Align T-Rex 150 DFC - 3 Difficulty Modes
- Tom Z
01 May 2014 02:03 - 01 May 2014 13:26 #22816
by Tom Z
Align T-Rex 150 DFC - 3 Difficulty Modes was created by Tom Z
I made this model based off my other Align T-Rex 150 DFC models.
It has 3 difficulty modes: Beginner, Standard, 3D. The difficulty modes are controlled with the Flight Mode Switch.
Normal - Beginner Settings
No negative pitch for normal mode so you don’t slam the heli down if you pull the stick down to fast. Zero degrees pitch at mid stick. Mild pitch.
D/R = 50% EXP +30%
ST-1 - Standard Settings
-3* negative pitch. Zero degrees pitch at mid stick. More aggressive pitch.
D/R = 70% EXP +30%
ST-2 - 3D Settings
Full +/- 3D pitch curve. Zero degrees pitch at mid stick. Aggressive pitch.
D/R = 125% EXP LIN
Model 48 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Normal: Linear Curve
ST-1: V Shaped Throttle Curve
ST-2: More aggressive V Shaped Throttle Curve
Pitch Curve
Normal: No negative pitch for normal mode so you don’t slam the heli down if you pull the stick down to fast. Zero degrees pitch at mid stick. Mild pitch.
ST-1: -3* negative pitch. Zero degrees pitch at mid stick. More aggressive pitch.
ST-2: Full +/- 3D pitch curve. Zero degrees pitch at mid stick. Aggressive pitch.
Gyro Gain - These are the values I used then converted them to the deviation values.
Mix Switch
Pos 0: 65%
Pos 1: 70%
Pos 2: 75%
DR/EXPO
DR/EXPO is controlled with the Flight Mode Switch.
Normal: Beginner Settings
ELEV D/R = 50% EXP +30%
AILE D/R = 50% EXP +30%
RUDD D/R = 100% EXP +15%
ST-1: Standard Settings
ELEV D/R = 70% EXP +30%
AILE D/R = 70% EXP +30%
ST-2: 3D Settings
ELEV D/R = 125% EXP LIN
AILE D/R = 125% EXP LIN
RUDD D/R = 100% EXP LIN
D/R = 50% EXP +30%
D/R = 70% EXP +30%
ST-2 - 3D Settings
D/R = 125% EXP LIN
- Throttle hold on the RUDD D/R switch.
- 7 Point Throttle and Pitch Curves.
- TX Power=100mW
- Channels=7
- Protocol=DSMX
- No Fixed ID
Set your ESC Li-po Cell Count setting to "AUTO". Default setting is 2 CELL.
ESC Settings
Functions
6. Li-Po Cell Count - Make sure to set this to "Auto".
Do not use the "2S" setting. You will have an extreme power/headspeed loss using the default "2S" setting.
Pitch Curve
Mix Switch
Pos 0: 65%
Pos 1: 70%
Pos 2: 75%
DR/EXPO
ST-2: 3D Settings
Last edit: 01 May 2014 13:26 by Tom Z.
Time to create page: 0.322 seconds
Model Configs
- Align T-Rex 150 DFC - 3 Difficulty Modes
