M80 set up
- Hot_Wheels
30 Jan 2019 16:38 #72626
by Hot_Wheels
M80 set up was created by Hot_Wheels
Does anyone have a setup for m80 on devo 8s by chance? In set my fmod switch to channel 5 made 3 positions via complex mixer however flight controller does not respond to change. I tried to set up my dr0 to arm switch however when activated It goes full throttle. I reversed throttle and it wont arm.
- a10nemesis
27 Oct 2019 19:06 #75327
by a10nemesis
Replied by a10nemesis on topic M80 set up
Did you made the model setup?
I´m looking for the same model.,
- propnut
19 Jun 2020 11:04 #76502
by propnut
Replied by propnut on topic M80 set up
From my T8Sg using an FrSky reciver
name=M80
mixermode=Advanced
type=plane
[radio]
protocol=Frsky
num_channels=8
fixed_id=1
tx_power=150mW
[protocol_opts]
Telemetry=On
Freq-Fine=0
Freq-Coarse=0
AD2GAIN=0
RSSIChan=None
[channel1]
template=simple
[mixer]
src=THR
dest=Ch1
scalar=125
[channel2]
template=simple
[mixer]
src=!AIL
dest=Ch2
[channel3]
template=simple
[mixer]
src=ELE
dest=Ch3
[channel4]
reverse=1
template=simple
[mixer]
src=RUD
dest=Ch4
[channel5]
template=simple
[mixer]
src=SW H1
dest=Ch5
curvetype=expo
points=0,0
[channel6]
template=simple
[mixer]
src=SW G1
dest=Ch6
curvetype=expo
points=0,0
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer2]
type=countdown
time=10
[datalog]
switch=None
rate=1 sec
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch1
Small-box=2,31,Timer1
Small-box=2,40,Timer2
Model=75,20
Battery=102,1
Toggle=4,10,0,3,0,None
Toggle=13,10,0,5,0,None
Toggle=22,10,0,4,0,None
Toggle=31,10,0,0,0,None
Toggle=40,10,0,0,0,None
TxPower=102,7
quickpage1=Telemetry monitor
[voice]
name=M80
mixermode=Advanced
type=plane
[radio]
protocol=Frsky
num_channels=8
fixed_id=1
tx_power=150mW
[protocol_opts]
Telemetry=On
Freq-Fine=0
Freq-Coarse=0
AD2GAIN=0
RSSIChan=None
[channel1]
template=simple
[mixer]
src=THR
dest=Ch1
scalar=125
[channel2]
template=simple
[mixer]
src=!AIL
dest=Ch2
[channel3]
template=simple
[mixer]
src=ELE
dest=Ch3
[channel4]
reverse=1
template=simple
[mixer]
src=RUD
dest=Ch4
[channel5]
template=simple
[mixer]
src=SW H1
dest=Ch5
curvetype=expo
points=0,0
[channel6]
template=simple
[mixer]
src=SW G1
dest=Ch6
curvetype=expo
points=0,0
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer2]
type=countdown
time=10
[datalog]
switch=None
rate=1 sec
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch1
Model=75,20
Battery=102,1
TxPower=102,7
[voice]
Time to create page: 0.033 seconds
