DSM Telemetry support
26 Apr 2015 21:56 #31679 by Indigo
Replied by Indigo on topic DSM Telemetry support
I think the key here is to have a consistent execution time. The added parameter is so it only needs to be called once.
I can probably improve it further by making the procedure have a more consistent execution time.
27 Apr 2015 14:36 - 27 Apr 2015 15:08 #31697 by vlad_vy
Replied by vlad_vy on topic DSM Telemetry support
How to disable switching to Telemetry monitor in case any telemetry alarm? I don't like when any device do thing what I don't ask. Moreover, I don't see anything at Telemetry monitor screen without glasses.
Also, at layout configuration screen, Page Config, I can select too many non-existent telemetry values (sensors) = Amps, PbVolt1 ...., up to HtOutput. Many of them do not fit into scroll bar.
Last edit: 27 Apr 2015 15:08 by vlad_vy.
27 Apr 2015 22:48 - 27 Apr 2015 23:34 #31719 by Gyrfalcon
Replied by Gyrfalcon on topic DSM Telemetry support
Hello everyone,
Let me start off by complimenting all the fine work done on this project. I have been using Deviation on both a Devo8S and a Devo12S (with additional RF modules) for about a year and it is great!
Recently I have been adding telemetry to all of my helicopters and really appreciate all the improvements that are in the works to improve the reliability both the Devo and DSM telemetry systems. I have just created my own local code building environment and I am starting to get up to speed with the development process. Hopefully I can help contribute to this effort in a complementarity fashion - so hear goes :)
For the telemetry alarm page switching changes, I also find that the original alarm works best on my system. I have modified the main page to include the telemetry information that I care to see and having the page jump is frustrating (especially on battery disconnect from the receiver.) But I can appreciate that others may like this feature. So I would suggest that two type of alarms be implemented - the original 'standard' alarm and an 'advanced' alarm that jumps to the telemetry page.
One simple method to implement this would be to make the first 2 or 3 alarms works as in the original code. The remaining alarms could be configured as advance alarms and jump to the telemetry page as the new code implements.
I created some example code that implements this on the Devo12S.
src/telemetry.c
Starting at line #342
    if (alarm_state[k]==1 && current_time >= music_time) {
        music_time = current_time + MUSIC_INTERVAL;
        if (k > 2 && k < 9 + TELEMETRY_Type())  // Keep first three alarms as original
            PAGE_ShowTelemetryAlarm();          //  and enable all others to change page to Telemetry Page
#ifdef DEBUG_TELEMALARM
        printf("beep: %d\n\n", k);
#endif
        MUSIC_Play(MUSIC_TELEMALARM1 + k);
src/pages/common/_telemconfig_page.c
Starting at line #29
static const char *label_cb(guiObject_t *obj, const void *data)
    (void)obj;
	if ( (int)(long)data < 3) {
        snprintf(tempstring, sizeof(tempstring), "%s%d", _tr("Std Alarm "), (int)((long)data)+1); // label first 3 as Std Alarm
	} else {
        snprintf(tempstring, sizeof(tempstring), "%s%d", _tr("Adv Alarm "), (int)((long)data)+1); // label remaing as Adv Alarm
    return tempstring;
src/pages/320x240x16/telemconfig_page.c
Starting at line #27
    enum {
        COL1 = (5 + ((LCD_WIDTH - 320) / 2)),  // Adjust for larger Alarm name
        COL2 = (COL1 + 75),
        COL3 = (COL1 + 171),
        COL4 = (COL1 + 236),
        ROW1 = (70 + ((LCD_HEIGHT - 240) / 2)),
I can also add the files if anyone is interested.
Thanks again to all,
Cheers
Last edit: 27 Apr 2015 23:34 by Gyrfalcon. Reason: code format
27 Apr 2015 23:04 #31720 by PhracturedBlue
Replied by PhracturedBlue on topic DSM Telemetry support
I am in agreement that this must be fixed. I don't really care if the functionality is reverted or if a per-alarm toggle is added, or some hybrid like Gyrfalcon suggests. Indigo, what is your opinion since this is your feature?
