Helicopter/Quad - Models made in Standard Mixer
- Tom Z
09 Apr 2014 15:51 - 30 Apr 2014 15:30 #22272
by Tom Z
Helicopter/Quad - Models made in Standard Mixer was created by Tom Z
I made some models 100% from scratch using the Standard Mixer.
I also made models for the Devo 7e.
All the models are using my custom made GUI.
The models are for the Deviation V4 Firmware only.
One model is for the Devo 7e only.
One model is for the following Transmitters: DEVO 6/6S/8/8S/10/12/12S
The models are made for Standard Settings.
* I used the settings from my models made in the Advanced Mixer. If you would like to see what settings I used see my Master Helicopter and Quad Models list and see the Standard Settings for the model. deviationtx.com/forum/model-configs/2555...pter-and-quad-models
* Note: Some switch assignments had to be changed for the Standard Mixer models for the Devo 7e. Also the Devo 7e has less switches. You will only have the ST-1 and DR/EXPO 0 settings that I made for the other transmitters.
If you would like Beginner or 3D settings you can use the model as a starting point and use my settings from my Tx Setup Guides on my web site: www.rcproreviews.com
I made the models in the Standard Mixer which is easy to change the settings and is similar to the menus and options we are use to.
I made all my other models in the Advanced Mixer due to the Standard Mixer doesn't have all the features and options I need.
I wanted to offer some of my models in the Standard Mixer format to help out people who are having problems with the Advanced Mixer format due to it is completely different than the menus and options we are use to.
* I will not be making any more models made in the Standard Mixer
Fixed ID
My models do not use a Fixed ID.
If you used a Fixed ID with the original Walkera firmware you must clear the Fixed ID in the Receiver with the Bind Plug.
If you don't clear the Fixed ID the model will not bind.
If you want to use a Fixed ID you can enter the same Fixed ID you had for the original Walkera firmware.
Example: Your original Walkera firmware Fixed ID was: 123456
Assign the Deviation Fixed ID: 123456
You can also assign any Fixed ID that you want to use. You don't have to use the original Walkera firmware Fixed ID. Clear the Fixed ID in the Receiver with the Bind Plug then assign any Fixed ID that you want to use.
Fixed ID
Last edit: 30 Apr 2014 15:30 by Tom Z.
- Tom Z
09 Apr 2014 15:55 - 11 Apr 2014 23:52 #22273
by Tom Z
Replied by Tom Z on topic Helicopter/Quad - Models made in Standard Mixer
The Walkera Helicopter and Quad models are ready to install and fly.
Customize the settings to your personal preference.
Walkera CP Helicopters
- Walkera V120D02S
- Walkera V120D02S V2
- Walkera Mini CP
- Walkera Super CP
- Walkera Genius CP V1/V2
- Walkera V100D08
- Walkera Master CP
- Walkera V450D01/D03
The model will work in the Walkera 4f200lm but you need to reverse ALIE and RUDD.
The model will work in the Walkera V200D03 but you need to reverse ELEV and RUDD.
*If you are using the V120D02S, V120D02S V2, Genius CP V1 with the WK-2801 Pro compatible Receiver change Protocol=DEVO to Protocol=WK2801.
Download this model for the following Transmitters: DEVO 6/6S/8/8S/10/12/12S
Download this model for the Devo 7e only
Attachment model8-3_Devo7e.ini not found
Walkera FP Helicopters
- Walkera Super FP
- Walkera Genius FP
- Walkera V200D01 w/Devo Receiver RX2437V-D
- Walkera V200D02 w/Devo Receiver RX2440V-D
Walkera Quads
- Walkera QR Ladybird V1/V2
- Walkera Hoten X
- Walkera QR Infra X
- Walkera QR Spacewalker
- Walkera QR Scorpion
- Walkera QR W100/100S
- Walkera UFO MX400S
- Walkera QR X400
Last edit: 11 Apr 2014 23:52 by Tom Z.
- Tom Z
09 Apr 2014 15:55 - 22 Apr 2014 21:50 #22274
by Tom Z
The Align T-Rex 150 DFC model is ready to install and fly.
Set your ESC Li-po Cell Count setting to "AUTO". Default setting is 2 CELL.
ESC Settings
Functions
6. Li-Po Cell Count - Make sure to set this to "Auto".
Do not use the "2S" setting. You will have an extreme power/headspeed loss using the default "2S" setting.
Align CP Helicopter
Align T-Rex 150 DFC
ESC Settings
Functions
Align CP Helicopter
Align T-Rex 150 DFC
Attachment model21-3_Devo7e.ini not found
Last edit: 22 Apr 2014 21:50 by Tom Z.
- Tom Z
09 Apr 2014 15:55 - 11 Apr 2014 23:52 #22275
by Tom Z
The Blade CP model I made has settings all the helicopters use listed below.
The only difference between the models is the Pitch and Throttle curves are a little different for each helicopter.
The model can be flown as it is. For the best 3D performance you should adjust the Throttle Curves, Pitch Curves, and DR/EXPO according to what model helicopter you have.
For the Blade mCPX V1/V2 model there is no need to adjust any settings.
I programmed the model specifically for the Blade mCPX.
For the Blade FP helicopter model there is no need to adjust any settings.
Blade CP Helicopters
Blade mCPX V1/V2
Blade FP Helicopters
- Blade Nano CPX
- Blade mCPX BL
- Blade 130X
Attachment modelBCP_Devo7e.ini not found
Blade mCPX V1/V2
- Blade SR 120
- Blade mSR/mSR-X
- Blade mCX/mCX2
- Tom Z
09 Apr 2014 15:56 - 09 Apr 2014 16:10 #22276
by Tom Z
Reserved (1)
Last edit: 09 Apr 2014 16:10 by Tom Z.
- Tom Z
09 Apr 2014 15:56 - 09 Apr 2014 16:10 #22277
by Tom Z
Reserved (2)
- Tom Z
10 Apr 2014 17:05 #22324
by Tom Z
Models updated (DR/EXPO settings).
I also got a chance to test fly some of the models today.
- burch
20 Jan 2015 04:38 #27873
by burch
Replied by burch on topic Helicopter/Quad - Models made in Standard Mixer
Im useing this with a devo 7e and 130x the gyro does not seem to be working, everything worked fine on dx6i
Time to create page: 1.313 seconds
Model Configs
- Helicopter/Quad - Models made in Standard Mixer
