HiSKY protocol
- blackmoon
29 Sep 2013 13:01 #14134
by blackmoon
Replied by blackmoon on topic HiSKY protocol
Nice to hear that it binds.
For the throttle issue, the default for hisky + ht8 is throttle channel reversed.
Don't know what they had in mind when they developed it like that...
Try to switch throttle channel to normal on your model file and see what happens.
- SeByDocKy
29 Sep 2013 17:06 #14136
by SeByDocKy
Replied by SeByDocKy on topic HiSKY protocol
Ok
I inverted the throttle, working better but still got some pb "strafing" left/right ....
I will wait an expert of config file to do the job
- panosnl
29 Sep 2013 17:12 - 29 Sep 2013 17:13 #14137
by panosnl
Replied by panosnl on topic HiSKY protocol
Last edit: 29 Sep 2013 17:13 by panosnl.
- victzh
29 Sep 2013 18:13 #14138
by victzh
Replied by victzh on topic HiSKY protocol
@panosnl, probably it can be used, but the chance is it has Beken chip, not nRF24L01. It's not bad by itself - our code supports Beken, and original modules from V202 work in Devo. Also, I am not sure about Power Amplifier, but judging by the metallic case, it has it.
You need to figure out the pinout, though. You're lucky - metallic case is not soldered, just has bent tabs. If you could make a detailed photo of insides, I can guide you in this.
Another option is a module from eBay for $5-7. Pay attention to Power Amplifier, search for "nRF24L01 PA".
- blackmoon
29 Sep 2013 19:08 #14141
by blackmoon
Can you describe the issues, and what does "strafing" means for you ?
Maybe in french if you can't explain it better, so I can understand it clearer.
(J'espère que je me suis fait comprendre
Thx.
SeByDocKy wrote: Ok
...but still got some pb "strafing" left/right ....
Thx.
- SeByDocKy
29 Sep 2013 21:16 #14142
by SeByDocKy
avancer/reculer ne marche pas encore bien ...
blackmoon wrote:
SeByDocKy wrote: Ok
(J'espère que je me suis fait comprendre)
Thx.
- blackmoon
29 Sep 2013 22:19 - 29 Sep 2013 22:20 #14144
by blackmoon
Ok if I understood it correctly, it binds, it flies but it isn't as smooth as with the HT8 module or RTF transmitter.
Maybe something to do with the protocol rather than with the model file ?
Could you link (or post it here) to the model file you are using ?
Last edit: 29 Sep 2013 22:20 by blackmoon.
- victzh
29 Sep 2013 23:59 #14146
by victzh
I ordered the second Q-BOT (I hesitate to use the first - I may still need it for verification of various aspects of the protocol implementation, and it takes hours to solder to it), so I will be able to test it but no sooner than HobbyKing's packages comes.
- MassiveOverkill
30 Sep 2013 00:06 - 30 Sep 2013 00:07 #14147
by MassiveOverkill
Replied by MassiveOverkill on topic HiSKY protocol
What do you need Victor? I have the Qbot. JX6 TX and the HiSky module.
Last edit: 30 Sep 2013 00:07 by MassiveOverkill.
- SeByDocKy
30 Sep 2013 06:00 #14153
by SeByDocKy
I am using this one ....
- victzh
30 Sep 2013 06:11 #14154
by victzh
@MassiveOverkill do you have Q-BOT or Q-BOT mini? I don't know whether they use the same protocol - no info on HobbyKing's site, only one is coming with HiSky HT-8 (mini, which I have and used) and another is with its own 4-ch TX.
To make a reasonable model file and to test the protocol implementation usability I need Q-BOT mini.
- blackmoon
30 Sep 2013 09:01 #14158
by blackmoon
The "normal" Q-BOt is a (if not mistaken) re-brand of WLToys V929 and so uses the Flysky protocol.
Only the mini uses the Hisky-FBL100 protocol.
- blackmoon
30 Sep 2013 09:26 #14159
by blackmoon
Try this one (adapted from gordonzo FBL80 model file), careful I didn't test it.
The one you linked had some weird pitch values.
Check for protocol name, I edited the file and put FBL100 as protocol, because I don't know how it translates in the software.
Maybe Throttle should be put to normal also...
SeByDocKy wrote: I am using this one ....
- MassiveOverkill
30 Sep 2013 11:05 #14161
by MassiveOverkill
The smaller direct-drive micro quad that's the same size as the V202, not the gear-driven larger mini quad that's the same size as the V212, which others have stated just uses the FlySky protocol.
- victzh
- MassiveOverkill
30 Sep 2013 13:18 #14168
by MassiveOverkill
So you just needed the quad or the board or more? I put the board on a Frankenquad frame.
victzh wrote: Yes, this one.
- victzh
30 Sep 2013 14:28 #14171
by victzh
That would be great, as soon as it flies from the stock controller. I have everything else for it - code to test on Devo and my own HT-8 to compare it with.
- SeByDocKy
30 Sep 2013 17:14 #14172
by SeByDocKy
No it doesn't work .... (same as I had in fact)
In fact I got unique pb. when press right stick forward (mode 2), the heli seems to backwared and vice and versa. If I invert this one now the it's inverted left/right on thr right stick. Both seems to be linked and I know nothing in profil .... (don't have time to read the doc)
- panosnl
30 Sep 2013 18:16 - 30 Sep 2013 18:17 #14179
by panosnl
Last edit: 30 Sep 2013 18:17 by panosnl.
- victzh
30 Sep 2013 19:41 #14181
by victzh
@panosnl, it sucks. nRF24LE1 is an integrated 8051 MCU and nRF24L01 RF. So the protocol is implemented inside of this integrated chip and its pinout is specific for the rest of the V922 TX. No way to use it in Deviation.
I'd recommend you to buy the following one: www.elecfreaks.com/store/nrf24l01p-pa-lna-v31-p-142.html
or something else based on nRF24L01+ (pay attention to the plus at the end). It is a bit more future-(and past)-proof. It support all the bitrates of nRF24 family. You need an antenna for this chip, if you remove the connector you can use your antenna from V922 TX, or you can buy 2.4GHz antenna on that site (and on many others).
Time to create page: 0.235 seconds
- HiSKY protocol
