Eachine E010 ini Devo 7E
- Alias_Hendrik
10 Sep 2016 21:49 #53773
by Alias_Hendrik
Eachine E010 ini Devo 7E was created by Alias_Hendrik
Here is my ini for the Eachine E010 with the Devo 7E.
Low / high rates is on "Fmod" switch.
Flip function is at the "Hold" switch.
Headless / RTH is at the left horizontal trim button.
If needed you can alter the ch3 throttle curve to your liking.
- Newman
12 Sep 2016 12:33 #53812
by Newman
Replied by Newman on topic Eachine E010 ini Devo 7E
Thanks a lot Alias_Hendrik I have a Devo 7E with the NRF24L01 added but just standard switches. So this looks to be set up for just that TX is it?
- Alias_Hendrik
12 Sep 2016 18:25 #53821
by Alias_Hendrik
Replied by Alias_Hendrik on topic Eachine E010 ini Devo 7E
Yes it is. Although i have added 2 x 3 way switches on my 7E i made the ini for the standard switches
- Newman
13 Sep 2016 00:33 - 14 Sep 2016 14:08 #53828
by Newman
Thanks a lot for posting that Alias_Hendrik, I flashed the correct firmware and used your model file and am now off the dinky TX
3am test flight
A quick inside and outside FPV test
3am test flight
Last edit: 14 Sep 2016 14:08 by Newman. Reason: Additional info
- Stomatopod
23 Sep 2016 02:36 #54142
by Stomatopod
Replied by Stomatopod on topic Eachine E010 ini Devo 7E
Newman,
How long have your flights been with your setup?
Cheers,
-G
Cheers,
-G
- Newman
23 Sep 2016 03:46 - 23 Sep 2016 03:47 #54146
by Newman
Hi G,
To be honest I could not tell you because although that is so much fun I have put that project on hold for a while as other projects require attention Alias_Hendrik has done some great work here.
www.rcgroups.com/forums/showthread.php?t=2739812#post35726587
Trim two of the arms off each prop for a start
Last edit: 23 Sep 2016 03:47 by Newman.
- kaligola
08 Oct 2016 07:56 #54709
by kaligola
Replied by kaligola on topic Eachine E010 ini Devo 7E
have control of this little thing with my davo 7e thanks but with yaw problems , keep turning left and trim is used by headless mode.
- epilot
08 Oct 2016 10:39 #54712
by epilot
Replied by epilot on topic Eachine E010 ini Devo 7E
Try doing a stick calibration on the TX
- kaligola
08 Oct 2016 10:48 #54713
by kaligola
thanks, i did once before load that model, i suppose next time i load a new one must redo
thanks a lot.
next step: spare batteries, great
thanks a lot.
- nitram509
05 Nov 2016 23:15 #55730
by nitram509
Replied by nitram509 on topic Eachine E010 ini Devo 7E
Thank you for sharing you configuration. Works well.
There is one thing I experience, where I would like to know, how it works for you.
When I fly E010 with Devo E7, it flys very shaky. A simple throttling to just lift straight up is quiet difficult.
When I switch to the 'original' childish cheap remote its again simple, just throttling and E010 lifts straight up. Again with Devo it drifts / shifts.
Did anybody experience similar behavior?
(any feedback is welcome)
Regards
Martin
Regards
Martin
- nitram509
06 Nov 2016 19:34 #55753
by nitram509
Found the answer own my own... I forgot to calibrate the sticks
(shame on me)
Thanks everybody for reading.
- Luis
20 Nov 2016 20:26 #56103
by Luis
Replied by Luis on topic Eachine E010 ini Devo 7E
Hi everybody,
I'm trying to get controlled my E010 with my DEVO-7E, but I don't get it and I don't know where is my error (I'm sure it's my fault).
I have installed a NRF24L01 and I have tested it's working (I'm using this module from Deviation v3). I have flashed the firmware with the version 5.0.0 of Deviation (I have also tryed with different Nightly Builds), and the MJXQ protocol doesn't appears on my transmitter to can be select. (The MJXQ protocol appears in the "protocol" folder of my transmiter, but not when I want to select it in the transmiter).
Does anybody have any idea about what is the problem???
If you need any other information to can help me, please just let me know.
Many thanks in advande to everybody for your help.
- Newman
20 Nov 2016 20:53 #56104
by Newman
Luis have you enabled the NRF24L01 module in your hardware.ini?
See here - www.deviationtx.com/wiki/rf_module_insta...ion/enabling_modules
- Luis
20 Nov 2016 21:42 #56107
by Luis
Yes Newman, I did it.
But I'm doing now some test more and I have seen my transmiter is not working at all with this firmware. I have tryed with other models I have at home (V977, Ladybird, Hubsan X4, and some more) and no one of them get linked.
Then, I have tryed to downgrade to Deviation v4.0.1, and now all of them are getting linked and fly properly.
Can u understand this
. I'm getting crazy.
HELP!!!
HELP!!!
- Newman
20 Nov 2016 21:58 #56111
by Newman
Not sure how you wired the module up but this is how I did mine if that helps
- Luis
20 Nov 2016 23:43 #56115
by Luis
Many thanks Newman. I have it wired up in the same way as you did and both modules are properly working with Deviation v4.0.1, but they don't work with Deviation 5.0.0 and that looks very strange.
Sometimes (but not always) with Deviation v5.0.0 when I turn my DEVO-7E on, it says to me "bad module instalation". But I have it tested several times and the modules are intalled correctly.
I don't understand anything.
Do u know if it should be possible to run the MJXQ protocol with Deviation 4.0.1? And if so, how could I do it?
- Newman
20 Nov 2016 23:50 - 20 Nov 2016 23:52 #56116
by Newman
When I first did my module and test for the Eachine E010, I flashed the nightly build from memory. Do you have any other quads that use the NRF24L01 module because you could see if they work with your setup.
Last edit: 20 Nov 2016 23:52 by Newman.
21 Nov 2016 05:12 #56121
Replied by hexfet on topic Eachine E010 ini Devo 7E
Did you do a full install of 5.0 including all the USB files? You can save the 4.01 models and icons and restore them after the install.
- Luis
21 Nov 2016 21:05 #56149
by Luis
Hi all, in fact I have made a full install of 5.0.0 and I have tryed to load the old models from the 4.0.1 after the install and also I have tryed to create a new one from "0", but nothing. I did the installation as always I did it from v2 to v3, v3 to v4, and now from v4 to v5.
I have some other models using the NFR24L01 and they doesn't work, but they doesn't work the models using the NFR24L01 nor using the A7105 nor using the CYRF6936. The transmiter is just not working, but when I downgrade to the 4.0.1 all of them works properly.
I let you my hardware.ini and an image from the transmiter folder. Please let me know if you see something estrange.
- Luis
01 Dec 2016 21:24 #56419
by Luis
Well, I did install deviation 5.0.0 some more times and at the end now is working properly, but I don't really know what was the problem because I tryed with Dfuse from Walkera and also with Deviation Upload several times.
Any case, now it's working
, and I'm happy.
Many thanks to everybody for your help and ideas.
Time to create page: 0.148 seconds
Model Configs
- Eachine E010 ini Devo 7E