28 Apr 2015 03:22 - 28 Apr 2015 03:40 #31723 by Indigo
On the Model's Telemetry Config page where you configure up to 6 alarms, the compare operator ">" or "<=" is now a combo list/button control. If you click the button is will just play that alarms sound, but I'm thinking when you click the button a config screen pops up with the following:
Title: "Alarm Actions"
Options:
- Jump to screen:<No action, Telemetry monitor, Main screen>
- Play sound: <on,off>
- Vibrate: <on,off>
- [Test button]
The Test button would execute all actions except for the "Jump to screen" action, for that action just popup the words "Telemetry Monitor", "Main screen" or do nothing.
Edit: Good idea, as an interim solution make the "Jump to screen" feature work only for the last 3 alarms.
Thank's for suggesting it. :) I will edit the code and make the required change.
BTW. Each alarm should have its own unique music and unique vibrate pattern. PB: Are you able to fix this?
Last edit: 28 Apr 2015 03:40 by Indigo.
28 Apr 2015 03:50 #31728 by PhracturedBlue
I don't know anything about vibrate patterns. I think we currently only ave vibrate and no-vibrate.
The music is already setup for a different tone for each alarm. Except that sound.ini has the same sound for all alarms. If you change that you should get different notes for each one.
28 Apr 2015 04:39 - 28 Apr 2015 04:41 #31729 by vlad_vy
It's not about telemetry, but about CYRF_FindBestChannels(). I think RSSi dummy read (CYRF_ReadRegister(0x13)) has to be placed after CYRF_StartReceive(). Otherwise real reading (rssi = CYRF_ReadRegister(0x13)) will return nothing real.
"The contents of this register are not valid after the device is configured for receive mode until either a SOP symbol is detected, or the register is (re)read.
If it is desired to measure the background RF signal strength on a channel before a packet has been received then the MCU should perform a “dummy” read of this register, the results of which should be discarded. This “dummy” read will cause an RSSI measurement to be taken, and therefore subsequent readings of the register will yield valid data."
void CYRF_FindBestChannels(u8 *channels, u8 len, u8 minspace, u8 min, u8 max)
    #define NUM_FREQ 80
    #define FREQ_OFFSET 4
    u8 rssi[NUM_FREQ];
    if (min < FREQ_OFFSET)
        min = FREQ_OFFSET;
    if (max > NUM_FREQ)
        max = NUM_FREQ;
    int i;
    int j;
    memset(channels, 0, sizeof(u8) * len);
    CYRF_ConfigCRCSeed(0x0000);
    CYRF_SetTxRxMode(RX_EN);
    //Wait for pre-amp to switch from send to receive
    Delay(1000);
    for(i = 0; i < NUM_FREQ; i++) {
        CYRF_ConfigRFChannel(i);
        CYRF_ReadRegister(0x13);
        CYRF_StartReceive();
        Delay(10);
        rssi[i] = CYRF_ReadRegister(0x13);
    for (i = 0; i < len; i++) {
        channels[i] = min;
        for (j = min; j < max; j++) {
            if (rssi[j] < rssi[channels[i]]) {
                channels[i] = j;
        for (j = channels[i] - minspace; j < channels[i] + minspace; j++) {
            //Ensure we don't reuse any channels within minspace of the selected channel again
            if (j < 0 || j >= NUM_FREQ)
                continue;
            rssi[j] = 0xff;
    CYRF_SetTxRxMode(TX_EN);
Last edit: 28 Apr 2015 04:41 by vlad_vy.
29 Apr 2015 14:22 - 30 Apr 2015 08:32 #31800 by Thomas.Heiss
Replied by Thomas.Heiss on topic DSM Telemetry support
vlad_vy wrote: PB, can you change at main trunk next things?
