Simple Elevons mix with dual rate please!!
24 Mar 2020 09:42 #76097 by Donthemon
Replied by Donthemon on topic Simple Elevons mix with dual rate please!!
Hi - knowing Deviation, there must be a way of doing this but I've never found it! I'd also be very interested as after getting the crackingly good elevon mix (see above), I now have it on 5 models.
24 Mar 2020 14:03 #76099 by danskis
Replied by danskis on topic Simple Elevons mix with dual rate please!!
Thanks Gerry - I guess I fat fingered it and turned off trim on one of the pages.
Next I want to try and load your ini file for a virtual channel but my setup is fairly different.
Once I load the file and set up a new model I assume that I can use the transmitter menu to change receiver protocols. Or, is my only option to do it in the ini before its loaded.
25 Mar 2020 04:44 #76102 by Gerry
Replied by Gerry on topic Simple Elevons mix with dual rate please!!
Loading and then changing the protocol should work, but the channel order (aetr vs taer) could change as well which could cause problems like tx warning of throttle not at zero.
Try it, if it works good, if not post your ini and describe what you want to achieve I'll see if I can fix it.
FFS (Forever Fixing Stuff)
Time to create page: 0.080 seconds
