Jumper T8SG Plus(Carbon) problem. Help ((
12 May 2020 13:42 - 12 May 2020 13:55 #76303 by pirlimb
Hello everyone) I ask you to help me.
I have 4 quadrocopters and Frsky r9m + and TBS Crossfire Nano RX receivers are installed on them
They are all connected with the Jumper T8SG Plus - this can be seen from the light bulbs of the receivers and the equipment itself.
In the Betaflight Configurator, I set everything up correctly, it seems.
The PROBLEM is that the motors do not react to the movement of the sticks on any quadrocopter, and in the Betaflight Configurator in the "receiver" section there are also no movements (((
Please tell me any solutions to this problem.
Last edit: 12 May 2020 13:55 by pirlimb. Reason: Ошибка
15 May 2020 10:44 #76313 by pirlimb
Replied by pirlimb on topic Jumper T8SG Plus(Carbon) problem. Help ((
Maybe some suggestions? And then I have no options left
29 May 2020 21:45 #76375 by Gilles17
Replied by Gilles17 on topic Jumper T8SG Plus(Carbon) problem. Help ((
Bonjour, moi j’avais un problème car les gaz dans Betaflight étaient en dessous de 1000 et quand la manette était tout en bas rien ne marchait mais si je la montais un peu c’était ok. Donc j’ai modifié la course pour être à mille. Ton problème est peut-être identique
30 May 2020 03:45 #76377 by pirlimb
Thank you very much for your advice) today I’ll try
31 May 2020 10:21 #76392 by pirlimb
I tried today. Did not help
31 May 2020 12:02 #76393 by Gilles17
did you try to just raise your throttle a little? to see if the other channels were responding. otherwise it may be from the configuration tab. for the receiver if it is a receiver integrated into the card you have to put spi-something (sorry but I don't know frsky well). otherwise there are differences between frsky EU and international. maybe you should look this side
31 May 2020 12:39 #76394 by pirlimb
Hey. I have iflight SucceX F4 ( shop.iflight-rc.com/index.php?route=prod...th=18&product_id=848 ) and RX Frsky XM + nano. Connected via SBUS. Do you have a Telegram? I have difficulty with the language barrier. It would be easier for me to explain using photo and video reports.
31 May 2020 13:14 #76395 by Gilles17
sorry for the language, i'm french and i use a translator. I'm not good enough with this radio (I have had it for 1 month). in betaflight, on the configuration page you must put spi-rx for the mode and FRSKY_D or FRSKY_X for the receiver. it's for the all-in-one controller. I can't help you much more, others are much more gifted
31 May 2020 13:17 #76396 by Gilles17
for RX FRSKY Sbus. I think we should try this
31 May 2020 14:10 #76397 by pirlimb
Thank you for helping me! I just tried it. No reaction! ((in the photo my configurations - maybe fix me!
31 May 2020 14:47 #76398 by Gilles17
sorry, i don't understand russian. and I don’t know enough to help you. I think there are more qualified people on the forum than me. you should try to ask your question in another section. there will be someone better than me to help you
31 May 2020 15:02 #76399 by pirlimb
Peut-être connaissez-vous quelqu'un vers qui vous pouvez vous tourner? ou dans quelle section devez-vous poser cette question? Je vous remercie!
31 May 2020 23:53 #76402 by bruce
Replied by bruce on topic Jumper T8SG Plus(Carbon) problem. Help ((
Don't read Russian sorry
I have a T8SGV2 plus and have recenty configured a crossfire nano that is working.
1) Bind the receiver (which is sounds like you have done - the receiver light will be solid green when the radio is turned on)
2) Wire the receiver to the flight controller. Look at the quick start guide for Crossfire nano, 5V, ground, Channel 1 and Channel 2 on the Crossfire go to the FC, Channel 1 and Channel 2 go to a TX and an RX. Look here for the connection
3) In Betaflight configurator ports tab, assign serial rx to the UART you connecged the cossfire to
4) In configuration tab, Specify serial, and below that select CRSF
5) Go to Receiver tab, you should see the bars responding to the stick movement
04 Jun 2020 11:48 #76420 by pirlimb
Всё сделал. Не сработало
04 Jun 2020 18:42 #76421 by Волошин
Replied by Волошин on topic Jumper T8SG Plus(Carbon) problem. Help ((
I had this experience when the receiver binds to the equipment, but the drone does not see it. I decided this way - on the flight controller there are other places for soldering ( I have rx1, r 2, and so on), I removed the signal wire from the receiver( it is yellow) from the common plug and soldered it there; in Bitefight, in the "port" section, I put that my receiver is on uart2( since I soldered it to rx2) and everything worked)))
08 Jun 2020 04:15 #76437 by pirlimb
It didn’t help ((I think the reason is to hide in the equipment! No drone reacts to the movement of the sticks, but they are all connected with the equipment.
Maybe you need to configure something in the equipment itself?
Time to create page: 0.215 seconds
