Separate airbrakes ailerons and Virtual Channels.
30 Mar 2019 08:13 #73611 by saidem
I saw on one answer that the best solution to create separate channels for the ailerons was to go through virtual channels. Could you tell me where to find a model with the airbrakes on the ailerons because I don't know how to do it?
Thank you very much.
01 Apr 2019 15:45 #73662 by hexfet
I didn't find such a model with searching. I think you'd want to add some negative to both ailerons based on a switch? The idea would be to create a virtual channel that produces either 0 or a negative value based on a switch. Then add that to the aileron mixers.
To do that create a virtual channel with fixed curve that produces 0 when switch is off and negative value (adjusted with Scale setting) when switch is on. Then in your aileron mixers add the virtual channel as the last page in the mixer.
Time to create page: 0.304 seconds
