New Hubsan Upgraded Version on the way
03 Jan 2014 17:23 - 03 Jan 2014 17:24 #17864 by SeByDocKy
Replied by SeByDocKy on topic New Hubsan Upgraded Version on the way
goebish wrote: not HOLD, HOLD1:
[channel7]
template=simple
[mixer]
src=HOLD1
dest=Ch7
curvetype=expo
points=0,0
It's what I had ... :( and not working (yet) ....
I will make another small video ...
Last edit: 03 Jan 2014 17:24 by SeByDocKy.
03 Jan 2014 17:29 - 03 Jan 2014 17:51 #17865 by goebish
Replied by goebish on topic New Hubsan Upgraded Version on the way
vlad_vy wrote: Probably you need to change two bits, set one to 1 and second to 0 and vice versa.
No, here's what my "Extra" firmware is doing:
packet[9] = 0x02; // this bit must always be set
packet[9] |= (1 << Model.proto_opts[PROTOOPTS_EXTRA]) & 0xff;
it only set one bit, and it's working
it's the same than:
packet[9] = 0x02;
packet[9] |= 0x01;
if Model.proto_opts[PROTOOPTS_EXTRA] is set to 0
I don't understand why it wouldn't work
Last edit: 03 Jan 2014 17:51 by goebish.
03 Jan 2014 17:39 #17868 by goebish
I rebuilt the firmware, maybe I made a mistake sending the previous one and sent an old one, don't know, better double check:
speedy.sh/m8fzN/deviation-devo7e-Unknown.zip
03 Jan 2014 17:56 #17872 by SeByDocKy
goebish wrote: I rebuilt the firmware, maybe I made a mistake sending the previous one and sent an old one, don't know, better double check:
The same ....
It's very strange ... :(
03 Jan 2014 17:58 #17873 by goebish
Can you check in channels monitor if channel 7 > 0 with the HOLD switch set to 1 ?
03 Jan 2014 17:58 #17874 by SeByDocKy
The "Extra" version video :
03 Jan 2014 18:03 #17875 by PhracturedBlue
Replied by PhracturedBlue on topic New Hubsan Upgraded Version on the way
Can you please post your .ini file?
And did you remember to change the # of channels to 7? otherwise the 7th channel won't apply.
03 Jan 2014 18:26 #17878 by SeByDocKy
PhracturedBlue wrote: Can you please post your .ini file?
Haha I didn't :)
03 Jan 2014 19:09 #17879 by SeByDocKy
Ok ... set to 7ch but nothing improved :( ...
File Attachment:
File Name: model5.ini
File Size:16 KB
The video I did 2h ago
03 Jan 2014 19:16 #17881 by PhracturedBlue
Your ini is still wrong.
Try this one
File Attachment:
File Name: model2.ini
File Size:2 KB
the problem is that you have trim enabled which is reuslting in a multiplicitive factor.
03 Jan 2014 21:19 #17889 by SeByDocKy
PhracturedBlue wrote: Your ini is still wrong.
Try this one
File Attachment:
File Size:2 KB
It's working now :)
03 Jan 2014 21:22 #17890 by goebish
Mystery solved, thanks :)
Please share your H102D profile in the appropriate forum when it's working as you like.
03 Jan 2014 22:14 #17892 by SeByDocKy
goebish wrote: Mystery solved, thanks :)
Yep :)
11 Jan 2014 08:10 - 13 Jan 2014 03:08 #18352 by gke
Replied by gke on topic New Hubsan Upgraded Version on the way
Additional field decodings for telemetry packets carrying the 0xe1 tag (thanks Goebish) in byte 0 for the X4 V1 are:
enum Tag0xe0 {
    TAG,
    ROC_MSB, // ??
    ROC_LSB, // ??
    XUNK3,
    XUNK4,
    XUNK5,
    XUNK6,
    XUNK7,
    XUNK8
    Z_ACC_MSB,
    Z_ACC_LSB,
    YAW_GYRO_MSB,
    YAW_GYRO_LSB,
    VBAT,
    CRC0,
    CRC1
  enum Tag0xe1 {
    TAG1,
    PITCH_ACC_MSB,
    PITCH_ACC_LSB,
    ROLL_ACC_MSB,
    ROLL_ACC_LSB,
    UNK5,
    UNK6,
    PITCH_GYRO_MSB,
    PITCH_GYRO_LSB,
    ROLL_GYRO_MSB,
    ROLL_GYRO_LSB,
    UNK11,
    UNK12,
    //VBAT,
    //CRC0,
    //CRC1
Last edit: 13 Jan 2014 03:08 by gke.
11 Jan 2014 10:32 - 11 Jan 2014 10:58 #18358 by goebish
Thanks gke :)
Have you checked packets starting with 0xe0 on a H107 (X4 v1) ?
Last edit: 11 Jan 2014 10:58 by goebish.
11 Jan 2014 16:05 #18367 by vlad_vy
Replied by vlad_vy on topic New Hubsan Upgraded Version on the way
Can be unknown fields Z_ACC and YAW_GYRO?
11 Jan 2014 23:20 - 13 Jan 2014 09:57 #18383 by gke
Last edit: 13 Jan 2014 09:57 by gke.
11 Jan 2014 23:20 - 13 Jan 2014 09:59 #18384 by gke
Hi Vlad,
The values don't seem to change with my Hubsan V1. I have a V2 board so I will check that as well as exploring the 0xe0 tagged telemetry.
... seems like the yaw and accz may be in the 0xe0 packet...thanks Goebish.
Last edit: 13 Jan 2014 09:59 by gke.
13 Jan 2014 12:35 #18466 by goebish
We might try to code heading hold and head free modes thanks to those data !
Well done gke :)
13 Jan 2014 13:32 - 13 Jan 2014 13:34 #18472 by vlad_vy
goebish wrote:
midelic wrote: So only 0xE1 is with voltage telemetry?
At least on the H107 (X4 v1).
With 0xE0 VBAT, H107 always show 0,2V. With 0xE1 VBAT is OK.
Last edit: 13 Jan 2014 13:34 by vlad_vy.
Time to create page: 0.327 seconds
