Eachine Racer 250/general purpose 6ch RX+CF/BF/OP
03 Dec 2015 22:02 - 03 Dec 2015 22:23 #40581 by dropax
All files use 6 channels (DSMX protocoll, change it according to your RX)
Edit: forgot to mention they are for Devo 7e.
model8 is for Openpilot:
Channel 5 uses FMOD and HOLD to switch output between
a) -100 with FMOD0+HOLD0
b) 0 with FMOD1+HOLD0 or FMOD0+HOLD1
c) 100 with FMOD1+HOLD1
Channel 6 is a virtual pot on right horizontal trim to be used for inflight adjustments.
model10 and model11 are for cleanflight / betaflight:
Channel 6 is a virtual momentary 3-position switch on right horizontal trim to be used for inflight adjustments.
model10 (without switch mod on devo)
FMOD for 2 flightmodes and HOLD to activate Blackbox are mixed in channel 5, paste this into CLI to see how it is demuxed in the flightcontroler:
aux 0 1 0 900 1500
aux 1 2 0 1500 2100
aux 2 25 0 925 1150
aux 3 25 0 1550 1700
model11 (with 3x2 switch mod)
SWB for 3 flightmodes, FMOD triggers blackbox and HOLD activates g-tune, again to be used with some aux-settings:
aux 0 1 0 1725 2050
aux 1 2 0 1350 1650
aux 2 25 0 1175 1300
aux 3 25 0 1500 1650
aux 4 25 0 1900 2025
aux 5 20 0 1050 1100
aux 6 20 0 1200 1250
aux 7 20 0 1350 1400
aux 8 20 0 1500 1550
aux 9 20 0 1725 1775
aux 10 20 0 1900 1950
Don't hesitate to ask if something is unclear and leave a feedback if you like it. :lol:
Last edit: 03 Dec 2015 22:23 by dropax.
15 Dec 2015 14:51 #40956 by vincentko88
Replied by vincentko88 on topic Eachine Racer 250/general purpose 6ch RX+CF/BF/OP
Dear Dropax,
I am planning to purchase the new Eachine 250 racer from Banggood.
What is your rx model and setup? and what mod require for devo 7e?
I already install the nrf24L01 & A7105 in my devo7e
Should I do the cyrf6936 resistor mod with DSMX rx or CC2500 mod with Frysky?
Vincent
18 Dec 2015 14:36 #41018 by justyn07
can i use this with the devo 10. thank you.
18 Dec 2015 15:10 #41019 by dropax
vincentko88:
I use a DSMX compatible S603 Rx, the range mod is mandatory for this.
To add the CC2500 you have to install the multi module board or take out one of the other modules.
justyn07:
Not sure but deviation intends to make this possible - try it and report back. ;)
18 Dec 2015 18:02 #41021 by Deal57
A model.ini for the 7e will work on the 10, but you need to change the names of each switch. The stock 7e has Hold 0/1 and FMOD 0/1, and the 10 has a bunch more switches. Trims and screen layouts, as well as any virtual channels should work fine, but when you change the switch names, the toggles may need changed.
I highly recommend the Model File Utility, and with mwm's Staight.exe much of the conversion can be done for you.
08 Mar 2016 21:27 #44282 by ursus69
Hi Dropax!!
I'll receive shortly a ER250 and S603. ....and I have the Devo7E with 3x2 switches and Smod module...
I have to use the model11. ¿Correct?
What is the triggers blackbox? And the g-tune??
Thanks for help
08 Mar 2016 22:24 #44287 by dropax
Reread the first post, from your questions I assume you're using openpilot. ;)
Model 11 is for betaflight (made this for version 2.1.6 iirc), with the above aux settings pasted to CLI you can switch blackbox recording on/off - Gtune is removed in the newer releases of betaflight (and pretty much useless anyways...)
08 Mar 2016 23:50 #44295 by ursus69
Hi dropax!!
I never used Openpilot :P
I will receive soon the ER250, and I'm looking for a .ini that works with my Devo7E with 3x2 and S603...
Any recommendation?
09 Mar 2016 08:18 #44310 by dropax
Model 8 is for openpilot but has 3 flightmodes distributed on the 2 devo stock switches. Compare the files and tinker if you want flightmodes on a 3-pos switch. ;)
Personally I prefer betaflight but openpilot is easier to setup for beginners. :)
23 May 2016 21:59 #49091 by kaligola
im tring to get cc3d with betaflight and r615x dsmx to work on devo 7e with 2 switches originals
id like to get in cleanflight the 1500 mid position and range of sticks 1000-2000 with no succes
can i get hold and fmod combined to get flight modes and or dual rates/led
im sorry this is my first model and just cant get out of it , the more i go the more i mess it up :S
name=zmr160
mixermode=Advanced
type=multi
[radio]
protocol=DSMX
num_channels=6
fixed_id=123369
tx_power=150mW
[channel1]
scalar=120
scalar-=120
subtrim=5
template=simple
[mixer]
src=THR
dest=Ch1
[channel2]
reverse=1
scalar=110
scalar-=110
subtrim=10
template=simple
[mixer]
src=AIL
dest=Ch2
[channel3]
template=simple
[mixer]
src=ELE
dest=Ch3
[channel4]
reverse=1
template=simple
[mixer]
src=RUD
dest=Ch4
scalar=115
[channel5]
template=simple
[mixer]
src=HOLD0
dest=Ch5
curvetype=expo
points=0,0
[channel6]
safetysw=!FMODE0
template=complex
[mixer]
src=FMODE0
dest=Ch6
switch=FMODE1
curvetype=expo
points=0,0
[ppm-in]
mode=stick
num_channels=1
switch=None
centerpw=1500
deltapw=400
map1=THR
map2=AIL
map3=ELE
map4=RUD
map5=None
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer2]
type=countdown
time=10
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch1
Small-box=2,31,Timer1
Small-box=2,40,Timer2
Model=75,20
Battery=102,1
Toggle=4,10,0,3,0,None
Toggle=13,10,0,5,0,None
Toggle=22,10,0,4,0,None
Toggle=31,10,0,0,0,None
Toggle=40,10,0,0,0,None
TxPower=102,7
quickpage1=Telemetry monitor
Time to create page: 0.089 seconds