Also, for() cycle doesn't work. It seems all values are writed to Telemetry.p.dsm.flog.fades[0].
        case 0x7f: //TM1000 Flight log
        case 0xff: //TM1100 Flight log
            update = update7f;
            //Telemetry.p.dsm.flog.fades[0] = pkt16_to_u8(packet+2); //FadesA 0xFFFF = (not connected)
            //Telemetry.p.dsm.flog.fades[1] = pkt16_to_u8(packet+4); //FadesB 0xFFFF = (not connected)
            //Telemetry.p.dsm.flog.fades[2] = pkt16_to_u8(packet+6); //FadesL 0xFFFF = (not connected)
            //Telemetry.p.dsm.flog.fades[3] = pkt16_to_u8(packet+8); //FadesR 0xFFFF = (not connected)
            //Telemetry.p.dsm.flog.frameloss = pkt16_to_u8(packet+10);
            //Telemetry.p.dsm.flog.holds = pkt16_to_u8(packet+12);
            for(int i = 2; i < 14; i+=2) {
                *(u8*)&Telemetry.p.dsm.flog = pkt16_to_u8(packet+i);
            Telemetry.p.dsm.flog.volt[1] = pkt16_to_volt(packet+14);
            break;
Guys, you start killing me :)
That code block has been changed a long time ago with my first posting by Mike and Indigo: www.deviationtx.com/forum/protocol-devel...port?start=100#26681
Of course it never has been merged to team repository or PB repository - not yet.
Mike and I had to put back the "1st pull request" for PB repository.
It is now fixed in dsm-telemetry branch (Indigo repository - 2nd pull request team repository) FOR AGES - fixing the overwrite.
We had two tickets open, one opened by me (code change by Mike, taken over by Indigo with further improvements). See commit log.
May I ask you in how many repositories are you now changing and testing code in parallel?
How many developers change code in parallel? Three? In three repositories? Indigo, PB, Vlad?
According to your latest threads you change code on-the-fly (in threads), locally creating test build versions?
So there are now test builds with not equivalent source code too? Only small (debug) changes?
Why do you now have to fight with wrong - already fixed - code at team main trunk??? I really get lost!!
PhracturedBlue wrote: Where is this all going?
I have to admit I'm very skeptical of the process at the moment. When I look at Indigo's code, it has a lot of change compared to the trunk in DSM and Devo protocols. I don't really understand what much of that change is buying me. In Devo, it may result in eliminating the 'Reboot' condition, but at least at the moment, it will come at the cost of major refactoring of the callback loop, and the Reboot condition itself is not causing any issues (any more). In DSM2 the code refactor may reduce Holds? I belive the original intent was to improve reception rate (eliminate invalids and bogus data)? What else does it achieve? All of that change comes with inherent stability risk to the most commonly used protocols. It makes me very nervous, especially with 9 out of 10 builds seeming to have major issues that make it unusable. I really need to see concrete gains, and then I will wonder whether those gains can be had with less change to the protocol code.
And then there are at least two to three threads too: Walkera telemetry - DSM telemtry - OrangeRX DSMx range problems.
Your question is related to DSM - but posted to Walkera thread.
To answer your question PB, I want to answer in this thread:
1) It all started with the above DSM telemetry code fixes. FlightLog DSM telemetry is / was corrupted in (PB+team) trunk - see my above first post.
2) "9999" values improvement (see tickets 180CFX, 200SRX): AR8000 can have >255 Fades too!
3) And then in all versions (starting offical team trunk, Indigos test builds) there are (still) corrupt DSM FlightLog telemetry data - see my new videos.
Indigo wrote about point 3) in another thread - I believe it was "DSMx range thread" why he did it and for what reason (separating RX + TX buffers).
Indigo was working on point 3) to eleminate bogus DSM FlightLog data. It seems it is not fixed yet - at least I missed that success posting by other developers / Indigo / re-testers.
I have not done any Flightlog re-tests since my video with new test build versions with original Spektrum RX+TM either.
Thomas.Heiss wrote: Confirm 5) Temp value '18186C' for disconnected sensor (tested on AR8000)
New error: Fades will be reset to 0 after some time (max 0xFF/255 bit counter on A for 6CH RX a problem?)
Flightlog (fades): Jumping numbers as previously described (problem goes back to nightly version 92e1705)
FlightLog test videos 36cce5c with 100uw (not 100mw) output power:
modellbau.theiss-nbg.de/Deviation-TX-Nig...5c-DSmx_TM1000_Tests
All videos finished uploading.
