blade 350 qx version 2
03 Jun 2014 10:25 #23874 by southtirol32
blade 350 qx version 2 was created by southtirol32
hi i search a model ini for the blade 350 qx firmware 2, i have a devo 7e whit 2*2 switch, i search a model, with motor off, 4 flymode, and dual rates,and telemetry, when supported
thank you
30 Aug 2014 07:43 #25426 by pweber
Replied by pweber on topic blade 350 qx version 2
do you get an answer, i search an ini File too
31 Aug 2014 20:43 #25442 by jesmail
Replied by jesmail on topic blade 350 qx version 2
Here you go....
Be careful, I put the arm and disarm on a switch. Not sure if that is a good idea. Had one friend hit it to disarm while in the air.
All 4 flight modes are implemented.
30 Aug 2016 07:21 #53259 by Mick1113
Replied by Mick1113 on topic blade 350 qx version 2
Hello and thanks for the file. In which switch did you assigned the disarm?
30 Aug 2016 11:55 #53275 by jesmail
Rudder D/R is the ARM/DISARM switch.
Time to create page: 0.473 seconds
