Tactic anylink
- Hexperience
24 Nov 2012 12:41 #3115
by Hexperience
Tactic anylink was created by Hexperience
Anyone looked at the chip they use? Could it be a possible candidate for running on deviation? I have a tx unit that I just burnt out so I can take it apart and check, but if it's already been deemed unworthy then I'll save myself the trouble.
If it did work, it would allow a lot of models to be flown...
Cheers
Cheers
24 Nov 2012 17:28 #3123
Replied by PhracturedBlue on topic Tactic anylink
I have one around. I think it is an nrf24l01 (but maybe a cc2500?). Either way, it appears it will need a different module to use.
It is on my todo list
- 3d-wanna-b
21 Mar 2013 09:13 #7948
by 3d-wanna-b
So, any progress been made on this yet? would love to be able to use the devo fly some of the models that are made for the tactic link.
Replied by 3d-wanna-b on topic Tactic anylink
PhracturedBlue wrote: I have one around. I think it is an nrf24l01 (but maybe a cc2500?). Either way, it appears it will need a different module to use.
21 Mar 2013 14:06 #7959
I started looking at it. The nrf24l01 which is used for anylink is annoying to use because it requires an extra pin which I don't have available. You can work around this in non-timing critical situations but I'm not yet sure if it is possible for the anylink yet.
- Hexperience
21 Mar 2013 18:57 #7967
by Hexperience
Replied by Hexperience on topic Tactic anylink
Personally I don't see much Bang for the Buck on this protocol anymore. I mean for $20 you can buy an anylink module and use PPM to it. If it were super easy, and on a module that we are already using then sure...
The big pay off will be frsky... long range 8 channel telemetry RX for $25! WIN...
- ave1
29 Jun 2013 13:13 #11555
by ave1
Replied by ave1 on topic Tactic anylink
can someone explain how to use an anylink device with the Devo PPM and which cables are required, please.
- ave1
29 Jun 2013 13:42 #11557
by ave1
Thank you it will bind. I don't know how to set my channels, I think. Ail seem to operate correctly but collective is all wrong and don't know what to do.
29 Jun 2013 13:49 #11558
Replied by vlad_vy on topic Tactic anylink
PPM
Walkera
1 - Elevator
2 - Aileron
3 - Throttle
4 - Rudder
JR (Spektrum)
1 - Throttle
2 - Aileron
3 - Elevator
4 - Rudder
Futaba (Hitec)
1 - Aileron
2 - Elevator
3 - Throttle
4 - Rudder
Walkera
1 - Elevator
2 - Aileron
3 - Throttle
4 - Rudder
JR (Spektrum)
1 - Throttle
2 - Aileron
3 - Elevator
4 - Rudder
Futaba (Hitec)
1 - Aileron
2 - Elevator
3 - Throttle
4 - Rudder
- ave1
29 Jun 2013 13:53 #11559
by ave1
Thanks .. I have never had to make these adjustments and don't know where. can these adj be made in standard?
- sbstnp
29 Jun 2013 14:35 #11562
by sbstnp
I don't think so.
Use advanced then for every channel verify and change the source accordingly. Don't be afraid, it's easy.
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic Tactic anylink
ave1 wrote: Thanks .. I have never had to make these adjustments and don't know where. can these adj be made in standard?
I don't think so.
Devo 10 + 4in1
- ave1
29 Jun 2013 14:40 #11563
by ave1
Thank you. But I am lost. Throttle and pitch seem to be okay now, I am playing with it but Ail and ele are not good. If and Once I stumble on the correct settings, the gui must remain on advanced? Ive never used or needed to use advanced and am lost.
- ave1
29 Jun 2013 15:05 #11565
by ave1
How does one change the source, please? The more I play (experiment) the less I understand. Few if any of my ch are correct now and throttle no longer works. Can someone please Steer me in the right direction?
- ave1
29 Jun 2013 15:33 #11566
by ave1
I don't understand "copy to". Is this my problem. I can't find my throttle channel and cyclic 2 and 1 means? At this time, when I use my Ail, my motor starts. Can't someone take several minutes and help me?
I am just asking for some minor help, please.
- ave1
29 Jun 2013 15:52 #11568
by ave1
I see others being helped all the time. I don't understand why someone will not reach out to help me. I am sure I can pick it up if I just had some minor direction, please.
- sbstnp
29 Jun 2013 16:05 - 29 Jun 2013 16:06 #11570
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
What transmitter are you using?
This is for Devo7E/Devo10:
1. Go to Model config/Mixer. You'll see something like this. Navigate to the type of the mixer associated with the channel, in this case 'Simple'
2. Press the button and you'll have something like this. You can clearly see 'Src' there, meaning Source. Press left/right until you have the correct source for the channel. Vlad provided the correct order in a post above.
Oh, and btw it's weekend so the forums are usually a bit slow, have patience.
Devo 10 + 4in1
Last edit: 29 Jun 2013 16:06 by sbstnp.
- ave1
29 Jun 2013 16:10 #11571
by ave1
12S
And thanks. I have no pitch. The throttle is on the ele ch. ail is Okay. I will review your advice but, but,
- sbstnp
29 Jun 2013 16:17 - 29 Jun 2013 16:24 #11573
by sbstnp
Pitch is usually on channel 6 and has a source of THR.
So you understand, every channel can either have a source or a fixed value. Source can be another channel, or hardware inputs.
This is a quick summary of the sources you can have:
a) Sticks:
AIL
ELE
THR
RUD
b) Switches:
AIL DR0,1,2
ELE DR0,1,2
FMODE0,1,2
etc
c) Channels:
Ch1 - ChX
Virt1 - VirtX
On a heli pitch is controlled by the THR stick. Position of said switch can be 1-to-1 value (like -100 to 100) or it can be mapped on a curve.
Most of the time, you create a curve, the simplest being a 3 point: -10, 0, 50 for example, and use it. Lowest position of the THR stick the maps to -10 and highest to 50.
Keep in mind these values are just pulled out of my a$$ and most likely they are not optimal.
Devo 10 + 4in1
Spektrum Dx9
ave1 wrote: 12S
a) Sticks:
AIL
ELE
THR
RUD
b) Switches:
AIL DR0,1,2
ELE DR0,1,2
FMODE0,1,2
etc
c) Channels:
Ch1 - ChX
Virt1 - VirtX
Devo 10 + 4in1
Last edit: 29 Jun 2013 16:24 by sbstnp.
- ave1
29 Jun 2013 16:18 #11574
by ave1
thank you. Yes, I know I can be impatient. Apologies.
I am making progress now, thank you. Only Pitch ch I can not locate. I think all else is taking shape.
Ive never used anything but the standard set up screen.
- sbstnp
29 Jun 2013 16:19 - 29 Jun 2013 16:21 #11575
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
TBH you should never use standard. It kind locks you in a friendly and familiar box and you never learn anything.
Plus, complex is the "power to you" kind.
Devo 10 + 4in1
Last edit: 29 Jun 2013 16:21 by sbstnp.
Time to create page: 0.203 seconds
- Tactic anylink
