Icone transparent / transparent icon
- Franck
- Pixel166
11 May 2013 21:08 #9878
by Pixel166
Replied by Pixel166 on topic Icone transparent / transparent icon
Icons used in deviation are bitmap, and as I know, it doesn't support transparency.
So you need to create 1 icon for each background you will use on Deviation
Warning: Spoiler!
[ Click to expand ]
[ Click to hide ]
Les icones utilisées dans le firmware Deviation sont des bitmap qui ne supportent pas la transparence
Warning: Spoiler!
[ Click to expand ]
[ Click to hide ]
Donc tu dois faire une icone pour chaque fond d'écran que tu utiliseras sur Deviation
11 May 2013 21:10 #9880
Replied by FDR on topic Icone transparent / transparent icon
Actually we do support transparency if you use the ARGB1555 format...
12 May 2013 07:40 #9885
Replied by rbe2012 on topic Icone transparent / transparent icon
Transparency is no magic and supported from the beginning of deviation. Take a look at this thread:
Instructions for making model icons
- Franck
12 May 2013 10:19 #9890
by Franck
Replied by Franck on topic Icone transparent / transparent icon
With GIMP is OK !! Thank
- Pixel166
12 May 2013 21:13 #9902
by Pixel166
Sorry for the mistake..
Seeing all the different icons for one single model on different backgrounds make me think it wasn't supported.
13 May 2013 04:17 #9910
It is because only full transparency is supported, i.e. a pixel is whether completely transparent or completely opaque, which makes hard to draw a shadow (or a nice contour for the matter), so some people draw icons that blend into the standard background instead...
Time to create page: 1.108 seconds
Model Icons
- Icone transparent / transparent icon
