Devo7E channels config
11 Mar 2017 13:06 #60125 by cimbolino
Devo7E channels config was created by cimbolino
Hello boys !
I need your help, someone help me please.
My updated Devo7E with Deviation firmware and 2x3 extra sw and nRF24L01 module works !
But.... I don't understand how may I config the extra fly controls as photo, video, headless, rth (when availables on drone)
CH7, CH8, CH9, CH10 and how control its.
Someone kindly give me detailed explanations please.
Many thanks in advance
Have a nice weekand
12 Mar 2017 13:25 #60148 by mwm
Replied by mwm on topic Devo7E channels config
You can't do it with the standard GUI. So the detailed description for something as broad as you asked is:
Step 1: switch to the Advanced GUI.
Step 2: Read the manual chapter for the advanced GUI
Step 3: Read my tutorial on writing advanced GUI models .
After you do that, if you have specific questions about getting channels to do things, please feel free to ask them.
14 Mar 2017 11:12 #60183 by cimbolino
Replied by cimbolino on topic Devo7E channels config
Hello !
Many thanks for your kind reply and links !
Now I've config for extra controls and works well !
If you please I tell youanother problem about supported models :
Original TX of the DM007 also bind the GW007, only inverted directions (ALE), but bind, Why the Devo7E bind only DM007 (?)
May you help me also this time ?
Thanks in advance
Kind Regards
14 Mar 2017 18:11 #60192 by mwm
Did you try the GW007 and it didn't work? Or are you assuming it won't work because the GW007 isn't on the supported models list? That's a bad assumption; not being on the list just means that nobody has said it works, which could be for a number of reasons other than it not working.
If you tried it and it doesn't work, that's probably because the GW007 needs something from the Tx that the DM007 doesn't. Since our code is based on the DM007 whoever did the code either didn't see those things, or didn't see the need to add them. In this case, you'll need to get a logic analyzer on the Tx and capture the data transfers during a bind for analysis. And someone to do the analysis and modify the code accordingly.
15 Mar 2017 12:23 #60215 by cimbolino
Yes friend, I try and also with different secondary protocols. doesn't work .
Unfortunately I haven't possibility to get tx analysis and (I think) would be hard for me modify the code.
Maybe in the future this GW007 will be add to model list.
Carpe diem !
Time to create page: 0.114 seconds
