ALIGN TREX 450L Dominator w/BRAIN F.less control
19 Jun 2016 17:09 - 10 Oct 2016 15:20 #50808 by mindo
here attached ini file created for my TREX 450L Dominator with Brain Flybarless flight controller www.msheli.com/
FMOD0= normal thr (no idle up)
FMOD1= idle up 1
FMOD2= idel up 2
MIX0=flight mode 1 (in my Brain: Beginner mode with stabilized mode and rescue)
MIX1=flight mode 2 (in my Brain: Beginner mode)
MIX2=flight mode 3 (in my Brain: Sport mode)
GEAR1=Panic button (stop motor)
Hoping could help someone!
_______________________________
name=TREX450L
mixermode=Advanced
[radio]
protocol=DEVO
num_channels=7
tx_power=150mW
[protocol_opts]
Telemetry=On
[channel1]
max=128
scalar=250
scalar-=116
min=-250
template=cyclic1
[channel2]
reverse=1
max=119
scalar=250
min=-125
template=cyclic2
[channel3]
safetysw=GEAR1
safetyval=-100
scalar-=100
failsafe=-100
template=complex
[mixer]
src=THR
dest=Ch3
curvetype=5point
points=-100,-55,5,65,100
smooth=1
[mixer]
src=THR
dest=Ch3
switch=FMODE1
curvetype=5point
points=80,70,60,70,100
[mixer]
src=THR
dest=Ch3
switch=FMODE2
curvetype=5point
points=100,90,80,90,100
[mixer]
src=THR
dest=Ch3
switch=GEAR1
scalar=-100
curvetype=fixed
[channel4]
reverse=1
scalar=250
scalar-=250
template=expo_dr
[mixer]
src=RUD
dest=Ch4
curvetype=expo
points=45,45
[mixer]
src=RUD
dest=Ch4
switch=RUD DR1
scalar=60
curvetype=expo
points=45,45
[channel5]
template=complex
[mixer]
src=!MIX0
dest=Ch5
[mixer]
src=AIL
dest=Ch5
switch=MIX1
scalar=0
usetrim=0
curvetype=fixed
[channel6]
max=86
scalar=126
subtrim=250
min=-85
template=cyclic3
[channel7]
template=simple
[virtchan1]
template=expo_dr
[mixer]
src=AIL
dest=Virt1
curvetype=expo
points=35,35
[mixer]
src=AIL
dest=Virt1
switch=RUD DR1
scalar=65
curvetype=expo
points=35,35
[virtchan2]
template=expo_dr
[mixer]
src=ELE
dest=Virt2
curvetype=expo
points=35,35
[mixer]
src=ELE
dest=Virt2
switch=ELE DR1
scalar=65
curvetype=expo
points=35,35
[virtchan3]
template=expo_dr
[mixer]
src=THR
dest=Virt3
curvetype=5point
points=-32,4,16,35,70
smooth=1
[mixer]
src=THR
dest=Virt3
switch=FMODE1
curvetype=5point
points=-100,-60,8,31,85
smooth=1
[mixer]
src=THR
dest=Virt3
switch=FMODE2
curvetype=5point
smooth=1
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
step=5
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
step=5
value=4,0,0
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
step=5
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
step=5
value=-17,0,0
[trim5]
src=Virt1
pos=TRIM_R+
step=193
value=-100,0,0
[trim6]
src=Virt2
pos=TRIM_L+
step=193
value=-100,0,0
[trim7]
src=Virt3
pos=Enter
step=193
[timer1]
src=THR
resetsrc=Virt2
[timer2]
type=countdown
src=THR
resetsrc=Virt1
time=600
[datalog]
switch=None
rate=1 sec
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch3
Small-box=2,32,Timer1
Small-box=2,41,Timer2
Model=75,20
Battery=102,1
Toggle=4,10,0,3,0,RUD DR
Toggle=13,10,0,5,0,ELE DR
Toggle=22,10,0,4,0,AIL DR
Toggle=31,10,207,209,210,MIX
Toggle=40,10,192,193,194,FMODE
TxPower=102,7
Toggle=48,31,0,214,0,GEAR
Small-box=51,1,Ch6
quickpage1=Telemetry monitor
Last edit: 10 Oct 2016 15:20 by mindo.
