TREX 250 In Standard mode not possible?
31 Mar 2014 18:45 #21976 by Lyndros
Hi guys,
I tried to setup my trex 250 in standard mode but is not possible always need to switch to advanced mode... which I do not understand why... since with my previous dx7 I could easily setup...
Why is it not possible to configure the TREX with the standard gui?
Cheers and thanks for your help.
31 Mar 2014 19:33 #21981 by PhracturedBlue
Replied by PhracturedBlue on topic TREX 250 In Standard mode not possible?
I think you need to be more specific about what is not working.
06 Apr 2014 14:45 #22173 by Darth. Heli
Replied by Darth. Heli on topic TREX 250 In Standard mode not possible?
Please let me jump in, because I have the very same problem. The problem is: The swash menu is broken!
You have to reverse elevator and pitch servo, then the swashplate goes up and down with throttle up and down. So far, so good.
But then it comes to the swash plate. I select 3Servo120. And then chaos rules.
When I push ...
... nick forward:
Elev goes up,Pit goes up, Ail goes down
... nick backward:
Elev goes down, Pit goes down, Ail goes up
... roll to the right:
Elev goes down, Pit goes up, Ail doesn't move
... roll to the left:
Elev goes up, Pit goes down, Ail doesn't move.
The servos are connected as follows:
Elev: back
Pit: left
Ail: right
Now THAT looks crazy!
I tried other swash types, no one works.
Changing any value (eg PIT Mix from +50 to -50) doesn't change anything!
To sum up:
I'm lost. :-)
Cheers,
Volker
Time to create page: 0.096 seconds