4) A new problem rise with (some / one) of Indigos test builds: TX + RX lockout. DSM lock with no ever changing new telemetry data.
At least I had that issue once. See one of my tests back where I even got a DSMx TX lockout (lost of bind) with my 200QX at the table.
5) Indigo had very good ideas how to further improve the telemetry monitor screen like alarming, flickering values, alarm stop by ENT button. Re-alarmings.
We also had to change code for the stepping of "1" (holds) and 10 (Fades) since the increments where wrong in the config screen in trunk. The config screen also had wrong comparator (<=0, >=0, >0) to check for holds >0!
If we can not fix points 4) and 3) we have no real benefit and we would have to rollback all changes. But we loose all new and fixed features of point 5)!
IMHO it is the wrong time to throw away all the hard work of Indigo and all the detail improvements which already went into!!! I want them!
I just can tell you that you can NOT use trunk version 92e1705 for DSM telemetry with all that bogus data and invalid stepping configurations and missing re-alarms on FrameLosses and Holds. All stuff the DX8 has - but I hate that Airware version. And I now own a Devo 10.
Point 3) bogus flightlog telemetry data is still open at my side.
Who of you could already take a deeper look in the recorded DSM flightlog telemetry vids?
What is your feedback? Did I miss it?
I had been flight testing trunk 92e1705 + 2-4 Indigo's further (early) test builds with the 200QX. Had no TX lockout during the flight(I could not fly that far away!!).
I have no idea if point 4) is something new introduced by all the new code changes or if that might even was already in 92e1705.
According to thread "DSMx range problem" problems may have already been there before we started re-engineering.
On the other side pilots even had no clue about if they had to choose 100uw/300uw/1mw for range testing before - so that might have given wrong results too?!? For Full-Range flight tests with 100mw and TX connection problems it is again different (results count).
But who would rely on test results for 3rd party Non-Spektrum RX like OrangeRX? Not me! They could have been problems because of SBEC ESC too just like I had once with DX8 and two ESCs.
One of the biggest problems:
You guys seem to have to code (almost) blind because of missing multiple original Spektrum RX, BNF quads + TM1000/TM1100. We would even have to test with 9-12CH receivers!
In the other "DSMx range problem" thread guys are testing wrong (TX lying on/above ground) or with Non-Spektrum equipment (OrangeRX/LemonRX) or without telemetry enabled (missing Flightlog DataPort).
One guy writes he wants now to test with 150mw, even within the EU only 100mw are allowed.
Why not compare each test build version with the same uw/mw and linked Spektrum TX (e.g 1mw on ground range-test) equipment.
So even all the testers - with all this different RX equipment - can not commit on a permanent testing pattern consistent over each test build version.
FlightLog Logging:
Maybe PB / a senior DeviationTX dev could tell me how to successfully record Flightlog DSM logfile data and publish all the bogus additional numbers which may or may not be an indicator of additional "TM1000 / telemetry out-of-range"?
Unfortunately I was never successful in enabling the log file and read from it in Linux once I rebooted into USB mode. It was empty always!
Because of all point 3) code improvements and re-engineering we now see values which were badly supressed before (>255 -> 255 fixed value).
I agree with PB's statement that it will probably still take a longer time to test thru all code changes by multiple testers with multiple RX equipment until we have a final working version which is ready for a public commit to team trunk.
However I am very delighted that Mike and Indigo took my code fixes and small 8bit/16bit improvements (9999 numbers).
Thank you working together!
All the "DSM Telemetry problems/enhancements" have got so many developers and testers active trying to further improve and help bugfix continuous.
I greatly appreciate all your efforts you put into.
I am sorry to see that new test builds might bring unforeseen new TX<->RX / lock or connection lost problems (when you trying to fix that initially) at this time or the code changes are already too big to be reviewed in steps and you now fear a final trunk commit. Please don't give up and keep trying.
Is there maybe any way to split the summary of "total code changes" to individual steps which may be safely committed one by one?
- Changes which are for sure
- improvements which are safe and
- RX/TX/connection/filtering code which needs to be tweaked and tested more in detail? Comparing Walkera + DSM code...
