Devo 10 4.0.1 & Blade Inductrix Setup
09 Jun 2016 02:57 #50225 by caughron01
Devo 10 4.0.1 & Blade Inductrix Setup was created by caughron01
I just received my Devo 10 today and it is running Deviation Devo 10 4.0.1 I am hoping someone can help me get my Blade Inductrix linked to my TX. Thank You
09 Jun 2016 21:36 #50279 by mwm
Replied by mwm on topic Devo 10 4.0.1 & Blade Inductrix Setup
The blade uses DSMx or DSM2. I believe there are model.ini files available in the forums if you search for them. But use a google search ( www.google.com/search?q=url%3Adeviationt...ceid=chrome&ie=UTF-8 ) instead of the site search.
Also, update to 5.0.
09 Jun 2016 21:54 #50281 by caughron01
Replied by caughron01 on topic Devo 10 4.0.1 & Blade Inductrix Setup
I was able to get a correct dsmx file from another user and got it connected and flying. If I update to 5.0 do I need to backup all of my files? Does it erase everything when updating? Thanks for the reply.
09 Jun 2016 23:02 - 09 Jun 2016 23:08 #50286 by Arnold
Replied by Arnold on topic Devo 10 4.0.1 & Blade Inductrix Setup
caughron01 wrote: ... If I update to 5.0 do I need to backup all of my files?
Yes, backup anything you don't want to lose.
Does it erase everything when updating? ...
Yes, installation replaces everything on your transmitter.
... Unless you use the Devation Uploader 0.8.0 tool, in which case you may be able to protect those items you do not wish to overwrite ...
Last edit: 09 Jun 2016 23:08 by Arnold.
12 Jun 2016 22:06 #50491 by caughron01
Just curious what would be the benefit going to 5.0? Thanks sorry for the stupid question, just want to see if there is a real benefit to upgrading.
13 Jun 2016 01:56 #50516 by mwm
What are you upgrading from?
There are lots of new features, protocols and bug fixes compared to 4.0.1. It's seriously to long to list.
If you're running a nightly from this year, then it's mostly bug fixes and more protocols. If you have an issue, going to 5.0 will be the first thing your'e asked to do before anyone looks at it.
14 Jun 2016 00:12 #50570 by caughron01
Well I am 4.0.1 I went to 5 and my screen had a couple of issues, so I went back to 4.0.1. I have been told to re-download and try again so I am working on that now. I really want to get my CX-10 going, but also my Inductrix wouldn't fly either it would bind but no response from the throttle which was weird.
16 Jun 2016 06:28 #50685 by RRacer
Replied by RRacer on topic Devo 10 4.0.1 & Blade Inductrix Setup
You probably got it figured out already, but here's my Inductrix setup anyway.
Devo 10, 4.0.1
Change flight mode by flicking the MIX switch back and forth. Onboard lights will toggle red/blue.
Ch1 - Thr
Scalar 100%, no expo.
Ch2 - Ail
Rate Expo
Fmode0 50% 40%
Fmode1 65% 40%
Fmode2 100% 30%
Ch3 - Ele
Fmode0 70% 40%
Fmode1 85% 40%
Fmode2 100% 40%
Ch4 - Rud
100%, no expo.
Ch6 - Mix
Fixed, +/-100%
/Hugo
17 Jun 2016 00:13 #50730 by caughron01
Thanks so much Racer, just loaded it and testing now. I appreciate it!
Time to create page: 0.203 seconds
