E011 Deviation (Jumper T8SG)
21 Nov 2017 21:54 #66031 by J.B.
E011 Deviation (Jumper T8SG) was created by J.B.
I configurated a Model for E011, Bayang Protocol, and set 1 channel for Flips;
Now, i tried other channels to find one that correspond to 2 Speeds of the original controller, not founding it..!
But, more important thing... i don't know why, with max throttle, it not have same Punch of the original controller!!
Seems to 80% hoveer and there isn't enough more to punch out..!!
With original controller no problem like this!
There is something to configurate in throttle settings..? Seem a different scale, i don't know!
23 Nov 2017 00:52 #66080 by Deal57
Replied by Deal57 on topic E011 Deviation (Jumper T8SG)
Maybe post your model.ini file and we can see what it's doing. Most protocols are built with the high rate at 100%, so scaling back is easy. You can also scale up if you like, maybe to 125% to see if that helps.
06 Jan 2018 20:40 - 06 Jan 2018 20:41 #66746 by J.B.
Replied by J.B. on topic E011 Deviation (Jumper T8SG)
Hello, i tried all settings possible.. Scale to 125%, Expo, all.
With TSG8, at full throttle, with E011 Board, Motors spin less fast that full throttle with Stock controller, so i have less punch.
i don't know what i can yet do, it's strange anyone haven't this problem..!
I know that, even with other protocols and betaflight, at first time connect, the throttle value is always less of FC ( example, max throttle is 1950 of TSG8 instead 2000 of betaflight), but, in betaflight you can assign different value from CLI to have correct range..!
With e011 board can't, and i think it's the problem.
Last edit: 06 Jan 2018 20:41 by J.B..
28 Jan 2018 08:25 #67228 by Kahless
Replied by Kahless on topic E011 Deviation (Jumper T8SG)
Yes, I noticed this as well, very disappointing not to have full throttle, even with new acro mode firmware flashed, the throttle is still low, looking forward to any possible solution!
09 Feb 2018 21:10 #67453 by Danimendi
Replied by Danimendi on topic E011 Deviation (Jumper T8SG)
I wanted to use it to sail. In the sailboats the throttle stick sets the sails aperture but I can not fix the end points. It seems that the "scale" function does not work at all. The course is too short. The same problem with the rudder (ailerons stick). Any advice is welcome!
13 Feb 2018 23:34 - 13 Feb 2018 23:34 #67501 by Wene001
Replied by Wene001 on topic E011 Deviation (Jumper T8SG)
is the channel monitor showing 100 percent output?
Sticks calibrated?
Last edit: 13 Feb 2018 23:34 by Wene001.
14 Feb 2018 08:19 #67513 by Danimendi
Thank you for your reply. Yes, sticks calibrated and 100% in the monitor. I need at least 130/140% to properly set the sails... as I do with Futaba and Turnigy i6
22 Feb 2018 20:22 #67700 by Danimendi
I finally fixed the issue creating a new model as helicopter. This way the Standard Gui is enabled and the Travel Adjust perfectly works. Don't ask me why...
07 Mar 2018 20:29 #67962 by J.B.
Oh, can you explain it better?
i never used standard gui, what's Travel adjust..?
07 Mar 2018 21:42 #67964 by Danimendi
Travel adjust is the same as "scale" in the advanced gui. In travel adjust you can set the end points of the servos course. Only the helicopter mode enables the standard gui.
12 Mar 2018 02:28 #68017 by J.B.
tomorrow i will try, thank you very much!
11 Jun 2018 17:55 #69611 by Bern
Replied by Bern on topic E011 Deviation (Jumper T8SG)
Hi, I'm new here... just installed deviation 5.1 on a devo6S with the required additional NRF24L01 module for Bayang protocol. My E011c (H67) and B03 are flying perfectly but I have the same throttle problem!
Did anyone find a solution? Punch-out test is significantly less compared with the little stock remote.
To be confirmed, I have even the feeling that when moving full speed forward, there is not enough throttle to keep the E011 at the same height.
Best regards,
Bern
10 Aug 2018 18:24 #70206 by sfjuocekr
Replied by sfjuocekr on topic E011 Deviation (Jumper T8SG)
I have flown a few E01x, but never had this throttle issue.
There is a reduced throttle mode on the normal toy transmitter if you hold the right stick pressed, is that the same limit you get using the T8SG?
If yes, maybe one of the other channels needs its value changed. I know one channel makes flips active, I've got another setup but it doesn't seem to do much...
Time to create page: 0.118 seconds
