Walkera Runner 250
08 Aug 2015 02:17 - 08 Aug 2015 03:29 #36670 by raduque
Walkera Runner 250 was created by raduque
Hold tight folks, I'm still working on a better ini. For now, though, I have this one.
It has -50 expo on the RUD, and 50/85 DR with no Expo on the AIL/ELE channels. FMOD0 is 50% and FMOD1 is 85.
Throttle hold is active on HOLD0. THR also has a subtrim of 12.5 so it SHOULD start spinning the motors when you flip to HOLD1. This is to help correct the "Flip of Death" (quad spins up one set - front, back or side - of motors before the other and causes an uncontrolled flip and crash) when you cut throttle and then power back up.
I'm currently trying to figure out how to enable Acro mode on FMOD, but it looks like the Runner is looking for activity on channel 5, but right now CH5 seems to be locked to the HOLD switch.
Edit: Ah, got it! Acro mode has been achieved.
The first INI enables Acro on FMOD1 and stability on FMOD0 with a simple 100% rate on AIL/ELE. The expo on RUD stays the same.
The second INI is the same as the first one I posted, just renamed to DR for the Dualrates on the FMOD switch.
Last edit: 08 Aug 2015 03:29 by raduque. Reason: New inis.
15 Aug 2015 04:36 #36905 by WallyJas
Replied by WallyJas on topic Walkera Runner 250
Super work thanks mate ..... I'll test it on mine this weekend. :)
15 Aug 2015 19:16 #36920 by SirDomsen
Replied by SirDomsen on topic Walkera Runner 250
Shouldn't it be possible to translate the devo7 settings to deviation und program an ini like that? Just an idea...
Greetz
Domsen
16 Aug 2015 01:11 #36930 by raduque
Replied by raduque on topic Walkera Runner 250
SirDomsen wrote: Shouldn't it be possible to translate the devo7 settings to deviation und program an ini like that? Just an idea...
Greetz
Domsen
The biggest issue is that I wasn't understanding how the Devo7 settings translated to Deviation settings, till I read the actual Devo7 manual, vs the Runner 250's quick start guide.Then it was just a matter of messing with the Ch5 curve till I had it to where FMOD0 is INH and FMOD1 is ACT.
16 Aug 2015 06:36 #36936 by SirDomsen
That's what i was thinking about ;-)
Greetz
Domsen
27 Sep 2015 03:36 - 27 Sep 2015 07:55 #38099 by WallyJas
Guys,
I've only just got around to trying the Runner250 with my 7E however am having troubles with it.
I've managed to get it to bind ok however I can't get it to arm and I'm not sure how to configure the switches to change flight modes or trigger the buzzer. I did notice that when I went to bind it the protocol was set to 'none' and I had to change it to 'DEVO', even though in the .ini file I can clearly see that it says it should be 'DEVO'. Does that mean that the .ini is not working correctly?
If anyone could help I'd really appreciate it.
Last edit: 27 Sep 2015 07:55 by WallyJas.
11 Jan 2016 21:08 #41646 by Renfeild
Replied by Renfeild on topic Walkera Runner 250
Hi Raduque,
Were you able to complete a fully functional ini for the walkera runner 250 and how did you get it working? Do you have to bind it to the devo 7/10 or does it bind automatically to the 250 after powering up the transmittter?
Thanks for the hard work,
Renfeild
17 Jan 2016 03:28 #41850 by kchupe
Replied by kchupe on topic Walkera Runner 250
I am in need of this config as well
27 Jan 2016 06:18 #42267 by kchupe
I can't seem to bind or if it is binding I can't get the motors to arm. Any suggestions? I have Rudder DR on 0, then FMOD to 0 and all the other switches to 0 then I put throttle to 0% and push rudder right, also tried rudder left with throttle 0% but nothing is happening. Any ideas? Thanks
04 Apr 2016 11:10 #45774 by mindo
Replied by mindo on topic Walkera Runner 250
I have configured a model for Runner 250 Advance with flight modes on FMOD switch and GPS functions on MIX switch.
Gear for throttle hold. No Camera on/off functions at this moment
But where is the ini file? So I can share it!
04 Apr 2016 14:58 #45781 by victzh
Replied by victzh on topic Walkera Runner 250
Mark your model number, say X. Switch your Devo to USB mode - easiest is to hold ENT button (usually on the right of your Devo) while turning it on. On the Devo's drive in the directory 'models' there is a file modelX.ini where X is the order number of the model you marked in step 1. This is your config file for the model. Share it with us, please.
04 Apr 2016 21:22 - 04 Apr 2016 21:24 #45795 by mindo
Here my model.ini for Walkera Runner 250 Advance.
Throttle, Aileron, Elev and Rudd with Dual rate.
Ail DR, Elev DR and Rudd DR assigned to respective switch: Position 0= linear curve, position 1=40% Expo
Throttle with expo.
Gear switch used to turning ON throttle hold to -110% so to immediately turning OFF motors (when you see the ground is really near....:-) )
FMODE switch used to toggle flight mode: position 0 and 1= stabilized, position 2= ACRO mode
MIX switch use to toggle GPS mode: Position 0= no GPS, position 1= GPS HOLD, position 2=ReturnToHome
2 timers: countdown (8 minutes) e stopwatch started by throttle. Timer resetted with AUX4 and AUX5 Knob.
