Frsky compatibility
- z33
18 Sep 2015 08:44 #37843
by z33
Replied by z33 on topic Frsky compatibility
Just came across this and reading with interest.
I hope the X4R-SB will be supported in the future.
I recently got a devo 6S and will be having it modded to be used with my D4r-ii. But I am transitioning all my D4r-ii away to X4R-SB...
If someone is committed to finding a solution to X4R-SB, I will be happy to donate a piece.
- jry
18 Sep 2015 09:49 #37844
by jry
Replied by jry on topic Frsky compatibility
D16 protocol capture from X4R-SB RX is now available at
www.rcgroups.com/forums/showthread.php?t=2503871
I will try to capture also XJT TX part.
19 Sep 2015 00:33 #37860
Yay! And I see midelic is already on it. Hopefully, he'll either do a deviationTx port, or provide code that can be ported.....
Replied by mwm on topic Frsky compatibility
D16 protocol capture from X4R-SB RX is now available at www.rcgroups.com/forums/showthread.php?t=2503871
- adamwedl
21 Sep 2015 18:49 #37934
by adamwedl
Replied by adamwedl on topic Frsky compatibility
I'm in the same boat as many others, just ordered an X4R-SB and CC2500 from banggood in the hopes of using them with Deviation on my new 6s.
Do you amazing people believe that this protocol can be implemented post haste? Or should I try and cancel the order now, before it has shipped?
- midelic
21 Sep 2015 19:20 - 21 Sep 2015 19:22 #37935
by midelic
Replied by midelic on topic Frsky compatibility
I started decoding the protocol but the go further identifying data used I need an X4R.RX. for testing the code.
Unfortunately I don't feel like buying immediately another RX,
I bought so many things for my multiprotocol testing. and have a lot of stuff I don't need .... so is going lower on my priorities list.
Last edit: 21 Sep 2015 19:22 by midelic.
- Fernandez
21 Sep 2015 20:31 #37938
by Fernandez
Replied by Fernandez on topic Frsky compatibility
Hi Midelic, did you ever looked into the feature of setting the Rx failsaves from button of the TX ?
With the D series it is possible and I find it very handy as receiver is normally somewhere not easy to reach after tunning configuring makes easy to store failsave before flying.
- adamwedl
22 Sep 2015 16:11 #37962
by adamwedl
Hello midelic, where are you located? I would love to send you my X4R-SB for you to work on the protocol, as I have nothing to use mine for until it is supported by Deviation.
midelic wrote: Hi,
- midelic
- midelic
29 Sep 2015 18:34 - 30 Sep 2015 06:14 #38227
by midelic
I made code for XJT 16 channels,But for test I need an X4 RX.
Maybe somebody from Europe is willing to sell one to me.
I need it in 2-3 weeks max.If not I will be able to test after 2 months.
Last edit: 30 Sep 2015 06:14 by midelic.
- Olivier0253
30 Sep 2015 06:10 #38263
by Olivier0253
Replied by Olivier0253 on topic Frsky compatibility
I have a devo 8s on last NB version and cc2500/d4r-II and i would like to have RSSI on my minimosd via a spare Channel to my naze32 (in ppm)
But i dont Know how?!...
- kerzin
04 Oct 2015 14:09 #38416
by kerzin
Replied by kerzin on topic Frsky compatibility
I think I have the same need. I am building a new 250 based on dr4-ii, flip32 and minimosd and I would like to send back RSSI to the flip32 in order for the RSSI to be displayed by the minimOSD.
Should be possible to do it with the Taranis (see http://http://vk4ghz.com/mwosd-display-rssi-via-spare-radio-channel/ ). But i think it is not yet possible with deviationtx ?
Any chance for that to be developed ?
- Fernandez
04 Oct 2015 19:38 #38422
by Fernandez
rssi at Rx is just coming out of d4r receiver if ouput in ppm mode.
I have problem with telemetry frsky at devo 7e, telemetry only comes in after bind or after an Rf power change.
Also the Tx voltage is being displayed instable going up and down. Further would be interesting if the minmax values, could be displayed, so after flight you can check min RSSi etc.
04 Oct 2015 21:45 #38424
The problems with data not being displayed until bind or power change were fixed by a fix a while back, though you may be having another problem with the same symptoms.
So which version are you running? In particular, have you tried my frysky telemetry test build? deviationtx.com/downloads-new/category/2...kysensorhubtelemetry
Days logging isn't going to happen on the 7e. I had to take out the vario reading to get the sensor hub battery voltage to display.
- Fernandez
05 Oct 2015 08:28 - 05 Oct 2015 08:51 #38433
by Fernandez
Excellent thanks for that. I am running v4.0.1-b381655, I put that as it was developed for Bayang Eachine H8 at the time.
Will run your test build if it has also the bayang protocol.
Wishlist:
For telemrtry, no full logging required. But as I can't read screen during flying, some Telemetry Statsistics screen would be very nice, giving min max Voltages, RSSI etc, or a possibly to set a counter, which can count the nr of samples RSSI / Voltage was below threshold as set etc. Just after the flight you can check it.
At power down, those values maybe deletet.
Wishlist:
Last edit: 05 Oct 2015 08:51 by Fernandez.
05 Oct 2015 18:26 #38443
You can display RSSI and battery voltage on the main screen, but you'll have to config it by hand since the 7E doesn't have layout editor. I can provide instructions if you need them.
You can also set alerts for both the voltage and RSSI levels. That's how I use it on my 10.
There's no room store any more telemetry values on the 7E in my test code. I had to turn some of them off in order to get it to fit already. So you can't get anything that requires keeping a value around, like a count or min/max/etc. I'm loathe to do much tailoring for the 7E until it's it's mostly sorted out. After that, we can revisit the list and decide how to squeeze it down to the 7E.
- petr512p
12 Oct 2015 04:28 #38754
by petr512p
Replied by petr512p on topic Frsky compatibility
Prompt it was succeeded to connect X4R-SB to CC2500?
- Arakon
12 Oct 2015 04:31 #38755
by Arakon
Replied by Arakon on topic Frsky compatibility
No. The protocol has not been fully decoded yet.
- blackmoon
12 Oct 2015 22:24 #38767
by blackmoon
Replied by blackmoon on topic Frsky compatibility
Does anyone uses this high precision variometer with their Devo+Frsky ?
www.hobbyking.com/hobbyking/store/__4231...cision_Version_.html
Or his little brother :
Thank you.
Thank you.
- jry
14 Oct 2015 19:40 #38816
by jry
Yes, it works fine with my testing code and CC2500. D16 protocol is clear, we can write both TX and RX including telemetry. There is one unknown value but it doesn't look critical for RX/TX communication.
petr512p wrote: Prompt it was succeeded to connect X4R-SB to CC2500?
- Fernandez
15 Oct 2015 12:32 #38860
by Fernandez
Super !!!
Missing value could it be for setting of the failsave of the Tx, I requested that also for the excisting Frsky protocol.
With mh Frsky DHT-U I can set failsave from my tranmitter over the air (no need to use a pencil in the rx to set failsave), but with deviation the set failsave feature from Tx is missing.
So it must be somehere in the protocol.
Time to create page: 0.265 seconds
- Frsky compatibility
