Blade Nano QX for Devo 7e please
20 Oct 2018 22:37 - 20 Oct 2018 22:41 #71444 by Peeeter
Blade Nano QX for Devo 7e please was created by Peeeter
I just got my Devo 7e, installed Deviation v5 on it, and want to fly a Blade Nano QX. There are no additional modules installed in the 7e, and I am using DSMX.
I tried this:
www.deviationtx.com/forum/model-configs/2646-blade-nano-qx
The Nano QX binds and flies, but unfortunately I can't get the Stability Mode working.
Could somebody please give me a working model.ini for a Blade Nano QX?
Many thanks
Peter
Last edit: 20 Oct 2018 22:41 by Peeeter.
21 Oct 2018 01:24 - 21 Oct 2018 01:25 #71445 by hexfet
Replied by hexfet on topic Blade Nano QX for Devo 7e please
This is a model file for Devo10. Stability/agility control is on channel 6. A momentary switch is needed for most Blade models. The state is toggled on transition. Don't remember if low-to-high or high-to-low.
This file puts the switch on a trim switch. Might be easier to look at for setting up a momentary switch rather than try to translate this model to 7e.
Last edit: 21 Oct 2018 01:25 by hexfet.
26 Oct 2018 15:06 #71493 by Peeeter
Replied by Peeeter on topic Blade Nano QX for Devo 7e please
Hi hexfet,
many thanks for posting this!
I guess I will have to do some learning to adjust it to the 7e, so I'm going have a look at the tutorial section now. I'm completely new to radio control and to deviation, so it's probably going to take a while. :cheer:
Time to create page: 0.792 seconds
