Many Config Files for Download
- gordonzo
15 May 2015 22:49 #32634
by gordonzo
Different fly for different guy.
Many Config Files for Download was created by gordonzo
I have many config files for my Devo 10:
Helis:
NE 328a
NE 228p
Hisky FBL70 / HFP80
Hisky FBL80 / HCP80
Blade MSR
Blade Tandem Rescue
Blade130x
Blade 200srx
Quads:
Ladybird QR-V1
Blade Nano QX
Hisky FF120 / HMX 120
RC Eye One Xtreme
Airplanes:
Champ
Mini Vapor
Spacewalker
Gee Bee R2
Nieuport 17
They can be downloaded here:
lonagord.wix.com/bigglittleo-1#!devo-10---deviation-40/c24ax
g
Helis:
NE 328a
NE 228p
Hisky FBL70 / HFP80
Hisky FBL80 / HCP80
Blade MSR
Blade Tandem Rescue
Blade130x
Blade 200srx
Quads:
Ladybird QR-V1
Blade Nano QX
RC Eye One Xtreme
Airplanes:
Champ
Mini Vapor
Spacewalker
Gee Bee R2
Nieuport 17
g
- Zaphod
16 May 2015 10:05 #32643
by Zaphod
Replied by Zaphod on topic Many Config Files for Download
Well done! Love the part re sticky hold.
Just a suggestion - with the model INI maybe a few words on what the controlling switches are (is Rudder d/r is throttle hold)
- gordonzo
16 May 2015 19:40 #32655
by gordonzo
Replied by gordonzo on topic Many Config Files for Download
Yes- I will be adding that soon. Thanks.
g
g
- thecric
06 Jul 2015 00:28 - 06 Jul 2015 21:22 #35143
by thecric
Replied by thecric on topic Many Config Files for Download
Thank you very much Gordonzo for your great work , it helps a lot.
Because I use your Eye One Xtreme .ini file on my Devo 10, I will add some infos I have found useful for the use of the .Ini file for EOX & Devo10
Careful, I'm NOT english native so tell me if you can't understand what I am trying to explain.
This config.ini use some tricky switches I like very much after tasting them:
First of all, there is a throttle Lock triggered by the Rudder D/R Switch.
You DON'T want this during the learning procedure of the EOX so you have to unlock the throttle by pulling the Rudder D/R Switch.
On the center of the display you should NOT see [TH] written in reversed font but in normal font which means throttle is unlocked
Second of all, AUX4 is used to control the sensibility of ELEVATOR/AILERON. When you turn AUX4 you can change the sensibility from 50% to 100%
During the learning procedure, I guess it's better to use 100%
To do the learning procedure you can use the great help of this video which is referenced elsewhere if I remember on the forum
-- note that the display is slightly different because of a different .ini but after all it seems to be from the same author so....
Some other things good to know about this .ini
FMOD is used as Channel 5: beginner mode / sport mode / expert mode
MIX is used as Channel 6 : acrobatic mode /normal flight / altitude height hold
GEAR is used to lock some expo you can put by rotating AUX5
AILE D/R is a Rudder /Aileron swapper which is very fun to use and very useful to get access to rudder command without moving throttle and losing Altitude height hold . The swap occurs on right stick (mode 2) and replace aileron command by rudder command. You can quickly switch back AILE D/R if you need to go back to normal. This can be very effective to do photography / panoramic using Altitude height hold.
On the Devo 10 display, you see an A meaning Aileron when swapping is not activated, R in reversed font meaning Rudder when swapping is activated
To understand how to use it, use Gordonzo video Eye One Xtreme - Special Alt-Hold
I hope these few notes help
Last edit: 06 Jul 2015 21:22 by thecric. Reason: typo
- gordonzo
07 Jul 2015 02:04 #35186
by gordonzo
Glad the ini works well for you. I have flow many hours with this configuration.
There is one discrepancy in your description - 'GEAR is used to lock some expo you can put by rotating AUX5'
This statement may be a language issue, but to clarify, the Gear switch allows you to use Aux5 to adjust cruising speed ie 'cruise control'.
g
g
- cyclops13
30 Nov 2015 20:10 #40510
by cyclops13
Replied by cyclops13 on topic Many Config Files for Download
The link seems to be broken?
- biker
01 Dec 2015 22:25 #40537
by biker
Replied by biker on topic Many Config Files for Download
Yes, looks like it, I'm looking for a Hisky FF120 / HMX 120 config file.
Any one?
Any one?
- mono
22 Jan 2016 09:55 #42061
by mono
Replied by mono on topic Many Config Files for Download
A google search for bigglittleo deviation brought up a link which works....
lonagord.wix.com/bigglittleo#!devo-10---deviation-40/c24ax
Time to create page: 0.095 seconds
Model Configs
- Many Config Files for Download
