Walkera Furious 320(G) setup file - GPS version!
07 Sep 2016 21:15 #53604 by FrankV
Hello people,
For the ones who are interested: I made my setup for my Furious 320 GPS version, with a Devo 10 transmitter MODE 2.
Mode 1 might need some minor mods but I suppose that is no problem.
You may find the needed files attached.
Please read the attached PDF - it contains also some information you need to know before flying :)
If you have any remarks, please let me know.
Firmware: Walkera Furious_320_1_12_2.bin
Transmitter: Devo 10, mode 2
23 Dec 2016 05:09 #57144 by Aleks341
Prompt please, this version is made based on the "M" version? If not, do you plan to do this?
27 Dec 2016 08:07 #57263 by nemo152
You can make settings in ini a format for this purpose
www.walkeraforums.com/threads/updating-y...ps-version-only.707/
27 Dec 2016 11:48 - 27 Dec 2016 11:56 #57264 by FrankV
@aleks341: I am not sure what version the M is. If it is the GPS version, then it will work.
If it is the non-gps version, then some minor adjustments in the ini file has to be made (e.g. the MIX-switch). I'm not familiar with the differences in the settings for the GPS and normal version. So I'm not able to make a new ini file for the regular version.
In the mean time I don't own the Furious any more, so I cant test anything from now on. The GPS version ini file worked great so far.
@nemo152: your link points to the devo ini file - meant for the devo with its original firmware. This thread however, is about the ini file with the deventiontx firmware and ini's installed. These ini files are not compatible with each other.
Please also read the attached manual: the function of the switches is different then the Devo firmware with devo ini installed.
E.g. the gear switch: in this version it is meant for the trainer port, and not the camera port. This will have strange effects if you like to take a picture in mid-air :)
Therefore: please read the manual belonging to this version and forget the Devo from the walkeraforums website.
Last edit: 27 Dec 2016 11:56 by FrankV.
28 Dec 2016 09:13 #57283 by Aleks341
I mean GPS version.
But if you now do not have 320, sorry.
28 Dec 2016 10:48 - 28 Dec 2016 10:50 #57286 by FrankV
The posted ini file in the first post is meant for the GPS-version as the subject says. For Deviationtx modded Devo transmitter.
Maybe I don't understand your question though but please explain then.
Last edit: 28 Dec 2016 10:50 by FrankV.
29 Dec 2016 16:46 #57332 by Aleks341
I understand that the first post was written about GPS version. And i need exactly а GPS version . But i think that GPS version with "M"
index is more interesting. ("M" version was made later, its newer.)
I would like to to remake ( fix) that "M" version for Deviation firmware , but i havent this ability. Im sory for my poor english.
29 Dec 2016 17:48 #57336 by FrankV
Now your question is clear to me ;) Thanks.
What do you think the differences are?
As far as I know the flightcontroller is the same, and there are no differences in firmware of the flightcontroller.
So this version should work well with your furious:)
There are some minor differences if you have a GPS version or the non-gps.
21 Jan 2017 07:40 - 21 Jan 2017 07:45 #58270 by nemo152
I have displayed devo10 display of situation stick. Also has seen that change of trimmers doesn't correspond to changes on the picture and on the kopter. I change Rhrottle trim for an example, on the screen Roll changes, and in a kopter Pitch changes. Why so?
It is my mistake?
It is the author's mistake?
And has to be? What for?
Я вывел на экран devo10 отображение положения stick. И увидел что изменение триммеров не соответствует изменениям на картинке и на самом коптере. На пример я меняю Rhrottle trim, на экране меняется Roll, а в коптере меняется Pitch. Почему так?
Это моя ошибка?
Это ошибка автора?
Так и должно быть? Зачем?
Last edit: 21 Jan 2017 07:45 by nemo152.
21 Jan 2017 14:44 #58279 by FrankV
No, it's no mistake.
Yes, it is mentioned in the manual.
Why? Because it is handy, use it always. When you have to trim on some kind of quad/plane/xxx you can have one hand at the stick, while you can easily use the other hand to trim.
No need for trimming this furious anyway, so why do you ask?
21 Jan 2017 17:37 #58288 by nemo152
I badly know English and I not always understand a sense of words. Please explain why trimmers are quite so set up. Use the simplest phrases and expressions
21 Jan 2017 23:12 #58292 by FrankV
Oke,
in short: it is easy to use.
21 Jun 2017 06:56 #63069 by sn8keyz
Hello...
I have a Furious 320(G) GPS with a Devo10.
I was hoping to upgrade to deviation,but could not find a converted model for my setup. Is this file still available for download?
Are there any bugs that I need to be aware of?
21 Jun 2017 08:31 #63070 by FrankV
I dont understand your question. Ever tried to download the files of the first post in this thread and read the few following posts?
21 Jun 2017 09:09 - 21 Jun 2017 09:13 #63072 by nemo152
Insertion of the FURIOUS 320G model for DEVO 10 apparvtura with deviation insertion, on the basis of FrankV-https://www.deviationtx.com/forum/model-configs/6354-walkera-furious-320-g-setup-file-gps-version#53604.
The made changes:
- the arrangement of trimmers and their display on the screen on standard is corrected (at FrankV they settle down on another, it is so more convenient to him)
- change of expenses of Elevator, Aileron, Rudder is joint and it is postponed for one toggle-switch - "ELEV D/R"
- the AILE D/R toggle-switch includes the additional flight mode
- instead of the picture of a multikopter display of a condition of levels on 7 channels of the 320th is displayed
- display on the screen of percent of level of gas is increased and the arrangement of other elements is changed, small additions are made.
the complex problem of display on the record inclusion mode panel is solved. On the right the timer which counts record time is inserted.
Several small improvements are made.
The camera turns on LTRIM +, LTRIM is switched off-.
But I would change ARM, so it isn't pleasant to me.
The insertion is working, it was written by my companion. We from Russia.
The link to file with the yadi.sk/i/DfN2gHoz3Dwhgt settings
Excuse for my English
Here a forum in Russia forum.rcdesign.ru/f135/thread441959.html
Last edit: 21 Jun 2017 09:13 by nemo152.
21 Jun 2017 11:55 #63074 by sn8keyz
hello FrankV & Nemo152.
Thank you for sharing your work.
i will update my devo10 to deviation tonight, then try the config file for the furious 320 in the next couple of days.
what is additional flight mode?
21 Jun 2017 12:11 - 21 Jun 2017 12:20 #63075 by nemo152
translation error
MIX - 3 flight mode + 1 flight mode AILE D/R = 4flight mode
The 4th mode should be chosen in FlyConfig
example
MIX
1 - Stabilize
2 - Loiter
3 - Drift
AILE D/R - RTL
How to make ARM on the switch?
who can make?
Last edit: 21 Jun 2017 12:20 by nemo152.
21 Jun 2017 13:39 #63076 by sn8keyz
check your 320 manual. it should have the letter beside name - Furious 320 ( G).
im not sure if there is an M version. maybe ask brian on the walkera forums.
I have the furious 320 (G) GPS and am going to try to install the deviation firmware on my devo10, then the ini file....i will post my results in thr next couple of days.
Time to create page: 0.219 seconds
