Syma X5SC Headless
18 Apr 2015 22:38 #31340 by 30secs
Syma X5SC Headless was created by 30secs
Can someone share their Syma X5SC headless config? Not sure what channels is are what. Thanks!
18 Apr 2015 22:48 #31341 by hexfet
Replied by hexfet on topic Syma X5SC Headless
You'll need the nightly from April 3 or later.
Channel 6: flip enable
7: take picture
8: start/stop video
9: headless mode
20 Apr 2015 02:19 #31391 by 30secs
Replied by 30secs on topic Syma X5SC Headless
thanks hexfet! Is there a place that i can keep track of these updates? I also have a JJRC (v202) quad with headless and wonder if there's a working update/channel for it?
20 Apr 2015 14:47 - 20 Apr 2015 14:48 #31422 by hexfet
The forums here will have the latest news (the Recent Posts tab and Last Post links are helpful).
The list of merged pull requests will show most of what's going into the nightly builds. The commit list has all the details.
On the merged pull list is "#51: V202: add headless handling, 250kbps mode."
Last edit: 20 Apr 2015 14:48 by hexfet.
25 Apr 2015 20:08 #31617 by 30secs
Do you use/recommend the 250kbps mode? i tried it on the v202 for jjrc but it wouldn't work when that was enabled.
25 Apr 2015 20:30 #31619 by SeByDocKy
Replied by SeByDocKy on topic Syma X5SC Headless
30secs wrote: Do you use/recommend the 250kbps mode? i tried it on the v202 for jjrc but it wouldn't work when that was enabled.
The 250Kbits is only for Bradwii application :
www.rcgroups.com/forums/showthread.php?t=2278850
26 Apr 2015 04:33 #31630 by 30secs
Does the Bradwii have any effect or benefits for quads like the Syma x5c/x11?
08 May 2015 21:05 - 08 May 2015 21:07 #32269 by cfl246tho
Replied by cfl246tho on topic Syma X5SC Headless
30secs wrote: Can someone share their Syma X5SC headless config? Not sure what channels is are what. Thanks!
the X11 configuration might work. If someone has an X5 configuration to post, I'd suggest posting one level up, in the X5 thread I started. I'd like to see how folks switch 4 or 5 things on the 7E. I use the THOLD switch for the flips, and the FMODE switch for two speed ranges, but don't know how to also toggle channels 7 and 8 for the camera. The answer should be applicable up on the X11C configuration
Quads: Syma X5, X11, X12; LishiToys L6052; NiHui U207, CG023; H7/SpaceTrek M9912; BayangToys X7; UDI U839/939; WLtoys V676; Cheerson CX205
Last edit: 08 May 2015 21:07 by cfl246tho.
Time to create page: 0.061 seconds
