Jumper T8sg Pitch/Throttle curves
26 Dec 2020 03:21 #77137 by Maturecruiser
Jumper T8sg Pitch/Throttle curves was created by Maturecruiser
I am setting up a couple of helis from the template. This is my first couple of goes. When using the Advanced GUI, how do I get to pitch and throttle curves, I can set the DR/Expo Ok but just not sure of the buttom/scroll sequence to get to the necessary screen.
So then I tried the Standard GUI, It is certainly more like Spektrum that I am familiar with. However I then get stuck as I feel the channel assignment is incorrect.
I would prefer to do this in the Tx rather than via a word processor.
The helis I am starting on are XK K110. I have downloaded and ini file from here but I wasn't totally happy with that either.
I have searched the forum as best I can but no joy.
26 Dec 2020 08:30 #77138 by Fernandez
26 Dec 2020 14:13 #77139 by Maturecruiser
Replied by Maturecruiser on topic Jumper T8sg Pitch/Throttle curves
Thanks, I have the manual but its doing my head in.
26 Dec 2020 18:13 #77140 by gdenton
Replied by gdenton on topic Jumper T8sg Pitch/Throttle curves
What exactly are you having trouble doing?
I don't have a T8sg but this is how to change a curve on a Devo 6S TX using the Advanced GUI:
On the Throttle or Pitch channel Mixer page scroll down to 'Curve', change to '5 point' using the left/right buttons, then press 'ENT' to get to the curve editor page.
I have a really simple K110 setup you might find useful, but again this is for a Devo 6S so you would need to change the switches specified in channel 3 (throttle disable) and channel 5 (autolevel/acro).
name=H K110
mixermode=Advanced
[radio]
protocol=S-FHSS
num_channels=8
fixed_id=203389
tx_power=100mW
[protocol_opts]
Freq-Fine=0
Freq-Coarse=0
[channel1]
template=expo_dr
[mixer]
src=AIL
dest=Ch1
curvetype=expo
points=20,20
[channel2]
template=expo_dr
[mixer]
src=ELE
dest=Ch2
curvetype=expo
points=20,20
[channel3]
safetysw=MIX0
safetyval=-100
template=expo_dr
[mixer]
src=THR
dest=Ch3
curvetype=5point
points=-100,0,100,100,100
[channel4]
template=simple
[mixer]
src=RUD
dest=Ch4
scalar=125
[channel5]
template=simple
[mixer]
src=GEAR0
dest=Ch5
curvetype=expo
points=0,0
[channel6]
template=expo_dr
[mixer]
src=THR
dest=Ch6
curvetype=5point
points=-20,-10,0,25,50
27 Dec 2020 00:42 #77142 by Maturecruiser
Thanks gdenton. As I play mainly with helis, I was trying to use the Standard settings via the Tx not a word processor. The template for helis appears to be different than the AETR setup I need. So I wanted to rearrange channels. That only seems possible via advanced. Seriously I cant even get to the Hold R+ ???.
I am a bit old BUT?
27 Dec 2020 04:17 #77143 by Maturecruiser
I have started from scratch again. And the reset on the Tx states AETR but its not. I just need to play with this setting preferably in Standard GUI. Aileron works the front and LHS servo. And Elevator seems to work Left & Right. Swash is correct, all up and all down.
29 Dec 2020 07:31 #77147 by Maturecruiser
Downloaded an ini file from here and the servos are all Ok and so is the swash. I know how to setup DR/Expo and I think thats done. Also Hold.
So any help with a walk thru for Normal/Idle up 1/Idle up 2. and pitch curves.
I think I can get into the throttle curves but cant get them to save??? I want 3 curves for throttle.
Any help???
Time to create page: 0.079 seconds
