T-rex 450 pro DFC with DSM2
- suchyjar
25 Jul 2014 06:07 #24787
by suchyjar
T-rex 450 pro DFC with DSM2 was created by suchyjar
Hi, I would like to ask if someone you do not .ini file for T-rex 450 for DFC. I use it with satellite DSM2.
Thanks for any reply
- suchyjar
07 Aug 2014 12:33 #25074
by suchyjar
Replied by suchyjar on topic T-rex 450 pro DFC with DSM2
Do not say, nobady fly with trex 450 for dfc to DSM2/x?
- tmcg
07 Aug 2014 14:08 #25075
by tmcg
Replied by tmcg on topic T-rex 450 pro DFC with DSM2
I have Trex 250 pro dfc with microbeast and dsmx sat. I just used the standard gui (instead of advanced), set new model to DSMX 8 channels and went through all the individual settings. The channels were already in correct order. I prefered this to copying an ini because I can see all the individual settings available to me. I would be happy to send you the standard gui ini that I have but I don't have the idle-up 3D (flight mode 3rd position) configured properly yet because I'm still working on my 2D flight. And the gyro percentages are probably different for 3GX than for microbeast.
- billmester
07 Aug 2014 21:00 - 07 Aug 2014 21:01 #25086
by billmester
I have an .ini for my Align 450 pro DFC 3GX with dual DSMX sats for DEVO10.
Very old file, I have changed the heli since, I found this in my archives. Please check before use - any questions, just ask.
Use at your own risk
bm
Replied by billmester on topic T-rex 450 pro DFC with DSM2
bm
Last edit: 07 Aug 2014 21:01 by billmester.
- dat
08 Aug 2014 01:00 - 08 Aug 2014 01:07 #25088
by dat
Replied by dat on topic T-rex 450 pro DFC with DSM2
here,the model is 450 pro v2 type with dsm2 and a ZYX-S gyro and plus a sat i used it on my DEVO 12S before.
but , but , i sincerely to recommend to you , resetup your heli from a new model by you yourself. you know why ? because every gyro always must to do a setup when you first use.
Last edit: 08 Aug 2014 01:07 by dat.
- suchyjar
11 Aug 2014 13:30 #25140
by suchyjar
3GX I set again. I found this forum some ini files, although it works, but I do not understand at all settings, it's all weird. Thank you for the files, I'll try and give you an answer.
- Ferdey
15 Aug 2014 03:05 #25199
by Ferdey
Replied by Ferdey on topic T-rex 450 pro DFC with DSM2
billmester, thank you for that file! I have been struggling to get my swash mixing working on my 450L/3GX and that file showed me how to do it. Phew!
Time to create page: 0.031 seconds
Model Configs
- T-rex 450 pro DFC with DSM2
