Alarme Devo when not used
19 May 2013 21:35 #10114 by Franck
Alarme Devo when not used was created by Franck
Is it possible to implement an adjustable alarm when the radio is not used? to avoid emptying the batteries!
19 May 2013 22:24 #10115 by PhracturedBlue
Replied by PhracturedBlue on topic Alarme Devo when not used
This has already been done, and is available in the nightly builds thanks to DomCars.
20 May 2013 06:57 #10129 by Franck
Replied by Franck on topic Alarme Devo when not used
PhracturedBlue wrote: This has already been done, and is available in the nightly builds thanks to DomCars.
Parles tu de « Power-down alert: » ? Moi je recherche une alarme quand on oubli d’éteindre la radio.
Translation
Are you talking about "Power-down alert:"? I'm looking for an alarm when you forget to turn off the radio. Sorry for my English.
  • rbe2012
  • rbe2012's Avatar
20 May 2013 07:58 #10131 by rbe2012
Replied by rbe2012 on topic Alarme Devo when not used
No, there is implemented an alert when the tx is not used (no movement of the sticks) for (configurable) 1 to 60 minutes. You can find it in the tx configuration menu (called "Power On Alarm").
20 May 2013 09:18 #10135 by Franck
rbe2012 wrote: No, there is implemented an alert when the tx is not used (no movement of the sticks) for (configurable) 1 to 60 minutes. You can find it in the tx configuration menu (called "Power On Alarm").
I don't find it :huh:
  • rbe2012
  • rbe2012's Avatar
20 May 2013 09:55 #10136 by rbe2012
It is in the nightly build since a few days (about a week), not in the regular code. I attached a screenshot from Devo12:
20 May 2013 12:22 #10143 by Franck
rbe2012 wrote: It is in the nightly build since a few days (about a week), not in the regular code. I attached a screenshot from Devo12:
YES ! but i don't have this option on my DEVO 8 ... :unsure:
  • rbe2012
  • rbe2012's Avatar
20 May 2013 13:09 #10147 by rbe2012
Checked with Devo8 emulator: it is present at the same location. Which build do you use (please look at USB page, you will see something like "devo8-v3.0.0-XXXXXXX - theses 'X' are interesting)?
As PB has written above it is not in the regular 3.0.0 version, but it will be included in the next release.
20 May 2013 13:19 #10148 by Franck
rbe2012 wrote: Checked with Devo8 emulator: it is present at the same location. Which build do you use (please look at USB page, you will see something like "devo8-v3.0.0-XXXXXXX - theses 'X' are interesting)?
ok I'll wait for the update. The emulator does not work for me, I get errors ...
20 May 2013 13:21 #10149 by vlad_vy
Replied by vlad_vy on topic Alarme Devo when not used
  • rbe2012
  • rbe2012's Avatar
20 May 2013 17:00 #10158 by rbe2012
Franck wrote: ... The emulator does not work for me, I get errors ...
Have you only errors concerning the DLLs? Then please read this: you-need-these-dlls
20 May 2013 18:08 #10160 by Franck
Not *Dll
Brightness: 1
Wait Release
Released
Wait Press
Pressed
Wait Release
Released
Failed to parse Model file: models/model1.ini
Brightness: 5
Contrast: 5
Couldn't open font file: media/.fon
ERROR: Could not read media/sound.ini
DEBUG: LCD_DrawWindowedImageFromFile: Image not found: media/devo8.bmp
DEBUG: LCD_DrawWindowedImageFromFile: Image not found: media/options.bmp
Could not locate character U-004d
Could not locate character U-006f
Could not locate character U-0064
Could not locate character U-0065
Could not locate character U-006c
Could not locate character U-0031
DEBUG: LCD_DrawWindowedImageFromFile: Image not found: modelico/heli.bmp
Could not locate character U-0020
Could not locate character U-0035
Could not locate character U-002e
Could not locate character U-0030
Could not locate character U-0056
DEBUG: LCD_DrawWindowedImageFromFile: Image not found: media/txpower.bmp
Brightness: 0
  • rbe2012
  • rbe2012's Avatar
20 May 2013 18:38 #10161 by rbe2012
This looks as if the file system you use is not correct. You should have a structure like this:
├───filesystem
│   └───devo8
│       ├───media
│       ├───template
│       ├───models
│       ├───modelico
│       ├───language
│       └───tx.ini
└───emu_devo8.exe
When you look at the USB drive you will only see the tx.ini and the directories media, template, models, modelico and language.
For the emulator the above shown structure is necessary.
If you create this, the "file not found" issues should be gone.
20 May 2013 19:03 #10163 by Franck
there is that in my devo
emu_devo8.exe is in my pc with dll
It is correct ?
20 May 2013 19:06 #10164 by heliaddict
Replied by heliaddict on topic Alarme Devo when not used
How exactly does the "power on alarm" work? I have tested on Devo 7e and set to 1mn - should the alarm activate after 1 minute? Nothing happens on mine, am I missing something?
20 May 2013 19:06 #10165 by FDR
Replied by FDR on topic Alarme Devo when not used
No, the 5 directories and 2 files of your first picture should be under the filesystem/devo8/ directory, i.e. 2 dirs deeper then in the tx.
20 May 2013 19:17 #10166 by Franck
FDR wrote: No, the 5 directories and 2 files of your first picture should be under the filesystem/devo8/ directory, i.e. 2 dirs deeper then in the tx.
OK ! I thought changing the settings of the remote, with the pc
20 May 2013 19:41 #10167 by domcars0
Replied by domcars0 on topic Alarme Devo when not used
heliaddict wrote: How exactly does the "power on alarm" work? I have tested on Devo 7e and set to 1mn - should the alarm activate after 1 minute? Nothing happens on mine, am I missing something?
If you don't touch anything during 1mn .... then the alarm must beep.
In fact "Power On alarm" is not a very good name... It's an "Idle TX Alarm"...
  • rbe2012
  • rbe2012's Avatar
20 May 2013 19:52 #10169 by rbe2012
It does on my Devo8. It is important not to move the sticks for one minute (or the selected time). Every movement resets the timer.
20 May 2013 20:43 #10172 by heliaddict
It's not working for me and have not touched anything. Have tried copying new filesystem and protocol again but still nothing. Has anyone else confirmed this working on Devo 7e? Are there any other setting that need changing? Yes I think TX idle alarm would be a better name.
Time to create page: 0.554 seconds
