Axial SCX10 (land vehicile) with devo10...Dev4
04 Mar 2014 19:58 - 15 Mar 2014 05:53 #21196 by Hondawasaki
full function 9 channel
I have also included a SCX10 Honcho icon..
plan to work on custom display next...
Last edit: 15 Mar 2014 05:53 by Hondawasaki.
15 Mar 2014 04:18 - 15 Mar 2014 05:55 #21556 by Hondawasaki
Replied by Hondawasaki on topic Axial SCX10 (land vehicile) with devo10...Dev4
UPDATE
I now have 9 channels working ...
Devo 10 (Dev4) Axial SCX10 rc truck/crawler :)
It is in devo protocol.
Mode 2 settings ...
.( channel guide )
Ch1 is throttle ..Fmode0 =50% Fmode1=75% fmode2= 100% saftey=RUD DR1
Ch2 is front steering ...ALE DR1 = 4 wheel steering
Ch3 is Winch .. ..gear0=saftey
Ch4 is rear steering....ALE DR1=saftey
Ch5 is rotary knob AUX4
Ch6 is rotary knob AUX5
Ch7 is setup as a light switch
Ch8 is a servo switch ...Mix1=-100 Mix0=100
Ch9 is a servo switch ...Mix1=-100 Mix2=100
.PS I now plan to work on a custom screen graphics for the model
Last edit: 15 Mar 2014 05:55 by Hondawasaki.
15 Mar 2014 04:19 - 15 Mar 2014 04:24 #21557 by Hondawasaki
(((((((((((((MODEL15))))))))))))
name=SCX10.420
mixermode=Advanced
type=plane
[radio]
protocol=DEVO
num_channels=9
tx_power=100mW
[protocol_opts]
Telemetry=Off
[channel1]
safetysw=RUD DR1
template=complex
[mixer]
src=ELE
dest=Ch1
switch=FMODE1
curvetype=9point
points=-75,-55,-35,-20,0,20,35,55,75
[mixer]
src=ELE
dest=Ch1
switch=FMODE0
usetrim=0
curvetype=9point
points=-50,-40,-25,-15,0,15,25,40,50
[mixer]
src=ELE
dest=Ch1
switch=FMODE2
usetrim=0
curvetype=9point
points=-100,-75,-50,-25,0,25,50,75,100
[channel2]
template=complex
[mixer]
src=AIL
dest=Ch2
usetrim=0
curvetype=expo
points=0,0
[channel3]
safetysw=GEAR0
template=complex
[mixer]
src=THR
dest=Ch3
switch=GEAR1
curvetype=expo
points=-100,-40
[channel4]
reverse=1
speed=168
template=complex
[mixer]
src=RUD
dest=Ch4
curvetype=expo
points=-15,15
[mixer]
src=AIL
dest=Ch4
switch=AIL DR1
usetrim=0
curvetype=expo
points=0,0
[channel5]
failsafe=-100
template=complex
[mixer]
src=AUX4
dest=Ch5
usetrim=0
curvetype=expo
points=0,0
[channel6]
failsafe=-100
template=complex
[mixer]
src=AUX5
dest=Ch6
usetrim=0
curvetype=expo
points=0,0
[channel7]
template=complex
[mixer]
src=ELE DR1
dest=Ch7
switch=ELE DR1
usetrim=0
curvetype=deadband
points=0,0
[channel8]
template=complex
[mixer]
src=MIX1
dest=Ch8
switch=MIX1
usetrim=0
curvetype=deadband
points=0,-1
[mixer]
src=AIL
dest=Ch8
usetrim=0
curvetype=expo
points=0,0
[channel9]
template=simple
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
step=10
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
step=10
value=2,0,0
[timer1]
type=countdown
src=ELE DR1
resetsrc=AIL DR1
time=600
[timer2]
type=permanent
src=ELE DR1
val=11300
[datalog]
switch=None
rate=1 sec
[safety]
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch3
Small-box=2,31,Timer1
Model=75,20
TxPower=102,7
Battery=102,1
Toggle=42,10,72,0,0,None
quickpage1=Telemetry monitor
Last edit: 15 Mar 2014 04:24 by Hondawasaki.
15 Mar 2014 05:55 #21560 by Hondawasaki
Here is the new file ...happy Rc'ing
Time to create page: 0.119 seconds
