Pixhawk/APM 6 Flight modes and voice -12 Channels.
31 Aug 2022 07:47 - 02 Sep 2022 21:46 #78068 by McGyver
Model was made for DEVO10 - I use full set of 12 channels. Config works good on Pixhawk and APM. I use some other set of MIX and AIL DR switches to get 6 Flight modes.
MIX0-AILDR0 FM1
MIX1-AILDR0 FM2
MIX2-AILDR0 FM3
MIX2-AILDR1 FM4
MIX1-AILDR1 FM5
MIX0-AILDR1 FM6
FM1 - In most cases is Stabilize
FM6 - RTL
That setup gives really easy changes between flight modes without too many shifting switches, and is quite straight. I didn't find anyone use setup like that before (or I didn't found it anywhere).Voice works correct for all flight modes, Last switch for Ch12 is one of unused trims and controls camera trigger.
File Attachment:
File Name: model3_2022-09-02.ini
File Size:14 KB
Last edit: 02 Sep 2022 21:46 by McGyver.
Time to create page: 0.028 seconds