I have not used Gear to turning on/off camera cause I Dont' use camera recording, I prefer using gear long switch as "hazard switch" when you are in serious problems
No fail safe configured to throttle cause in some forum I read that it could cause problems to RTH.
Attached ini file, quad bmp and toggle used
Hoping could be useful to someone!
_____________________________________
name=Runner 250
mixermode=Advanced
type=plane
[radio]
protocol=DEVO
num_channels=7
tx_power=100mW
[protocol_opts]
Telemetry=On
[channel1]
template=expo_dr
[mixer]
src=ELE
dest=Ch1
scalar=105
[mixer]
src=ELE
dest=Ch1
switch=ELE DR1
scalar=105
curvetype=expo
points=40,40
[channel2]
template=expo_dr
[mixer]
src=AIL
dest=Ch2
scalar=105
[mixer]
src=AIL
dest=Ch2
switch=AIL DR1
scalar=105
curvetype=expo
points=40,40
[channel3]
safetysw=GEAR1
safetyval=-110
min=-110
subtrim=117
template=expo_dr
[mixer]
src=THR
dest=Ch3
scalar=105
curvetype=expo
points=40,40
[channel4]
template=expo_dr
[mixer]
src=RUD
dest=Ch4
scalar=105
[mixer]
src=RUD
dest=Ch4
switch=RUD DR1
scalar=105
curvetype=expo
points=40,40
[channel5]
failsafe=-100
template=complex
[mixer]
src=!MIX0
dest=Ch5
[mixer]
src=MIX1
dest=Ch5
switch=MIX1
scalar=0
usetrim=0
curvetype=fixed
[channel6]
template=complex
[mixer]
src=!FMODE0
dest=Ch6
usetrim=0
[mixer]
src=FMODE1
dest=Ch6
switch=FMODE1
scalar=0
usetrim=0
curvetype=fixed
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
step=2
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
step=2
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
step=2
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
step=2
[timer1]
type=countdown
src=THR
resetsrc=AUX4
time=480
[timer2]
src=THR
resetsrc=AUX5
[datalog]
switch=None
rate=1 sec
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch3
Small-box=2,31,Timer1
Small-box=2,39,Timer2
Model=75,20
Battery=102,1
Toggle=4,10,0,3,0,RUD DR
Toggle=13,10,0,5,0,ELE DR
Toggle=22,10,0,4,0,AIL DR
Toggle=31,10,192,193,194,FMODE
Toggle=40,10,0,211,202,MIX
TxPower=102,7
H-trim=5,59,0
V-trim=65,10,0
H-trim=74,59,0
Model=75,20
Battery=102,1
Toggle=49,29,0,214,0,GEAR
Toggle=13,10,0,5,0,None
Toggle=22,10,0,4,0,None
H-trim=39,35,0
Small-box=40,32,None
quickpage1=Trims
quickpage2=Mixer
quickpage3=Telemetry monitor
quickpage4=None
Last edit: 04 Apr 2016 21:24 by mindo.
05 Apr 2016 05:31 #45813 by stevemeister
Replied by stevemeister on topic Walkera Runner 250
Many thanks!! Will try this evening and revert back!
Regards,
Steven
05 Apr 2016 07:40 #45815 by mindo
Next days I'll do a .ini for Walkera Runner 250 basic, not advanced
05 Apr 2016 07:51 #45817 by mindo
mindo wrote: Next days I'll do a .ini for Walkera Runner 250 basic, not advanced
I quote myself, my .ini can be used with Runner Basic too, the only difference is that flight modes will be toggled with MIX Switch and not FMODE switch
06 Apr 2016 11:43 #45911 by stevemeister
Hi Mindo,
I was wondering why you set the failsafe to -100 in channel 5 (GPS)?
Doesn't the 250 advance fly back on signal loss?
Regards,
Steven
[channel5]
failsafe=-100
06 Apr 2016 12:14 - 06 Apr 2016 12:57 #45913 by mindo
stevemeister wrote: Hi Mindo,
Regards,
Steven
[channel5]
failsafe=-100
Failsafe on Channel 5 means that when you loose signal, GPS Switch goes to RTH. I don't know if flight controller has rth embedded
Last edit: 06 Apr 2016 12:57 by mindo.
06 Apr 2016 14:12 #45920 by Renfeild
According to the user manual it should RTH when signal loss occurs, but the added feature is fantastic. Thanks for the settings and I look forward to your update.
Renfeild
06 Apr 2016 17:45 #45948 by stevemeister
If you ask me; if the transmitter loses signal how can it send the RTH command? It can't??
RTH on signal loss is programmed in the quad itself I think.
06 Apr 2016 17:55 - 06 Apr 2016 17:59 #45950 by stevemeister
Well, here it is. Mindo's version worked very good, I altered a few things:
- GEAR switch now triggers foto/video
- Set throttle curve without expo; like standard curve as Devo 7 does
- removed throttle hold to immediately turn off motors (needed GEAR switch for foto/video)
Questions I still have:
Channel 5 (GPS MIX switch) has fail-safe set to -100. Maybe this one can be removed, any ideas?
Something I would still like to do:
- use RUDD D/R switch to set throttle hold to MID-STICK, so that GPS mode keeps exact same height
Regards!
File Attachment:
File Name: model7-Run....ini.txt
File Size:4 KB
Last edit: 06 Apr 2016 17:59 by stevemeister.
Time to create page: 0.127 seconds
