DSM Telemetry support
15 Apr 2015 15:13 - 15 Apr 2015 15:14 #31206
Replied by vlad_vy on topic DSM Telemetry support
Nothing changed with GPS data, except speed is as km/h. Time run as mad, I think instead seconds it use 1/100 sec, whole time has not sense, e.g. 31:04:42. Altitude 88760.500m, speed 129.639km/h and so on.
Last edit: 15 Apr 2015 15:14 by vlad_vy.
- Indigo
15 Apr 2015 16:58 #31207
by Indigo
Replied by Indigo on topic DSM Telemetry support
Possible error in my byte swap function,
Should have been this:
I have recompiled and uploaded to Test Builds.
static void swap_LSB_MSB(u16 *ptr)
for(int i = 1; i <= 7; i++) {
ptr[i] = ((ptr[i] >> 8) & 0xff) | (ptr[i] << 8);
}I have recompiled and uploaded to Test Builds.
- wing927
16 Apr 2015 02:29 #31228
by wing927
Replied by wing927 on topic DSM Telemetry support
Hello All,
I am new to this forum and to Deviation, My question is, will my Devo-10 work with DSM Telemetry. I wanted to get a TM-1000 module and use it with a AR10000 10Ch Rx. I had hopes that I could use the STi™ app with the TR-1000 Made for my, iPhone. This would be a home run for me but, I do not want to spend the $ if the system will not support it. So if anybody knows the answer please give me a hand thanks. By the way this is a great thing, I love my Devo 10 but until I found out about the Deviation upgrade I thought that the system was outdated, Again thanks.
17 Apr 2015 01:11 #31270
Replied by mwm on topic DSM Telemetry support
I have tried both my own builds of the dsm-telemetry branch on the team repository, and a download of your test build, even though both are 84cc0db.
I don't get a reliable telemetry connection with a LemonRX Rx. I can get it to bind and display data, but it won't reconnect after power cycling everything, and I have to hit bind again. Even then, it won't stay connected, but will drop the connection in a minute or two.
I was getting similar behavior from an OrangeRx Rx, but it's been installed in the Orion, so I haven't tested it on the new versions.
- Indigo
17 Apr 2015 11:19 #31288
by Indigo
I updated (about 40 hours ago) 84cc0db, Did you try downloading again and re-testing GPS data?
vlad_vy wrote: Nothing changed with GPS data, except speed is as km/h. Time run as mad, I think instead seconds it use 1/100 sec, whole time has not sense, e.g. 31:04:42. Altitude 88760.500m, speed 129.639km/h and so on.
17 Apr 2015 11:25 - 17 Apr 2015 11:27 #31289
Yes, but nothing changed. Changed code for byte swap function look right and it should work. Do you really change code?
Last edit: 17 Apr 2015 11:27 by vlad_vy.
- Indigo
18 Apr 2015 02:47 #31318
by Indigo
Ok, problem is elsewhere.
I suspect problem is hr & min are swapped, and sec & 1/100 sec are swapped.
I have updated (just now) 84cc0db, Could you please try downloading again and re-testing GPS data?
Also, can you make sense of altitude or speed? I think altitude out by a factor of 100.
18 Apr 2015 06:26 #31321
I don't know what is wrong with your builds, but nothing changed at all. Do you "make distclean" before rebuild?
- Indigo
19 Apr 2015 00:56 #31344
by Indigo
I have found the problem. Some calls to function bcd_to_int() were applying a bitmask to the returned value instead of the parameter value. eg. calls to bcd_to_int() from within function pkt32_to_coord() used to decode Latitude and Longitude.
I have uploaded a new version 9834633 to Test Builds.
19 Apr 2015 08:11 - 19 Apr 2015 10:34 #31348
Code corrections:
static u32 pkt32_to_coord(u16 *ptr)
// (decimal, format DD MM.MMMM)
return bcd_to_int(ptr[1] >> 8) * 3600000
+ bcd_to_int(ptr[1] & 0x00ff) * 60000
+ bcd_to_int(ptr[0]) * 6;
} if ((data_type >= 0x15 && data_type <= 0x18) || (data_type == 0x34)) {
swap_LSB_MSB(pktTelem);
} Telemetry.gps.satcount = bcd_to_int(pktTelem[4] & 0x00ff);
altitude = bcd_to_int(pktTelem[4] >> 8) * 1000000; //In 1000 meters * 1000 (8Bit decimal, 1 unit is 1000m)
Last edit: 19 Apr 2015 10:34 by vlad_vy.
