E-flite convergence vtol
11 Jun 2018 07:41 - 11 Jun 2018 07:58 #69606 by ericart63
E-flite convergence vtol was created by ericart63
Can you help me with a configuration of the model "E-flite Convergence VTOL"
because I am a beginner and I have problems to make it work on a DEVO 8S
thank you in advance
Bonjour,
Pouvez vous m'aider avec une configuration du modèle "E-flite Convergence VTOL"
car je suis débutant et j'ai des problèmes pour le faire fonctionner sur une DEVO 8S
Merci d'avance
Last edit: 11 Jun 2018 07:58 by ericart63. Reason: here is the manual
12 Sep 2018 16:25 #70841 by cody
Replied by cody on topic E-flite convergence vtol
I am currently trying to get it to work.
No success with binding though.
12 Sep 2018 17:39 #70843 by cody
Success!
I used these settings with Devo 7E:
- DSMX protocol
- 6 channels
- 100mW
- Channel 5 bound to HOLD
- Channel 6 bount to FMODE
I dont really remember the binding procedure. Maybe this worked:
- Switch tx off
- Switch plane on, wait until its LED flashes fast red
- Switch tx on, hit bind
- Switch bind off after 3 seconds
- Switch plane on and off, LED should be constantly on. Color depends on the channel 5 switch.
Switches:
- The motor switch(channel 6) should be 100 by default. If you press it, it goes to 0 and should go to 100 on release. The Devo 7E does not have such a switch. You have to switch it on/off by yourself. Otherwise you may encounter strange behavior.
- The flight mode switch(channel 5) should be 3 state but it only has 2 states on Devo 7E. By default you have these flight modes:
- Multirotor mode = 100
- Acro = -100
- Stabilized/Level = 0
So you cant have all flight modes with one mixer setting.
24 May 2020 14:49 #76360 by ericart63
Replied by ericart63 on topic E-flite convergence vtol
Thank you
Time to create page: 0.077 seconds
