New Hubsan Upgraded Version on the way
29 Dec 2013 20:17 #17432 by goebish
Replied by goebish on topic New Hubsan Upgraded Version on the way
HappyHarry wrote: guys i'm being given an H107L as a late christmas present and i'm wondering is it possible to pull the a7105 module from the stock tx? or will i need to order one elsewhere? if so any reccomendations?
thanks in advance
There's no module in the H107L TX, you'll have to find another one, search ebay for a7105-500m for example.
29 Dec 2013 22:12 #17437 by HappyHarry
Replied by HappyHarry on topic New Hubsan Upgraded Version on the way
thanks for the info, i take it the chip is hardwired into the main pcb then?
29 Dec 2013 22:30 - 29 Dec 2013 22:32 #17439 by SeByDocKy
Replied by SeByDocKy on topic New Hubsan Upgraded Version on the way
Sorry, I inserted the wrong photo
Last edit: 29 Dec 2013 22:32 by SeByDocKy.
29 Dec 2013 22:41 - 29 Dec 2013 22:41 #17440 by HappyHarry
n/m
Last edit: 29 Dec 2013 22:41 by HappyHarry.
29 Dec 2013 23:20 #17442 by goebish
SeByDocKy wrote: Sorry, I inserted the wrong photo
We can't see the traces, they must be underneath the 2.4 RF module, if you have a multimeter with fine tips you'll have to find the connections from the a7105 chip sdio, sck and scs to the module header pins.
29 Dec 2013 23:31 #17443 by SeByDocKy
Compare to your scheme and my photo, the point is located on top right. So there is a rotation of +90 deg.... I think it's easy to find all those pins :)
29 Dec 2013 23:38 #17444 by goebish
Yes, they are easy to find on the chip, now you've to trace the 3 interesting pins to their corresponding pins on the module header
Unless you want to try to solder wires directly on the QFN chip :P
30 Dec 2013 07:43 #17461 by SeByDocKy
goebish wrote: Yes, they are easy to find on the chip, now you've to trace the 3 interesting pins to their corresponding pins on the module header
My next question concerning the logic analyser... I think I will have only female/female wire .... I need some female/male or some female/mini-croco :)
30 Dec 2013 07:47 - 30 Dec 2013 07:47 #17462 by midelic
Replied by midelic on topic New Hubsan Upgraded Version on the way
Come on!
Lol!
Last edit: 30 Dec 2013 07:47 by midelic.
30 Dec 2013 07:58 #17463 by Xermalk
Replied by Xermalk on topic New Hubsan Upgraded Version on the way
From Rcgroups Hubsan 107D thread.
"got it to work, by soldering 2 wires on the + and - of the VTX board, and the main + and - of the battery cable of the TX.
It's working but at 5860 MHZ only !! At least, I have it working ! I was desperating having it to work..
Now, it's heating a little bit, but it works."
Apparently the video tx module works just fine with only the power wires connected, unfortunately not on a boscam frequency.
30 Dec 2013 09:46 #17468 by goebish
I'll try to understand how to set the frequency once I have one.
That's weird, in SeByDocKy's picture I can see CS0, CS1 and CS2 on the vRX, just as if it was a "classic" 8 channels vRX.
30 Dec 2013 09:56 #17469 by SeByDocKy
Here is the A7105 module of the H102D and in the general for the first generation of FPV TX of hubsan product
For the 3 CS pins ... it's strange coz in fact, I can also select a channel with +5Mhz increment ....
30 Dec 2013 09:57 #17470 by goebish
A few wire scraps will be OK, no need to buy anything else.
30 Dec 2013 10:00 #17472 by goebish
SeByDocKy wrote: Here is the A7105 module of the H102D and in the general for the first generation of FPV TX of hubsan product
I wonder why they removed the RF amp in the newer versions ...
30 Dec 2013 10:02 #17473 by SeByDocKy
I think I will be able to use directly the female connecor on the pin .. there is enough space I guess
30 Dec 2013 10:03 #17474 by SeByDocKy
Coz it's for a nanoquad.... My TX was designed for spyhawk plane which have something link 500m of control range.
30 Dec 2013 10:06 #17475 by goebish
Does the H102D have telemetry ?
I'm working on it now and should have something to test soon.
30 Dec 2013 10:36 #17476 by goebish
HappyHarry wrote: thanks for the info, i take it the chip is hardwired into the main pcb then?
Yes:
30 Dec 2013 11:03 #17477 by SeByDocKy
goebish wrote: Does the H102D have telemetry ?
No telemetry :( but maybe everything is here and with your work maybe we can expect a miracle ....
30 Dec 2013 19:24 - 31 Dec 2013 00:11 #17497 by goebish
I'm currently trying to implement telemetry and I'm having an issue, I can control the quad for a few seconds (random, 1s-15s maybe) then motors stop and controls stop working.
I only have a H107L but adding telemetry shouldn't change anything for it.
Here's my code, I hope an A7105 expert (PB, Midelic ?) can help to debug, I've probably overlooked something obvious..
from hubsan_cb():
case DATA_1:
case DATA_2:
case DATA_3:
case DATA_4:
case DATA_5:
    if( txState == 0) // send frame
        if(state == DATA_1)
            A7105_SetPower(Model.tx_power); //Keep transmit power in sync
        hubsan_build_packet();
        A7105_Strobe(A7105_STANDBY);
        A7105_WriteData(packet, 16, state == DATA_5 ? channel + 0x23 : channel);
        if (state == DATA_5)
            state = DATA_1;
        else
            state++;
        delay=3000;
    else
        if( txState == 1) // switch to rx mode 3ms after packet sent
            A7105_Strobe(A7105_RX);
            A7105_Strobe(A7105_RX); // 0xc0 appears twice in the dump
        for( i=0; i<20; i++)
            if(!(A7105_ReadReg(A7105_00_MODE) & 0x01)) // data received ?
                A7105_ReadData(packet, 16); // A7105_RST_RDPTR + 16x A7105_05_FIFO_DATA
                Telemetry.p.hubsan4.volt = packet[13];
                break;
        delay=1000;
    if (++txState == 8) // 3ms + 7*1ms
        txState = 0;
    return delay;
If I remove A7105_ReadReg(A7105_00_MODE) and following instructions in the if block there's no problem anymore.
I'm pulling my hair (or what remains of it).
... and I don't even know if it actually grabs telemetry data during the few seconds it works because I do not have a H107D.
Anyone with one wants to try a build ? :P
Last edit: 31 Dec 2013 00:11 by goebish. Reason: typo
Time to create page: 0.549 seconds