Do you have any idea how you might get away from "blind coding"?
Thanks again to all of you who stepped into helping to bugfix and trying to further improve.
Thomas
Last edit: 30 Apr 2015 08:32 by Thomas.Heiss.
29 Apr 2015 16:09 #31809 by PhracturedBlue
1st off recall that until March I was completely unavailable to the community for any code merge or comment. Everyone does things differently and Mike and Indigo may run the main repo differently than I do. I also had no interest in reading 6 months of back conversation, so anything posted before I became active again can be assumed to be unknown to me.
For the main repo, I am much more likely to merge small obvious patches than large complex ones. Vlad's fix is an example of something that was obviously wrong and could be fixed trivially. The new solution may also be wrong, but it works for at least one person, so it is better than what was there. If there are other isolated changes that can be added, submit them individually, and I'll review and merge them as appropriate. Big changes (like the telemetry display merge) take me longer to review. Once the protocol stuff was removed, that one seemed like it was in good shape, and so I accepted it. The wider testing it is getting has identified some further changes that are needed, that Indigo is working on.
Changes to the protocol code are the most sensitive and require the most diligence. Indigo's current branch has some prettymajor underlying changes, and I want to ensure it is really solving a issues without any regressions before I touch the 'bread and butter' that is the Devo/DSM protocols. I am not yet convinced it needs as much restructuring as there currently is, but I'm willing to wait and see. However, I am holding the next official release until these 2 protocols are working properly.
I prefer test-based coding, where changes can be shown concretely to have a benefit. But with the protocol code that can be very hard due to the nature of the issues as well as the hardware affected. The number of people here who have both the inclination and hardware to do coding and testing is very small, and we need to make due with what we have. That is why the test-branches are valuable to get feedback from as many people as possible. I may complain about the process, but in the end I am very appreciative to the folks willing to do countless iterations of developing and testing to improve the situation. I am currently working on too many other aspects of Deviation to dive into these issues, and I don't have the proper equipment to validate all the changes anyway. Once the changes are proven to work, we'll figure out the best way to merge them into the trunk, but sometimes flying blind is the only way. If different folks want to attack the problem in different ways, that is fine with me. I am looking for the smallest change that will provide the right behavior.
As for how the threads are organized, the DSM changes and Devo changes are different but are interrelated due to both using the same functions to control the CYRF chip. Keeping the discussions separate in general is important because the set of users who can contribute is different.
29 Apr 2015 16:17 #31810 by PhracturedBlue
I am not sure what issues you have with data logging. a different thread would probably be better if you've tried the obvious and it doesn't work. I think the log-end detection isn't working well (which means if you reboot the tx it may start overwriting the log).
So I'd recommend using a toggle to start/stop the logging. select the relevant channels (or all if you are lazy), set a proper logging time. turn on the log with the toggle and make sure the space is counting down. when done, turn off the logging shut down the tx, and start up while holding 'ENT'. The log file size is fixed, but there should be data inside it when examined using xxd. the repo contains a script to convert it to csv.
If you've done all that and it doesn't work, provide a detailed description of what you are doing and what isn't working, and I'll see if I can help.
30 Apr 2015 09:22 - 02 May 2015 15:08 #31837 by Thomas.Heiss
Bug Tracker / pull request links:
BT #590: www.deviationtx.com/mantisbt/view.php?id=590
BT #571: www.deviationtx.com/mantisbt/view.php?id=571
1st BitBucket pull request #7 comments: bitbucket.org/deviationtx/deviation/pull.../dsm-telemetry-fixes
vlad_vy wrote: www.deviationtx.com/mantisbt/view.php?id=611
It works fine. After Tx power off and power on:
FadesA = 45
FadesB = 255 (always)
FadesL = 45
FadesR = 255 (always)
Loss = 0
Holds = 1
Once more:
FadesA = 89
FadesL = 89
Loss = 0
Holds = 2
8bit datatypes are wrong anyways.
Fades do NOT end at 0xFF.
AR8000 can e.g display >255 Fades for FlightLog - see my previous postings.
AR6210 is max 255 for FlightLog (A and B). RX stops sending data >255.
