bind devo 7e ( version 5.0 ) with RX frsky problem
31 May 2016 11:18 - 31 May 2016 11:20 #49627 by anthony7288
hi all
i just update devo 7e with version 5.0 .I install modul CC2500 PA/LNA .Then i config in hardware.ini
[modules]
; enable-cyrf6936 = B12
has_pa-cyrf6936 = 0
; enable-a7105 = A13
; has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
; enable-nrf24l01 = A14
; has_pa-nrf24l01 = 1
; enable-multimod = A13
When i power TX , it warring "" Missing CC2500 module "" . i can not Bind with RX frsky V8 . And how to bind with Re-int ? turn on TX ?
anyone help me ? what am i wrong ?
Last edit: 31 May 2016 11:20 by anthony7288.
31 May 2016 11:34 #49630 by mwm
That warning is telling you that the TX isn't seeing the CC2500 module. Either your hardware install is broken, or the hardware.ini isn't right. The latter looks right, so the only problem would be that you've got the enable pin wrong.
Post pictures of your hardware setup so people can diagnose that.
31 May 2016 12:08 - 13 Jul 2016 06:54 #49636 by anthony7288
Replied by anthony7288 on topic bind devo 7e ( version 5.0 ) with RX frsky problem
ok , i sucessfull
Last edit: 13 Jul 2016 06:54 by anthony7288.
Time to create page: 0.395 seconds
