HFP80 V1 (V2) NRF24L01 module
- blackmoon
08 Aug 2014 22:22 - 12 Aug 2014 21:48 #25100
by blackmoon
HFP80 V1 (V2) NRF24L01 module was created by blackmoon
For mugen0001, model file tested on Devo7E mode2 with NRF24L01 module inside, and nightly build, it works as it should.
I should work on a devo8S, only thing is Throttle HOLD becomes RUD switch on the devo8S if not mistaken, maybe you should change that to your preference.
I didn't flight tested it, but on the bench all channels o the V1 model, react as they should, I don't see why they won't on the V2.
See post #3 for the file.
Last edit: 12 Aug 2014 21:48 by blackmoon.
- mugen0001
12 Aug 2014 09:03 - 12 Aug 2014 09:05 #25168
by mugen0001
Replied by mugen0001 on topic HFP80 V1 (V2) NRF24L01 module
Thank you verymuch.
I will try it., and tell you about it
Last edit: 12 Aug 2014 09:05 by mugen0001.
- blackmoon
12 Aug 2014 21:01 - 12 Aug 2014 22:06 #25181
by blackmoon
Replied by blackmoon on topic HFP80 V1 (V2) NRF24L01 module
Flight tested the file on a V1, model is a lot more balanced now with the modifications done on the file. Just need to add a sticky throttle hold.
I edited the model file (it was MO's one), it was based on a CP heli, so removed all CP stuff and also the scalar 125 on each channel (don't know why it was like that...).
No more 7 points curves, so :
FMODE0 rates 80 1-1.
FMODE1 rates 100 expo 15.
Thr 100 1-1
Rud 100 1-1
GUI layout is the one I use for all models, it's the Waldo's one.
Thr 100 1-1
Rud 100 1-1
Last edit: 12 Aug 2014 22:06 by blackmoon.
- mugen0001
13 Aug 2014 10:32 #25185
by mugen0001
thanks ,now i test this config .
throttle stick down => roter spin
,and i hold throttle down by my hand => roter not spin
- blackmoon
13 Aug 2014 15:29 #25190
by blackmoon
Troubleshooting time :
1.
Did you calibrate your transmitter after you installed deviation ?
2.
I don't know if this is relevant, but which mode is your devo set on ? mode 2 or mode 1 ?
3.
What's the revision of deviation you are using ? 4.1 or a nightly ?
4.
When you say "and i hold throttle down by my hand => roter not spin", does this mean that when you use throttle OLD, the rotor stops to spin ?
5.
Is your HFP80 a V2 ? If so maybe something as changed between V1 and V2, as I don't have any V2 that I can borrow like the V1, I can't test it.
6. Did you download the latest version of the file in post 3 ?
1.
2.
3.
4.
5.
- mugen0001
13 Aug 2014 19:03 #25192
by mugen0001
now i "calibrate my transmitter again" => it work (i use the post3 config)
- devo set on ? mode 2
- Deviation FW is "devo8-v4.0.1"
-My is "HFP80 Version 2" (Blade and canopy are Green color)
-if i want to slow down my "HFP80 Version 2" when i control , i must to change config which row. because my HFP80 is very quickly , over my control . i am beginner .
Thank you very much for your help
- blackmoon
13 Aug 2014 20:08 #25193
by blackmoon
I'm glad to read that it works now after calibration, a lot of people forget to calibrate and has you could see it gives a lot of headaches.
If you use the GUI to setup your model, and to "slow down" your helicopter you can reduce the rates, but pay attention at some point you'll be chasing your helicopter (the response will be to slow to compensate for any flight error).
So go to: Model Menu -> Mixers -> for each channel choose the "Complex" or "simple" then go down until you see "Scale", reduce that number from 80 to 70 then try it, if you don't like reduce it again.
If you edit the file you should change this for AIL and ELE :
[mixer]
src=AIL
dest=Ch1
switch=FMODE0
scalar=80
[mixer]
src=ELE
dest=Ch1
switch=FMODE0
scalar=80
Change the scalar=80 to scalar=70
[mixer]
src=AIL
dest=Ch1
switch=FMODE0
scalar=80
[mixer]
src=ELE
dest=Ch1
switch=FMODE0
scalar=80
- mugen0001
13 Aug 2014 20:24 #25195
by mugen0001
Thank you
I will try .
I will try .
Time to create page: 0.110 seconds
Model Configs
- HFP80 V1 (V2) NRF24L01 module
