HiSky HCP60
22 Apr 2016 11:19 - 29 May 2016 13:20 #46975 by matrixFLYER
HiSky HCP60 was created by matrixFLYER
HiSky HCP60. I use this model on a Devo 10 with april 2016 nightly.(works on 5.0)
GEAR 0: 3 axis
GEAR 1: 6 axis
MIX 0/1/2 = CH5(gyro) -100/0/100 I don't know if this may change something in the flight
30% expo on aileron and elevator and 10% on rudder
FMOD0 = almost no negative pitch and motor curve from 0 to 100%
FMOD1= STUNT1. Almost flat 80% throttle curve and pitch from -100 to 100
FMOD2 same as FMOD1 but max throttle value is 100%
Pitch is set to +/- 70
Aileron/Elevator are on 100% or more on all modes.
timer on 4 minutes
Last edit: 29 May 2016 13:20 by matrixFLYER.
29 Apr 2016 20:12 #47445 by lakodathecat
Replied by lakodathecat on topic HiSky HCP60
I found this HCP60 ini on a Russian webpage. I haven't tried it and I'm not sure what it actually does. It's a very complex setup which can be great if it works. Use lots of virtual channels. If someone wants it here it is. I did not make or used it yet... Feel free to delete this.
Time to create page: 0.064 seconds
