skyartec compatibility
- stein@office-center.no
01 Aug 2013 23:38 #12710
by stein@office-center.no
Replied by stein@office-center.no on topic skyartec compatibility
Hello again.
I chose to keep the Nasa 701 intact for reference. When a problem occur I can always check if its a radio issue by binding the X3V to NASA701.
As i now get 150m range I have more than enough for The X3V.
I could get some pictures from inside my Devo-10 if that could be helpful?
About the module You are using, I also bought that one and another one -but chose to go with Skyartec. But from one of the other modules I used the antenna and antennawire.
Anyway I hope You get it too work soon!
Stein
Stein
- bigde
03 Aug 2013 01:27 #12733
by bigde
Replied by bigde on topic skyartec compatibility
Hello guys... how do I change the power output setting for cc2500 skyartec_init. for devo12s.
I need clear info about doing this so please help.
- RandMental
03 Aug 2013 14:23 - 03 Aug 2013 14:24 #12742
by RandMental
Currently you cannot change it from the menu (yet).
There is a pull request on Bitbucket to increase the default output to about 80mW. However it means you have to build the software yourself. bitbucket.org/PhracturedBlue/deviation/p...output-skyartec/diff
If you PM me your email address I shall email you the firmware with the fixed 80mW output (which is what Stein uses).
Replied by RandMental on topic skyartec compatibility
bigde wrote: Hello guys... how do I change the power output setting for cc2500 skyartec_init. for devo12s.
Last edit: 03 Aug 2013 14:24 by RandMental.
03 Aug 2013 14:42 #12743
HI..
Just a little correction. The firmware You made for me RandMetal I do not use anymore. After I got the antenna soldered to the Skyartec module i installed the last nightly build - getting enough distance with that setup.
Stein
Stein
- RandMental
03 Aug 2013 15:01 - 03 Aug 2013 15:01 #12744
by RandMental
Good to know, it again shows the improvement that a good external antenna gives compared to a short internal pigtail.
stein@office-center.no wrote: HI..
Stein
Last edit: 03 Aug 2013 15:01 by RandMental.
- bigde
03 Aug 2013 20:32 #12746
by bigde
OK RandMental I've send you a PM, if you can send me a patch that would be nice.
Thanks.
Thanks.
- pcguru
20 Nov 2013 20:37 - 20 Nov 2013 20:38 #15709
by pcguru
Replied by pcguru on topic skyartec compatibility
Hello, I bought a similar unit (XL2500-D03) on ebay and have been trying to get the specs for it... what is the RFC pin used for? Does anyone have a pointer to the specs for this board?
THANKS!! Bob
THANKS!! Bob
Last edit: 20 Nov 2013 20:38 by pcguru.
- victzh
20 Nov 2013 20:54 #15710
by victzh
Replied by victzh on topic skyartec compatibility
This discussion and also one about power output was happening here some time ago. Take a look:
www.deviationtx.com/forum/protocol-devel...patibility?start=100
- hepoun
16 Dec 2013 22:06 #16724
by hepoun
Replied by hepoun on topic skyartec compatibility
Hi, I'm posting here for next statistic record, I bought XL2500-D03 on ebay (as suggested in manual
here
) and I had also real problem with TX output power (worked for really short range), I followed cmpang's
advice
and connected Vcc to pin 5 on module (instead of to pin 10) and problem is gone.
On PCB are pins marked as 5-RFC and 10-PAEN, quite misleading.
- boives
Time to create page: 0.502 seconds
- skyartec compatibility
