New Hubsan Upgraded Version on the way
- goebish
- NRF Weirdo
29 Dec 2013 14:27 - 29 Dec 2013 14:30 #17401
by goebish
Replied by goebish on topic New Hubsan Upgraded Version on the way
Looks like it is... and I wouldn't be surprised to find gyro/acc data (could be useful for an osd) and other interesting debug values in the frames
Last edit: 29 Dec 2013 14:30 by goebish.
- Xermalk
29 Dec 2013 16:16 #17405
by Xermalk
Replied by Xermalk on topic New Hubsan Upgraded Version on the way
- SeByDocKy
29 Dec 2013 16:41 #17407
by SeByDocKy
Replied by SeByDocKy on topic New Hubsan Upgraded Version on the way
Great job everyone too
Hope it will be included in a next NB realease ...
- goebish
- NRF Weirdo
29 Dec 2013 16:46 #17408
by goebish
Look like vTX frequency selection is already in the latest nightly (12/29).
- SeByDocKy
29 Dec 2013 16:49 #17409
by SeByDocKy
HoHo,
I will test with my H102D too
- goebish
- NRF Weirdo
29 Dec 2013 16:50 #17410
by goebish
Oh yes please
- SeByDocKy
29 Dec 2013 16:55 #17411
by SeByDocKy
You have to add some new section in the corresponding model.ini ?
goebish wrote: Oh yes please
- goebish
- NRF Weirdo
29 Dec 2013 16:58 #17412
by goebish
You can :...but there's a vTX frequency setting menu.
on My Devo 10 I've to go to Model Menu -> Model Setup -> then click the protocol name (Hubsan4).
[protocol_opts]
vTX MHz=5885on My Devo 10 I've to go to Model Menu -> Model Setup -> then click the protocol name (Hubsan4).
- SeByDocKy
29 Dec 2013 17:07 #17414
by SeByDocKy
Good news .... Seems also to work with my Heli H102D.
With this helicopter, you can activate from the TX recording on sd-card located on the Heli. So I guess this information is transmitted in a specific channel
goebish wrote: You can :
...but there's a vTX frequency setting menu.[protocol_opts] vTX MHz=5885
- goebish
- NRF Weirdo
29 Dec 2013 17:08 - 29 Dec 2013 17:09 #17415
by goebish
If you have a logic analyzer and are willing to open your radio and solder 4 wires I'm pretty sure we can crack the SD recording feature in no time
Last edit: 29 Dec 2013 17:09 by goebish.
- goebish
- NRF Weirdo
29 Dec 2013 17:11 - 29 Dec 2013 17:17 #17416
by goebish
... as this is a single on/off feature I suspect it could be a bit to set in "jj" bytes, just like for leds and flips feature.
If you're OK I'll make you test a few firmwares to check this possibility once I'm done with the H107D telemetry (haven't started to code).
Last edit: 29 Dec 2013 17:17 by goebish.
- SeByDocKy
29 Dec 2013 17:13 #17417
by SeByDocKy
I just ordered it .... Will receive it within 2 weeks.
Ok great new also ... when I changing the vTX value on the devo, it's applying directly on the heli
and with my Hubsan FPV TX i just adapted to chosen frequency. So Great job
(je crois que tu es français)
goebish wrote: If you have a logic analyzer and are willing to open your radio and solder 4 wires I'm pretty sure we can crack the SD recording feature in no time
- goebish
- NRF Weirdo
29 Dec 2013 17:13 #17418
by goebish
oui
- SeByDocKy
29 Dec 2013 17:17 #17419
by SeByDocKy
Sure ....
goebish wrote: ... as this is a single on/off feature I suspect it could be a bit to set in "jj" bytes, just like for leds and flips feature.
If you're OK I'll make you test a few firmwares to check this possibility after I'm done with the H107D telemetry (haven't started to code).
Sure ....
- midelic
29 Dec 2013 19:13 - 29 Dec 2013 19:13 #17424
by midelic
Replied by midelic on topic New Hubsan Upgraded Version on the way
goebish,
some quick code in arduino maybe it can help for devo
unsigned long pause;
uint8_t x;
uint8_t y;//vlipo
pause=micros();
_spi_strobe(0xA0);//std-by
write_packet();//all data sent packets go here
_spi_strobe(0xD0);//Strobe TX
while(1){
x=_spi_read_adress(0x00);//read mode register(0x00) 0x40 adress
if(! (x & 0x01))//
break;//if 1A break
_spi_strobe(0xC0);//Strobe RX
while((micros()-pause)<10000){//timing 10ms
x=_spi_read_adress(0x00);//40-19
if(x & 0x01){// 0x19
continue;
else{
Read_packet();//if 0x18 read packet all read packets go here
y=packet[13];//nn
Last edit: 29 Dec 2013 19:13 by midelic.
- SeByDocKy
29 Dec 2013 19:15 #17425
by SeByDocKy
A picture of the VTX of the Hubsan H102D.... When I will receive the logic analyser, you will tell me where to plug
- SeByDocKy
29 Dec 2013 19:15 #17426
by SeByDocKy
- goebish
- NRF Weirdo
29 Dec 2013 19:33 - 29 Dec 2013 19:34 #17427
by goebish
You don't need to plug on the vRX module, but on the spi bus between the mcu and the a7105 RF chip, will require another picture.
SeByDocKy wrote: A picture of the VTX of the Hubsan H102D.... When I will receive the logic analyser, you will tell me where to plug
Last edit: 29 Dec 2013 19:34 by goebish.
- goebish
- NRF Weirdo
29 Dec 2013 19:37 #17428
by goebish
But can you take an HD picture of this vRX ? I'm interested in the pinout but can't read in your picture (too blurry), I'd like to know if it use serial or i2c or anything else...
- HappyHarry
29 Dec 2013 20:13 #17431
by HappyHarry
Replied by HappyHarry on topic New Hubsan Upgraded Version on the way
guys i'm being given an H107L as a late christmas present and i'm wondering is it possible to pull the a7105 module from the stock tx? or will i need to order one elsewhere? if so any reccomendations?
thanks in advance
thanks in advance
Time to create page: 0.827 seconds
- New Hubsan Upgraded Version on the way
