Hobby King Assault Reaper 500 with Devo12 config
06 Mar 2016 12:55 #44189 by Fernbediener71
Hobby King Assault Reaper 500 with Devo12 config was created by Fernbediener71
Here are initial Settings for the Hobby King Assault Reaper 500 (like Stingray 500).
The Settings are like the settings from the manual with small improvements:
- If you switch the flight mode the Reaper will not jump or fall.
- The Hold=1 switches off the motor (for configuration and starting and crash)
- The ELEV D/R sets the sensitivity of Ele and Aile (mid – low - high)
- Mix Switch regulates the Gyro (80%/70%/50%) but this is not tested, I did not feel any difference. I Use an RX601 with Aux1 (Chan 5) to Aux1 (Reaper).
- The Timer is set to 7minutes, reset=TRN switch
I did not flip or things like this with the Reaper the settings are ok for hovering and regular drone flight.
Has anyone other settings so far?
I think with some small modifications in the ini File these Settings will work for other Devo models.
09 May 2016 19:37 #48134 by Fernbediener71
Replied by Fernbediener71 on topic Hobby King Assault Reaper 500 with Devo12 config
The GYRO settings are a mistake in the manual. There is no option to change the Gyro settings in the FC.
09 May 2016 22:29 #48139 by HappyHarry
Replied by HappyHarry on topic Hobby King Assault Reaper 500 with Devo12 config
will this ini also work with the wltoys v383-500 quad?
Time to create page: 0.089 seconds
