Blade 200SRX?
- RWH
23 May 2014 16:24 #23532
by RWH
Blade 200SRX? was created by RWH
Hello to All here,
yesterday I got my new Blade 200SRX. I entered the settings from the userguide to my Devo 12s (with Deviation 4.1). It seems the modell is binding (red led changed to constant blue). But no reaction to any input from me with the Devo 12s.
Does anyone have the same problem - and a solution..?
Would be great!!
Best regards
Rudolf
Would be great!!
Best regards
Rudolf
- chromose
24 May 2014 12:22 - 24 May 2014 12:28 #23567
by chromose
Replied by chromose on topic Blade 200SRX?
Here's my work-in-progress for the stock 7e on Deviation 4.0.1.
A couple wonky things at the moment:
- Throttle hold is on the F MOD switch
- Flight mode is on the Hold switch
- No panic button at this time
(I couldn't get the auto-stabilizing to turn off when using F MOD originally)
Hold 0 is either beginner or intermediate mode. The auto leveling is on and servo throw is greatly limited (though I haven't played around enough to know if that's from the receiver/gyro or my transmitter curves).
I've got about 10 flights on it using this configuration.
Special note, this also replaces vertical trims with virtual switches. There are 3 timers on the left of the GUI. The top one is flight countdown (8 minutes). The middle one is total time for that flight session (assuming you don't turn the transmitter off between batteries), and the bottom one is permanent flight time for that model.
The left vertical trim switch plays/pauses the timers while the right vertical switch resets the top flight countdown.
Aside from customizing the GUI, this is my first major model configuration, so use at your own discretion
I'll be doing the 2x3 switch mod this weekend in hopes of getting all three flight modes in there and the HOLD switch back to its intended functionality. Will post that as a separate model if all works out.
Last edit: 24 May 2014 12:28 by chromose.
- RWH
24 May 2014 16:08 #23576
by RWH
Replied by RWH on topic Blade 200SRX?
Thank you for your reply.
I fixed my first problem. For 200SRX it seems to be absolutely necessary to use the binding plug for the first binding. All my other blade modells works without this plug. Now the 200SRX works.
I am using a Devo 12s (Deviation 4.0.1). I am using the acrobatic-mode
and I set "Gear = FMOD (0)" and K6 = TRN (for panic switch). THHOLD is regular. Seems it works, but I had only 2 flight till now.
May be this modell works for you, too, because I set only 6 channels. This is still a "beta", so take care.
- Stavross118
04 Jul 2014 15:54 #24382
by Stavross118
Replied by Stavross118 on topic Blade 200SRX?
Hi ordered my devo 10 should get it in a couple of days got my blade 200 srx using. Dx6i...
Just wondering if any of these files will work or if there's another file I could use as totally new and just starting to learn all about this great fw ....
Deviation seems to be the way to go especially as in the near future plan on walkera helis as well as blade
Many thanks
Many thanks
- Stavross118
14 Jul 2014 16:21 #24578
by Stavross118
all done everything now working after 2 days of reading and learning many thanks to all the info here,,,,,my devo 10 is much better than my dx6i at less the cost???
16 Jul 2014 22:40 #24628
Replied by mwm on topic Blade 200SRX?
Well, here's my entry. I started with my 200QX model
Controls:
Rud DR 0 is throttle hold (up to disable the hold). It's sticky, so you'll have to lower the throttle stick to 0 as well.
Ele DR 1 resets the countdown timer.
Gear 1 is Panic mode. This seems to be working fine.
Ail DR is dual rates: 0 is High, with an expo of 35, low is linear at 70%.
Fmode is flight mode: 0 -> low angle stability, 1 -> High angle stability, 2 -> Expert.
In addition, it inherited "stagility" mode from the 200QX model. This is on Mix:
Mix 0 -> No stagility at all.
Mix 1 -> Low stagility; when in high angle stability mode, it switches to agility mode when the elevator or aileron is around 90% of the way to the edge.
Mix 2 -> High stagility: as above, but the cutover is at about 50%.
Stagility mode is a work in progress.
I have two issues, and would like to know if others see this:
1) It doesn't seem to autolevel in high angle stability mode. The panic button works there, so it can, but doesn't.
2) Seems to need nearly 70% throttle to get off the ground. A bit high, if you ask me.
Controls:
- Stavross118
28 Jul 2014 22:23 #24877
by Stavross118
here is my file hope it helps someone have throttle hold on rudd/dr1 and flight modes all 3 on fmod panic is on gear switch also used latest nightly build as could not get switches to work properly this on my white devo 10......
i have kept it simple like me
- Stavross118
28 Jul 2014 22:30 #24878
by Stavross118
thanks
steve
also i have added the telemetry to on as it supposed to work but not sure if anyone can add info to this much apreciated...Stavross118 wrote:
thanks
steve
28 Jul 2014 22:35 - 28 Jul 2014 22:44 #24880
Telemetry on the 200 SR X sort of works, but it's not all that useful. They don't even provide battery voltage!
In normal mode, the various flight log data displays values from the vibration sensors. No real value, except that the smaller they are, the less vibration you have.
In gain setting mode, they display the current values of the gain settings. This doesn't work correctly on 4.0.1, as it doesn't display which gain the in gain setting indicator, or which setting you're currently adjusting. Still a lot easier than trying to read the swash plate, though.
Details from hh .
Stavross118 wrote: also i have added the telemetry to on as it supposed to work but not sure if anyone can add info to this much apreciated...
thanks
steve
Details from hh .
Last edit: 28 Jul 2014 22:44 by mwm.
- Stavross118
29 Jul 2014 06:10 #24882
by Stavross118
Thanks mwm that clears a lot of things up
- Mr-Ferret
19 Sep 2014 10:08 #25727
by Mr-Ferret
Replied by Mr-Ferret on topic Blade 200SRX?
hello, i am seeking a config for DEVO 8!
Is anyone here and use a DEVO 8 to fly an Blade 200 SR x?
Thx.
Thx.
- Barclay
22 Mar 2015 19:34 #30066
by Barclay
Replied by Barclay on topic Blade 200SRX?
Hi, do you know if this model template/ini file for the Blade 200 SR X will work on my Devo 8S?
- RWH
23 Mar 2015 08:26 #30097
by RWH
I am sorry, but I dont know if it will work.
23 Mar 2015 08:32 - 23 Mar 2015 08:33 #30098
The Devo 8 and 10 have the same set of switches, so any of the configs for the Devo 10 should work on an 8.
Last edit: 23 Mar 2015 08:33 by mwm.
- Joshua
23 Mar 2015 09:04 #30099
by Joshua
Replied by Joshua on topic Blade 200SRX?
I use it on my Devo8S and it works fine.
- Barclay
27 Mar 2015 19:20 - 28 Mar 2015 05:09 #30340
by Barclay
Hi Joshua, are you using the template named model2blade200srx.ini or one of the others? If this one, Stavross118 made mention of using the nightly build as he could not get the switches to work properly. I am using the current release v4.0.1. is that what you are using? Thanks for your help, Barclay. Stavross or anyone else, feel free to harp in here.
Last edit: 28 Mar 2015 05:09 by Barclay. Reason: left something out
- nwoodschris
03 Apr 2015 20:28 #30766
by nwoodschris
Replied by nwoodschris on topic Blade 200SRX - Need icon
Anyone have a good model icon for the 200 SRX on a Devo 10 they could share?
Thanks.
Thanks.
Time to create page: 0.084 seconds
Model Configs
- Blade 200SRX?
