wltoys V912
- suzali
15 Feb 2014 16:03 #20305
by suzali
wltoys V912 was created by suzali
Hello, I'm a bloody beginner in setting up a model. I'm pretty far with my Belt CPX (standard gui) on a 7e & it really does hover by now
But don't know how to start with a fixed pitch. Want to set up my V912.
Does anyone have a config or can I use the V911 setup I found here somewhere???
Thx !
Thx !
- aw73
17 Feb 2014 03:03 #20419
by aw73
Replied by aw73 on topic wltoys V912
i used the v911 config and tweaked it.
- suzali
17 Feb 2014 06:31 #20426
by suzali
Replied by suzali on topic wltoys V912
could you please post (or send as pm) the model.ini
- aw73
18 Feb 2014 04:05 #20507
by aw73
if i have time tomorrow i will pm you the config but the v911 config will fly the v912 with a few adjustments.
- suzali
18 Feb 2014 15:15 #20522
by suzali
Yes, that great!
So I can even compare unmodified and modified model.ini
Guess that's help a lot in understanding/learning.
Hope you find the time & thx!
- aw73
19 Feb 2014 00:44 - 19 Feb 2014 00:49 #20555
by aw73
this is the one i use but you might need to make adjustments for your v912. i have the honey bee 370 super motor on mine. you can add more servo throw but, i would not recommend it because it will become unstable in hard banks.
Last edit: 19 Feb 2014 00:49 by aw73.
- suzali
- Dandan123
16 Mar 2014 14:36 #21588
by Dandan123
Replied by Dandan123 on topic wltoys V912
I'm trying use the V912 with a rocket launcher (bullet). How should I config? anyone have tried? What channel I use for this function? I have a devo 12s... Thanks
19 Nov 2014 01:46 #26453
Replied by mwm on topic wltoys V912
DanDan, you still here? If so, I believe the reason you don't have an answer is because the V912 & V915 use different extensions than the V959, even though the basic protocol is the same.
I'm looking into getting working out what these are. If you could answer some questions, it might help.
Mostly, can you get a V959 Tx and see if it can control the rocket? Remove your blades before trying it, as it caused my V912 to kick the motor into high!
Time to create page: 0.081 seconds
Model Configs
- wltoys V912
