Req: Hisky HCP 100/ V922 model ini for nrf24l01
05 Apr 2014 21:54 #22157 by Bollis
Hi, I search for a model ini file for the Hisky HCP 100/ V922 model. I have a devo 10 with the nrf24l01+ module soldered ini tx.
Best regards Tom
05 Apr 2014 22:53 - 05 Apr 2014 22:55 #22159 by blackmoon
Replied by blackmoon on topic Req: Hisky HCP 100/ V922 model ini for nrf24l01
www.deviationtx.com/forum/model-configs/...-swash-custom-layout
Just adapt the switches to correspond to your Devo10, and it's a standard mixer setup from HappyHarry.
Enjoy! :D
Last edit: 05 Apr 2014 22:55 by blackmoon.
03 Aug 2014 04:42 #24986 by mugen0001
Replied by mugen0001 on topic Req: Hisky HCP 100/ V922 model ini for nrf24l01
if i want to use this config with "Hisky HFP80 V2" for Devo8S , can to use it?
thanks .,
03 Aug 2014 21:45 #25003 by blackmoon
No, this is for a CP heli, your's is a FP. For the HFP80 V1/V2 a simple 4 channels model file is enough.
Search the models sub-forum for the HFP100 or the HFP80.
05 Aug 2014 09:40 #25025 by mugen0001
blackmoon wrote: No, this is for a CP heli, your's is a FP. For the HFP80 V1/V2 a simple 4 channels model file is enough.
i can't see from this web . can u help me ?
thanks
05 Aug 2014 11:29 - 05 Aug 2014 11:30 #25027 by blackmoon
I don't seem to find a config here... :(
Anyway, try this one from rcgroups, it was one from MassiveOverkill for the FBL70, which became the HFP80 (its the same helicopter only name changed).
You can use it also with he HFP100, only thing you have to adapt the rates and expo to your liking.
Pay also attention to the channels direction, maybe some need to be reversed for the HFP100, as I don't own one I can't help there.
www.rcgroups.com/forums/showpost.php?p=26615162
Last edit: 05 Aug 2014 11:30 by blackmoon.
06 Aug 2014 07:51 #25058 by mugen0001
blackmoon wrote: I don't seem to find a config here... :(
Thanks you; :)
06 Aug 2014 19:08 #25060 by mugen0001
anybody help me?
please help me.
now i use config from www.rcgroups.com/forums/showpost.php?p=26615162
it can pair with hfp80 but when it binded to my devo8s , blade is spinning immediately . trottle is in normalposition
06 Aug 2014 22:25 #25067 by blackmoon
Reverse throttle channel.
07 Aug 2014 03:24 #25069 by mugen0001
blackmoon wrote: Reverse throttle channel.
Help me please
i don't know how to change config "Reverse throttle channel"
i attatched "my config" .
can you hlpe me please?
thank you
File Attachment:
File Name: model11.ini
File Size:4 KB
07 Aug 2014 06:04 - 07 Aug 2014 06:05 #25070 by blackmoon
You just add reverse=1 to the channel you want, in this case channel 3.
I recommend you read carefully the deviation manual. :)
Anyway, this is the modified model file :
File Attachment:
File Size:1 KB
Last edit: 07 Aug 2014 06:05 by blackmoon.
07 Aug 2014 07:28 #25071 by mugen0001
blackmoon wrote: You just add reverse=1 to the channel you want, in this case channel 3.
File Attachment:
File Size:1 KB
thank you very much , i will test at tonight.
07 Aug 2014 18:01 #25076 by mugen0001
now i test with my HFP80 ,it don't work .
in left stick (throttle) when i push up => nothing , push down => only tail rotor spin ,and main rotor not spin
07 Aug 2014 19:10 #25079 by blackmoon
OK lets continue in PM, we are way out of topic here.
11 Apr 2017 08:53 #61374 by DeAdOne
This file for the hcp100 should work for the
hcp 80 version 1? In Devo 10 with new 4in1
Time to create page: 0.202 seconds