0xFF=max 255 fades should NOT be suppressed but displayed normally (not replaced by "0").
NOT_CONNECTED is 0xFFFF, not 255 (65535).
Multiple receiver show "not connected" antennas B, L or R depending on connected satellites.
Values A, B, L, R will be different depending on RX (e.g AR8000, 9->12CH RX) or same (e.g AR600).
Mapping code if >255 -> return 255 in trunk is wrong.
My 1st try code mapping was >9999.
Mike and Indigo re-engineered to let telemetry data values >9999 thru and handle NOT_CONNECTED + filtering packets differently.
NOT_CONNECTED looks to be different for some receivers (Spektrum, OrangeRX, LemonRX) too according to other threads.
- again a new coding concept / different incompatible source
- coding over and over again (by eventually missing some important points we where discussing endlessly before)
- topic for >255/>9999 packet values had been solved already in dsm-telemetry branch by three people + tested (NOT_CONNECTED still does unfortunately not work always for bogus telemetry data - see my videos)
- new code on different repository which is even not anymore source compatible with Indigos dsm-telemetry branch?
Why do you not at least take these well-done sub-code parts from Indigos branch without rewriting it from scratch?
Do I misunderstand your goals and new discussions?
Greetings
Thomas
Last edit: 02 May 2015 15:08 by Thomas.Heiss. Reason: added link 1st BitBucket pull request #7 comments, added text for 0xFF/255 handling (display)
30 Apr 2015 18:37 #31857 by mwm
Replied by mwm on topic DSM Telemetry support
Seems like telemetry alerts now take you to the telemetry config page when they go off. Ok, I can see why, but think maybe the telemetry monitor page might be a better option. Since there's no "search thread" option, I haven't checked to see why.
However, when this happens on the "Range Test" page, it's really annoying. In particular, since it leaves the range test page, it turns off the range test, which could lead you to thinking the range test was still going on. I can see that you might want to monitor radio losses during a range test, but other things are irrelevant. My initial reaction was that jumping to the telemetry page should be disabled during a range test, but maybe not.
30 Apr 2015 20:49 #31860 by PhracturedBlue
Thomas,
The fact is that until very recently there wasn't a pull request that met my requirements that I could even review. Even now, Indigo's pull request can't be pulled as is. Even as late as last week, there were major issues being reported with them in both Devo and DSM, and I'm not sure the Devo issues are actually fixed. That pull request basically rewrites the callback functions for the 2 most critical protocols that Deviation supports, and I do not personally have the bandwidth to verify that it is more reliable than what we have. So that makes me very reluctant to include it. In the end, I understand the code as it is now. If all of the developers drop off the face of the earth, I know I understand how the current DSM and Devo protocols work. I do not want to give that up, so I am unlikely to include those changes until I do understand them and believe I can support them.
I have already explained why I'm taking this path, and I think we are starting to go around in circles now.
Mwm,
I tend to agree that the page jump should likely not happen during range-test, though I am unlikely to be happy hardcoding inter-page dependencies like that into the code.
30 Apr 2015 20:56 - 30 Apr 2015 22:21 #31861 by mwm
PhracturedBlue wrote: Mwm,
Maybe the page jump should just not happen? People using telemetry should be able to config their main page so they can easily figure out what the alert it is for. Either display the value that's causing the alert (whether it be a telemetry alert or a timer alert) on the main page, or configure page shortcuts to take them to the relevant pages?
Which adds the question - do we highlight the Tx battery level when that's causing an alert?
Last edit: 30 Apr 2015 22:21 by PhracturedBlue.
01 May 2015 03:21 - 01 May 2015 03:32 #31878 by Gyrfalcon
Just checked Indigo's latest build, deviation-devo12-v4.0.1-ee1b869 and he has implemented the hybrid Telemetry Alarm I suggest a couple of days ago.
It is a small code change that enables the first three alarms work as in the original code and the last three alarms jump to the Telemetry Monitor page. I think this is better for now, as it gives both functionalities. (I do not know all the history on this, but I assume that someone really wanted Telemetry Alarms to change to the Telemetry Monitor page.)