19 Apr 2015 08:59 - 19 Apr 2015 10:18 #31349
PB, can you correct DSM2 code in main trunk?
case 0x16: //GPS sensor (always second GPS packet)
update = update16;
Telemetry.gps.altitude = altitude + (bcd_to_u8(packet[3]) * 100
+ bcd_to_u8(packet[2])) * 100; //In meters * 1000 (16Bit decimal, 1 unit is 0.1m)
Last edit: 19 Apr 2015 10:18 by vlad_vy.
- Indigo
19 Apr 2015 12:45 - 19 Apr 2015 13:00 #31353
At least the time is good. Speed also is good. Altitude a little high, but it can depend from number of sats.
But, Latitude and Longitude have zero values. Something is wrong.
With first code correction it should work. I only changed bitwise "!" to "&".
Last edit: 19 Apr 2015 13:00 by vlad_vy.
- Indigo
19 Apr 2015 13:40 - 19 Apr 2015 13:48 #31357
by Indigo
Ok, I have restored code for pkt32_to_coord() so atleast the uploaded Test Build is working.
Could you please test these alternatives which reduce code size:OR
}Could you please test these alternatives which reduce code size:
+ bcd_to_int(((u32)(ptr[1] & 0x00ff) << 16) | ptr[0]) * 6;
}static u32 pkt32_to_coord(u16 *ptr)
return bcd_to_int(((u32)ptr[1] << 16) | ptr[0]) * 6
- bcd_to_int(ptr[1] & 0xff00) * 24000;
Last edit: 19 Apr 2015 13:48 by Indigo.
19 Apr 2015 13:51 #31358
By sorry it doesn't help, Latitude and Longitude have zero values.
I can test any you want, if I will have your source code. Where I can download your code?
- Indigo
19 Apr 2015 13:59 - 19 Apr 2015 14:40 #31359
by Indigo
The
source
I had would probably work with (ptr[1] << 16) changed to ((u32)ptr[1] << 16)
or
bitbucket.org/Indigo1/deviationtx/src
hg pull -r dsm-telemetry https://bitbucket.org/Indigo1/deviationtx [<destinationPath>]bitbucket.org/Indigo1/deviationtx/src
Last edit: 19 Apr 2015 14:40 by Indigo.
19 Apr 2015 15:35 #31363
First code correction surely should work. There is something else.
But, it seems I've found next bug, control bits are in 16 byte:
I'm not sure it will help. It can't change latitude value, sign only.
}But, it seems I've found next bug, control bits are in 16 byte:
Telemetry.gps.latitude = pkt32_to_coord(&pktTelem[2]) * (pktTelem[7] & 0x0100)? 1: -1; //1=N(+), 0=S(-)
Telemetry.gps.longitude = (pkt32_to_coord(&pktTelem[4]) + (pktTelem[7] & 0x0400)? 360000000: 0) //1=+100 degrees
* (pktTelem[7] & 0x0200)? 1: -1; //1=E(+), 0=W(-)I'm not sure it will help. It can't change latitude value, sign only.
- Indigo
20 Apr 2015 05:48 #31399
by Indigo
Thanks, I've updated the test build with those changes.
Latitude value too small? Try adding another zero to 3600000.
Would the latitude value be correct if you divide value by 36 and multiply by 60?
20 Apr 2015 06:03 #31400
No, both Latitude and Longitude values are zero. Sometimes I can see "1" at least significant digit.
- Indigo
20 Apr 2015 09:08 #31406
by Indigo
Yes, I think it should be this (byte order ptr[0], ptr[1] swapped):
I have made this change and replaced the test build with new version.
vlad_vy wrote: First code correction surely should work. There is something else.
return bcd_to_int(ptr[0] >> 8) * 3600000
+ bcd_to_int(ptr[0] & 0x00ff) * 60000
+ bcd_to_int(ptr[1]) * 6;
}I have made this change and replaced the test build with new version.
Time to create page: 0.285 seconds
- DSM Telemetry support
