New Hubsan Upgraded Version on the way
27 Dec 2013 22:43 #17187 by Daryoon
Replied by Daryoon on topic New Hubsan Upgraded Version on the way
Got it.
I went into the menu and keep trying frequencies until I found one that works. :)
So right now, my devo7e is controlling the X4FPV, while the video is displayed on the Hubsan TX.
27 Dec 2013 22:48 - 27 Dec 2013 22:48 #17189 by goebish
Replied by goebish on topic New Hubsan Upgraded Version on the way
good news, it's on with a default frequency at power up !
should be very easy to hack :)
what's the default frequency ?
Last edit: 27 Dec 2013 22:48 by goebish.
27 Dec 2013 22:59 #17193 by Xermalk
Replied by Xermalk on topic New Hubsan Upgraded Version on the way
The default frequency on the hubsan seem to vary somewhat, between 5725 and 5780. Probably to reduce the chance of disturbing another hubsan in the air.
27 Dec 2013 23:05 #17194 by goebish
Got it, that's too easy, on the 0x40 tx frames, bb and cc bytes are the frequency in MHz:
eg: in your dump, the last frequency you set is 0x1694 = 5780 !!!
I'll now build a firmware that tries to set it to 5900MHz :)
27 Dec 2013 23:11 #17196 by Daryoon
Cool. The highest frequency is 5945mhz. Then the next step rolls back to 5725MHz.
27 Dec 2013 23:13 #17197 by Xermalk
/prays for a 5885 , 5905 or 5945 frequency version when i wake up tomorrow.
27 Dec 2013 23:25 - 27 Dec 2013 23:26 #17198 by goebish
I just built a firmware for Devo 7e/5945MHz but there's something I'm not sure.
I've a Devo 10 and it only needs the .dfu file, I think I understand the 7e needs a .dfu and 1 .bin file per used protocol ?
Which file(s) should I post ?
Last edit: 27 Dec 2013 23:26 by goebish.
27 Dec 2013 23:28 - 27 Dec 2013 23:40 #17199 by goebish
Tell me if this is OK (.dfu + every .bin, built for Devo 7):
speedy.sh/UDGYV/deviation.zip
If it works it should set the frequency to 5945
Last edit: 27 Dec 2013 23:40 by goebish.
27 Dec 2013 23:37 - 27 Dec 2013 23:41 #17203 by Xermalk
Is that for the 7e? I no longer have the module in my 7. Its installed in my Devo 10.
Edit: And whats with the download manager? I refuse to install download managers to download a file.
please attache the files to the post, or use a better filehost.
Last edit: 27 Dec 2013 23:41 by Xermalk.
27 Dec 2013 23:39 - 27 Dec 2013 23:40 #17205 by goebish
Here it is for Devo 10, please don't forget it's just a test version, have a backup of your firmware and config files ready !
speedy.sh/f8wEk/devo10.dfu
27 Dec 2013 23:41 #17206 by Daryoon
That doesn't look right. If you download one of the Devo7e firmware. You'll see the structure that gets outputted.
I get a .zip file that contains the dfu and a folder call /protocol
Within that folder are each of the protocol with the .mod extension. No .bin.
27 Dec 2013 23:42 - 27 Dec 2013 23:43 #17207 by Xermalk
found the hidden link to not use the crappy download manager.
Ill see if i have a battery charged.
What firmware version is the protocol for? I'm running ca2fa01 right now.
Last edit: 27 Dec 2013 23:43 by Xermalk.
27 Dec 2013 23:42 #17208 by Daryoon
Xermalk wrote: Is that for the 7e? I no longer have the module in my 7. Its installed in my Devo 10.
LOL
I know. But I found out that if you click on the title at the top. You can download directly without needing to install the download manager. :)
27 Dec 2013 23:44 #17209 by goebish
Daryoon wrote: That doesn't look right. If you download one of the Devo7e firmware. You'll see the structure that gets outputted.
Sorry, I don't know how the Devo 7 works, here's the protocol folder with mod files:
speedy.sh/Qb36Z/protocol.zip
27 Dec 2013 23:46 - 27 Dec 2013 23:47 #17211 by goebish
Xermalk wrote: What firmware version is the protocol for? I'm running ca2fa01 right now.
latest dev sources, rev 2039.
Last edit: 27 Dec 2013 23:47 by goebish.
27 Dec 2013 23:51 #17212 by Daryoon
The video seems to be coming in at 5815MHz for me.
27 Dec 2013 23:52 - 27 Dec 2013 23:54 #17213 by Xermalk
Daryon, try rebinding and se if its always 5815.
And holy crap dfuse 2.0 sucks, 4 minutes just to get past the erase phase ? *shudders* i need to locate a download for 1.5.
I normally have a full firmware flash done in under a minute in my vm machine. but i don't have access to it right now.
Last edit: 27 Dec 2013 23:54 by Xermalk.
27 Dec 2013 23:54 #17214 by Daryoon
Tried a bunch of rebind. And it's always 5815.
Actually, I can switch to the neighboring frequencies...5800, 5805, 5810 and 5815. But 5815 seems to be the strongest.
27 Dec 2013 23:55 #17215 by goebish
Daryoon wrote: Tried a bunch of rebind. And it's always 5815.
Ok was 5815 the default frequency when you used your previous firmware ?
27 Dec 2013 23:55 - 27 Dec 2013 23:56 #17216 by Xermalk
There's always some bleeding on video frequencies. That's why you never use similar frequencies when you fly.
The fact that its constant though is a very very good step forward.
@ goebish 5815 is outside the default frequencies when binding.
Last edit: 27 Dec 2013 23:56 by Xermalk.
Time to create page: 0.040 seconds