However, I would suggest that the alarm labels on the "Telemetry config" page be renamed to avoid confusion. At least a simple name change, that still fits with in the original label ("Alarm") footprint, like "S_Alm" and "P_Alm". (any other suggestions?)
Ultimately, once all the telemetry and protocol improvements are made and approved, it would be great to see the configuration of telemetry alarms enhanced. Independent configuration for sounds, color/highlighting, page jumps, durations, auto/manual resets, and logging (just to name a few) would give users some very cool capabilities.
Perhaps we should start a new thread on Telemetry Alarm Configuration?
Last edit: 01 May 2015 03:32 by Gyrfalcon. Reason: updaated to correct build version
01 May 2015 04:11 #31879 by PhracturedBlue
I'd rather not change the names. The reason is simple. Every unique string costs RAM in the language translation table. unique strings bloat the table for little gain. Especially if the plan is to rework it in the future anyway. I haven't seen a pull request from Indigo on this as yet.
01 May 2015 04:47 #31880 by Gyrfalcon
That's a really good point that I had not consider. I completely agree that only simple telemetry alarm changes (if any) should be made now. Let's get the protocols and telemetry code stable and consider these other ideas separately.
02 May 2015 15:39 #31961 by Thomas.Heiss
PhracturedBlue wrote: Thomas,
Hello PhracturedBlue, Hello all,
I am not sure if there may been some overlaps writing here in forum, old bugs shown by vlad, my posts, your answers, preparing telemetry branch for merge and latest merges pull request #43 on 04-25?! I was not aware of those pull request merges before.
I am glad you guys found a proper route to partial split the development work but being already able to commit Indigos basic dsm telemetry branch changes and enhancement and not having to really re-write everything from scratch and re-talk over every already fixed bug over again.
I can totally understand your toughts about the protocol changes and I agree with it to postpone and re-test them separately.
02 May 2015 15:55 #31963 by Thomas.Heiss
Pull Request #42 RangeTest:
Pull request comment about 100uw: bitbucket.org/deviationtx/deviation/pull.../add-range-test-page
Thread DSMx range test link: www.deviationtx.com/forum/3-feedback-que...ions?start=120#31014
100uw does not seem to match Spektrum 30-35m test range.
Even 60-65m has been successfully tested by me on AR6210 with Spektrum DX8 with "range test mode" / pressing trainer button.
Is it possible to make the range test page configurable to 1mw too and not hard code 100uw into the code?
Is it possible to include DSM telemetry monitor for the range-test just like Spektrum does it when you receive telemetry data?
So I need a "test mode + telemetry monitor" <100mw which is able to show DSM flightlog.
FlightLog 0xFF / 255 max value
Do the latest pull requests (without protocol changes), which are merged into deviationtx team repository (trunk), have some more code changes / reviews for displaying 0xFF/255 values?
Have you been already working on this Indigo?
As posted before in this thread I had the problem that the Fades A, B, L, R reset to "0" suddenly once "255" had been reached.
The valid max value (fades) for AR6210/AR600 is 255. It went no further on DX8 so it is receiver hardware.
It is fine to display 255 therefore. It is not a bad value (for fades).
AR8000 and probably 9-12CH receivers can go >255 for fades (I tested this on AR8000 on L before).
You must NOT reset or suppress flightlog data 0xFF (at least not for fades).
Not sure about holds and framelosses (and jumping telemetry data).
Framelosses: should be <40 normally (best up to ~20), could go 50-90 on AR6210 or higher on AR600 with only one receiver antenna (antenna diversity still counts up FrameLosses)
Holds: <10 (0) expected
Bigger numbers on FrameLosses / Holds are "telemetry jumping numbers" or telemetry out-of-range errors?
Earlier in the thread there had been an explanation about telemetry out-of-range (that does NOT!!! mean the Spektrum receiver has lost connection / bind too) and possible high numbers.
02 May 2015 17:09 #31966 by vlad_vy
Spektrum DX8 has 18-19dB attenuation for range test. It's about 1mW. But other Tx can provide greater attenuation. So we have not any reference point. Range from 100uW to 1mW.
Time to create page: 0.301 seconds
