V202 protocol
21 May 2014 20:15 #23479 by victzh
Replied by victzh on topic V202 protocol
Man can dream! If you find anything, please share. I also have an Aviator YK016 which is another clone. I can try it as well.
22 May 2014 14:08 #23497 by warewolf75
Replied by warewolf75 on topic V202 protocol
i have a wltoys v212 and deviation 4.0.1 on devo7e, suprisely it really goes smoother but if i put the throttle more than 50% and the aileron or elev more than 95% it flips, is there any thing to do about that? sounds like it not made for that or i do nat have the right adjustement on tx, or maybe the board is made like that? i would like to do loops, not flips.
and id like to know, the nightly buit does it work the same as deviation ?
im new in quads and mods, but i do my own things, can anybody help me ?
22 May 2014 14:37 #23498 by skyjet
Replied by skyjet on topic V202 protocol
I don't know if this will help anybody else with the 2X2 protocol with the NRF24L01 module in the Devo 10 or not but my problems were solved by putting a 3 cell lipo battery in my Devo 10. I set the low voltage warning to 11.1V. Now I will always operate my radio above 11.1 volts.
skyjet wrote:
Daryoon wrote: Yeah, there is possibly a bad batch of NRF24L01 with PA boards out there.
The best source? If you have more than one of those stock TX that came with your WLToys quad. Grabbing the module out of there is a good way IMHO.
Thanks! I see a lot of complaints here with the 2X2 protocol with a Devo 10. Does anybody here have a Devo 10 with the 2X2 protocol that doesn't have any problems?
22 May 2014 14:43 #23499 by warewolf75
I have a devo7e and a 7.4v 2 cell lipo, at what voltage do i need to adjust my tx warning ?
22 May 2014 15:12 #23500 by skyjet
7.4 At full charge the battery will be around 8.4V
22 May 2014 15:16 #23501 by warewolf75
so i should set the alarm to 7.4v ?
22 May 2014 15:54 #23504 by IMback!
Replied by IMback! on topic V202 protocol
A discarged 2s lipo would have about 7.2v, but if i where you i would not push 8.4v thrugh a circut thats only meant to handle about 6V.
22 May 2014 16:34 #23505 by warewolf75
IMback! wrote: A discarged 2s lipo would have about 7.2v, but if i where you i would not push 8.4v thrugh a circut thats only meant to handle about 6V.
but the deviation program says that it can be set to more voltage so i could use a 7.4 lipo ?
22 May 2014 17:58 #23507 by timmyd463229
Replied by timmyd463229 on topic V202 protocol
I have a v272 I just got yesterday and I'm waiting for parts to wire in the module for it in my devo 10 could anyone help me out with what setting I'll need to get this thing flying ....deviation settings are confusing lol since coming from a dx6i ...thanks
23 May 2014 00:35 #23511 by Daryoon
Replied by Daryoon on topic V202 protocol
You can always try the Standard GUI instead of the Advance GUI. Deviation defaults to the Advanced.
23 May 2014 17:23 #23534 by timmyd463229
Yeah I didn't think of that do you know what channel makes it go into flip mode
23 May 2014 19:04 #23537 by Daryoon
It depends on the quad and what the manufacturer programmed the FC to do.
Some quad will be in flip mode at 100% rates. Just move the stick to the full deflection to flip in that direction.
While others will required a channel activated. I believe the v202 protocol has channels 5-8 enabled in the Deviation firmware. You can check to see what toggling each does.
I don't have the v272 to check for you.
23 May 2014 19:32 #23538 by victzh
Channel 6 is autoflip for V2x2.
24 May 2014 00:27 #23548 by timmyd463229
OK thanks daryoon once I get the module in I'll try it out ....thanks for answering all my dumb questions lol
24 May 2014 00:28 #23549 by timmyd463229
OK cool thanks a lot man
26 May 2014 14:45 - 26 May 2014 14:45 #23632 by Daryoon
@warewolf75
Victzh replied below about the v2xx protocol using channel 5 for flipping.
So enable that and bind it to a toggle switch to see if you can disable auto flipping.
Otherwise, you'll have to set up multiple rates. For instance, set up a switch so that when toggled, you're not able to go past the 95% rate that causes the autoflip routine to activate.
Last edit: 26 May 2014 14:45 by Daryoon.
29 May 2014 02:57 #23738 by timmyd463229
i was on massiverc site and seen a config file for the v212 and it says fmod is flips and dual rates does that mean it just swithes the v212 into 100% rates so it can flip and having it off is like below 95% or is it actually putting it in flip mode like the v272 tx
29 May 2014 19:26 - 29 May 2014 19:29 #23752 by jason4207
Replied by jason4207 on topic V202 protocol
I wrote the original V2x2 config file that was on Massive's site. Not sure if it has been updated since then.
Can you link to where it's currently at on his site? I just spent a good hour looking for it in vein. Been a while since I saw it there.
With all V2x2 quads the flip is initiated by activating CH6 and then hitting 100% on the stick. Ch5 is for LED control.
Certain V2x2 stock Tx's have CH6 always activated and so all that is needed is 100% stick input to initiate the flip routine, and other V2x2 stock Tx's use a separate button for Ch6 control. Either way the flip control is CH6 + 100% stick input in the protocol.
On Devo we have full control. We can keep rudder at 100% rate no matter what we set for the other rates. We can trigger Ch6 (flips) however we like; simultaneously with 100% AIL/ELE stick input or using any switch/button on the Tx or even some other creative way if you like or even fully disable it even though rates are 100%.
Here's some useful info from earlier in this thread:
deviationtx.com/forum/protocol-developme...ocol?start=100#11855
Last edit: 29 May 2014 19:29 by jason4207.
29 May 2014 23:02 #23755 by timmyd463229
jason4207 wrote: I wrote the original V2x2 config file that was on Massive's site. Not sure if it has been updated since then.
www.massiverc.com/PrestaShop/en/115-wl-t...nf-alien-canopy.html
OK thank you for the help ...yeah I really would like to be able yo fly 100% without flipping unless I want it to ...so if I want to use a switch I have to go to channel six and assign a switch to that channel and make the scale 100 and that's its?
31 May 2014 12:36 #23782 by jdoo
Replied by jdoo on topic V202 protocol
That is exactly it. I assigned FMOD1 ( top right switch on my Devo10 ) to channel 6, and when it's in position - get flips on my V222 at 100% throws. Moving the switch away from that position -- and can go full 100% throws with no flipping!
Time to create page: 0.214 seconds
