New Hubsan Upgraded Version on the way
03 Jan 2014 13:31 #17836 by goebish
Replied by goebish on topic New Hubsan Upgraded Version on the way
Ok, thanks to confirm.
03 Jan 2014 15:06 - 03 Jan 2014 15:49 #17841 by goebish
SeByDocKy wrote:
File Attachment:
File Name: model22.ini
File Size:8 KB
with this model, you can see how they use trim to acticate camera, etc...
Left Vertical Switch Up - Ch7 Momentary - Camera/AutoMissle/HoistA
Left Vertical Switch Down - Ch8 Momentary - Video/Missle/Sprayer/HoistB
Left Horizontal Switch Right - Ch5 Toggle - Toggle LEDs On/Off
Left Horizontal Switch Left - N/A
Here's a test build, so now the Hubsan protocol has 7 channels, (if channel 7 > 0, record video)
speedy.sh/WZhN6/deviation-devo7e-Unknown.zip
You'll have to configure this 7th channel, this template will assign video recording to the AIL DR1 switch (0=off, 1=on):
[channel7]
template=simple
[mixer]
src=AIL DR1
dest=Ch7
curvetype=expo
points=0,0
You'll have to figure out how to assign it to a trim button and find how to show an indicator on screen by yourself, I'm lazy, share your .ini section(s) when you get it working please :lol:
Last edit: 03 Jan 2014 15:49 by goebish.
03 Jan 2014 15:31 #17843 by goebish
03 Jan 2014 15:47 #17844 by SeByDocKy
Replied by SeByDocKy on topic New Hubsan Upgraded Version on the way
goebish wrote:
SeByDocKy wrote:
File Attachment:
File Size:8 KB
[channel7]
template=simple
[mixer]
src=AIL DR1
dest=Ch7
curvetype=expo
points=0,0
You'll have to figure out how to assign it to a trim button and find how to show an indicator on screen by yourself, I'm lazy, post your .ini section(s) when you get it working please :lol:
For instance ... it not working anymore ... :(
I added this part in the ini file
[channel7]
template=simple
[mixer]
src=Virt1
dest=Ch7
curvetype=zero/max
points=0
[trim1]
src=Virt1
pos=TRIMLV+
neg=None
step=193
value=-100,0,0
03 Jan 2014 16:02 #17845 by goebish
Does it work with the template I posted ?
03 Jan 2014 16:07 #17847 by SeByDocKy
goebish wrote: Does it work with the template I posted ?
no ...
03 Jan 2014 16:15 - 03 Jan 2014 16:17 #17848 by goebish
That's weird because when channel 7 is > 0 it does the same thing that with the previous firmware I sent you with the Extra option set to 0.
(set packet[9] bit 1)
Investigating ...
Last edit: 03 Jan 2014 16:17 by goebish.
03 Jan 2014 16:24 #17849 by SeByDocKy
goebish wrote: That's weird because when channel 7 is > 0 it does the same thing that with the previous firmware I sent you with the Extra option set to 0.
Investigating ...
I installed again the first version and it's working when value pass to "0" and stop to record when pass to "1'
Why you wrote "set packet[9] bit 1" and not 0 ?
03 Jan 2014 16:27 - 03 Jan 2014 16:29 #17850 by goebish
Can you do another test with the "Extra" build please ?
follow these steps exactly:
- don't bind (no battery in the quad)
- power on TX
- set Extra to 1
- power off TX
- plug battery
- bind
- set Extra to 0, wait a few seconds
- set Extra to 1
Does it work ?
Last edit: 03 Jan 2014 16:29 by goebish.
03 Jan 2014 16:31 - 03 Jan 2014 16:33 #17851 by goebish
SeByDocKy wrote: Why you wrote "set packet[9] bit 1" and not 0 ?
bit 0 if you prefer ( packet[9] |= 1<<0; )... LSB
Last edit: 03 Jan 2014 16:33 by goebish.
03 Jan 2014 16:31 #17852 by SeByDocKy
goebish wrote: Can you do another test with the "Extra" build please ?
- power on TX
- set Extra to 1
- power off TX
- plug battery
- bind
- set Extra to 1
Does it work ?
For sure it's working... As long extra is set to "1" no recording. I checked to keep it at "1"... nothing happened. Only when extra is set to "0"
03 Jan 2014 16:37 #17853 by goebish
Ok, and you confirm it works on the fly, you do not have to rebind to start video recording if Extra is not set to 0 when TX is powered on ?
03 Jan 2014 16:44 #17854 by SeByDocKy
goebish wrote: Ok, and you confirm it works on the fly, you do not have to rebind to start video recording if Extra is not set to 0 when TX is powered on ?
Yes I confirm ... Will upload a small video on YT
03 Jan 2014 16:47 #17855 by goebish
no problem, I trust you :p
03 Jan 2014 16:49 #17856 by SeByDocKy
goebish wrote: no problem, I trust you :p
In the case, I made an error :)
03 Jan 2014 16:58 #17857 by SeByDocKy
I am on devo 7E .... AIL DR1 is HOLD or FMOD ? (I tried all of them .. nothing worked)
03 Jan 2014 17:00 #17860 by goebish
lol, try another button if there's no AIL DR on your TX :p
In my template replace AIL DR1 with HOLD for example.
03 Jan 2014 17:07 #17861 by goebish
not HOLD, HOLD1:
[channel7]
template=simple
[mixer]
src=HOLD1
dest=Ch7
curvetype=expo
points=0,0
03 Jan 2014 17:18 - 03 Jan 2014 17:19 #17862 by vlad_vy
Replied by vlad_vy on topic New Hubsan Upgraded Version on the way
Probably you need to change two bits, set one to 1 and second to 0 and vice versa.
Last edit: 03 Jan 2014 17:19 by vlad_vy.
03 Jan 2014 17:19 - 03 Jan 2014 18:34 #17863 by goebish
I'm fairly sure it will work once SebyDocky have is config file right :)
Last edit: 03 Jan 2014 18:34 by goebish.
Time to create page: 1.512 seconds
