Furibee f3 frsky
22 Feb 2017 14:19 - 22 Feb 2017 14:21 #59457 by jasonlove199450
Furibee f3 frsky was created by jasonlove199450
In need of Furibee f3 frsky model files as when I bind it just doesn't work. It binds but the receiver goes off and never actually fully binds (tried 2 receivers with the same problem). iv been trying for 3 full days now and still having the same problem so thought its just going to be easier to ask on here on. I have the cc2500 installed and seems to work and I'm using deviation-devo7e-v5.0.0-f15939a .. thanks
Last edit: 22 Feb 2017 14:21 by jasonlove199450.
22 Feb 2017 17:22 #59468 by magic_marty
Replied by magic_marty on topic Furibee f3 frsky
Did you try changing the Frequeny range by 10 at a time on the selection page for Frysky? I had to keep changing it to get it to bind also there is a swamping issue with the F3 if you have it to close to the tx with the power set to high it will loose bind until you move it further away from the tx..When binding make sure you have at least 3 feet between the rx and tx..
22 Feb 2017 17:31 #59470 by jasonlove199450
Replied by jasonlove199450 on topic Furibee f3 frsky
Yes I've tried changing the thing by 10 starting at -50 up to +50 . And yes that's what happens it seems to disconnect it's self.. IV also just tried the 3ft away thing and it's still the same
23 Feb 2017 04:50 #59499 by magic_marty
You might try going beyond -50 +50 and see also perhaps the latest nightly build might help...Or see if you can bind it in Cleanflight
23 Feb 2017 13:06 - 23 Feb 2017 13:07 #59520 by jasonlove199450
hey thanks for your help i had to set it to just over- 60 for it to bind. but now i have another problem , im unable to arm as aux 1 and 2 dont work at all and aux 5 seems to be set to 1950 to 1990 as it jumps around there constantly :/ so i cant fly as I'm unable to bind. see photo about what I mean with aux 5
Last edit: 23 Feb 2017 13:07 by jasonlove199450.
23 Feb 2017 17:57 #59533 by magic_marty
it's normal for Aux5 to jump around like that due to the rx being PPM everybody reports theres doing the same as well as mine..Did you set up the switches in the mixer on your radio? You can go to the mode selection in CF and manually set it to Angle mode if you don't want to set up switches on your tx...I think you hold Right on throttle to arm but most setup a switch to arm/disarm
28 Apr 2017 11:18 #61829 by kabo
Replied by kabo on topic Furibee f3 frsky
Which frsky did you use? frsky or frskyx?
both have freq adjustments
Larry
30 Apr 2017 02:06 #61856 by magic_marty
I used frsky and had no luck using the frskyx protocol ..The furibee f3 is really cool cause it sends telemetry back to the tx ..I set a voltage alarm to alert me when my battery gets low
Time to create page: 0.181 seconds
