WLToys V2x2 protocol camera platforms
28 Jan 2015 03:38 #28138
WLToys V2x2 protocol camera platforms was created by mwm
This is my config & icon for the V323 on my Devo10. It should work for the other large WLToys multirotors, like the V262, V333 and V353, though you might want to change the icon.
Switches:
High rates have a 35% expo, which is my preference.
Timer2 is a permanent timer. Both timers are switched on the throttle.
Still image capture takes 3 shots every time. This also happens with the RTF transmitter. With my old, SD v959 camera, that takes about 20 seconds, and trying to start video capture before then won't work.
Read my review for to find out how much deviationTx improves this hex!
Switches:
- RUD DR1 is sticky throttle hold, with display icon.
- ELE DR1 resets the countdown timer, currently starting at 8:30.
- GEAR1 turns the lights on.
- AIL DR1 is a low rate of 70%, no expo.
- FMOD2 is flip mode.
- The L+ trim start and stops video recording and toggles a display icon.
- The L- trim triggers a still image capture.
- rafael
05 Mar 2015 04:59 - 08 Mar 2015 21:43 #29343
by rafael
Replied by rafael on topic WLToys V2x2 protocol camera platforms
Thank you!
I'm using it with a V636 and it's great! The flip is not working, but I really don't care.
Nice job!
EDIT: Flip is working! My bad...
Nice job!
Last edit: 08 Mar 2015 21:43 by rafael.
- Spidermike
14 Jan 2016 15:55 #41752
by Spidermike
Replied by Spidermike on topic WLToys V2x2 protocol camera platforms
Hello there ,
the setting is going very well.
Thanks for that .
But I have one more question, I have to always bind manuel, you can adjust the way it goes automtatisch?
Sorry for my bad english, I live in Germany and can only speak a little English
greeting
horst
Thanks for that .
greeting
horst
Time to create page: 0.492 seconds
Model Configs
- WLToys V2x2 protocol camera platforms
