fy326 q7 quadcopter
- kingkong
05 May 2015 02:20 - 08 May 2015 20:06 #32088
by kingkong
fy326 q7 quadcopter was created by kingkong
Devo 7e modded with(A7105 and nRF24L01 ) working with fy326 q7 quadcopter. I forgot I use the nightly build 05/03/2015. You will have to recalibrate you TX after the binding is done. I hope this help.
Last edit: 08 May 2015 20:06 by kingkong.
- mbk17
05 May 2015 05:09 - 05 May 2015 05:15 #32090
by mbk17
Replied by mbk17 on topic fy326 q7 quadcopter
Thanks for the ini but my Q7 is not binding.
Last edit: 05 May 2015 05:15 by mbk17.
- lebowitz
08 May 2015 10:20 - 08 May 2015 10:21 #32242
by lebowitz
Replied by lebowitz on topic fy326 q7 quadcopter
This worked for me on latest nightly. Thank you.
I have some constant rudder but I'm almost positive it's me needing calibration on my end.
Last edit: 08 May 2015 10:21 by lebowitz.
- Splodgie
13 May 2015 09:10 - 19 Jul 2015 07:03 #32489
by Splodgie
Replied by Splodgie on topic fy326 q7 quadcopter (RED RX Board)
Hi, Same here, not binding at all, installed the latest nightly build 2015-05-03, tried all sub protocols in YD717, Must be some difference
on the PCB. (Red RX Board, V1 NO headless mode).
Last edit: 19 Jul 2015 07:03 by Splodgie. Reason: More RX PCB's and TX's for the Q7 since posting
- Durete
13 May 2015 10:10 - 13 May 2015 10:12 #32491
by Durete
Replied by Durete on topic fy326 q7 quadcopter
I read somewhere, something related to 2 different FC. One red and another green. One of them DeviationTx compatible, the other one not
Maybe a photo of the FC not binding with YD717 protocol, could bring some help to identify the transceiver used.
Last edit: 13 May 2015 10:12 by Durete.
- mbk17
14 May 2015 23:17 #32592
by mbk17
My quad will bind to the YD717 protocol with a X11 ini but not with the ini in this thread.Durete wrote: I read somewhere, something related to 2 different FC. One red and another green. One of them DeviationTx compatible, the other one not
- gonzalovalenzuela
16 May 2015 19:17 #32653
by gonzalovalenzuela
Replied by gonzalovalenzuela on topic fy326 q7 quadcopter
didn't work for me either, the pcb is red, so i think that is totally different from the green one
- mbk17
16 May 2015 23:45 #32671
by mbk17
Mine binds fine to this ini.
- robca
17 May 2015 15:10 #32689
by robca
Replied by robca on topic fy326 q7 quadcopter
I have a red PCB FY326, and mine is not working with my modded 7e... problem is, I just installed a nRF24L01 module, so I'm not sure if the module itself is working. But I can enable the YD717 protocol and I get no missing module error (I installed a nRF24L01 in another 7e, so I know how to properly wire for it. Unfortunately that radio is in another country right now
What color PCB do you have (and does it work or not)?
I also have a logic analyzer, in case I can help figuring out the red PCB protocol
- gonzalovalenzuela
18 May 2015 03:04 #32719
my module is working, I can bind with my Syma X5, X11, JJRC H8C and the CX-10 , so I will review the settings on the ini file, maybe I'm doing something wrong
- robca
18 May 2015 07:11 #32724
by robca
What color PCB? it's clear that there are 2 different versions of the FY326 (see also the thread on RcGroups), and my hypothesis is that the green one binds, the red one doesn't
- gonzalovalenzuela
19 May 2015 14:43 #32775
I think thats correct, my pcb is red and can't bind with my Devo7e
- greenfly
28 May 2015 02:53 - 28 May 2015 02:55 #33089
by greenfly
Replied by greenfly on topic fy326 q7 quadcopter
I have a 'green board' version and I have no problem binding with my Devo 7E.
Here is my simple, basic config.
Note: I have bumped the low-rate RUD Expo to 80% to compensate for the slow yaw with the stock transmitter.
BTW: I am running the latest nightly build.
Last edit: 28 May 2015 02:55 by greenfly.
- robca
31 May 2015 15:39 #33285
by robca
It's pretty clear that the red board i snot compatible. As a matter of fact, the red board seems ot have a lot of problems, including dropouts. Gearbest apologized for having shipped the red board version (they said the OEM sent them a different version with no warning, and all the newly shipped models are green board), and if you contact their support, they will offer you a few options to solve the issue.
I'm very impressed by how Gearbest handled this... waiting for my green board fy326 at the moment
- IKKI
26 Jun 2015 09:40 #34673
by IKKI
Replied by IKKI on topic fy326 q7 quadcopter
Hello to everyone.
This morning I went to the park to try out my new controller. With x4 3d connection is as good as with syma x12 no lag. In both, however, finding the problem that if I move the stick too much in some direction, the bird starts to do flips. I tried the various keys but nothing happens. In contrast with the model Fy326, I do not understand how to make the launch and go to normal mode. Last negative note. The controller range is 70 to 80 meters to set 150mw, shame the original controller arrivals to 300 meters. What does not work?
- cluxter
29 Apr 2018 23:39 #68929
by cluxter
I have not been able to bind my t8sg / 7e with a copy of syma; I think it's bayangtoys x8 and it does not bind either. Do you bind well with Syma X5?
Replied by cluxter on topic fy326 q7 quadcopter
gonzalovalenzuela wrote: my module is working, I can bind with my Syma X5, X11, JJRC H8C and the CX-10 , so I will review the settings on the ini file, maybe I'm doing something wrong
Time to create page: 0.050 seconds
Model Configs
- fy326 q7 quadcopter
