EleVon template with 3 position rates
- stevecox
- Keep swinging
13 Jan 2013 12:49 - 13 Jan 2013 14:09 #4969
by stevecox
Adelaide
EleVon template with 3 position rates was created by stevecox
Working Elevon template, this uses the mix switch for rates 40%, 70%, 100% or whatever you change it to. Using the F.Mod switch as a crude throttle cut, you need to set it to -100 or take out etc, as you prefer.
Adelaide
Last edit: 13 Jan 2013 14:09 by stevecox. Reason: F.Mod switch comment
- marcochiu
13 Jan 2013 19:12 #4987
by marcochiu
Replied by marcochiu on topic EleVon template with 3 position rates
That is. Thank you so much.
- unclecrash
25 Dec 2021 02:18 #77632
by unclecrash
Replied by unclecrash on topic EleVon template with 3 position rates
Only elevon template i could seem to get to work, only thing i dont like for some reason i hit the gear switch and it shuts off all movement to servo's any way to change this .
- Gerry
- Bbrad
27 Dec 2021 02:17 #77633
by Gerry
FFS (Forever Fixing Stuff)
Replied by Gerry on topic EleVon template with 3 position rates
read through this thread for elevon tutorial.
www.deviationtx.com/forum/model-template...lease?start=20#69364
Model Templates
- EleVon template with 3 position rates
