New Hubsan Upgraded Version on the way
01 Jan 2014 18:36 - 01 Jan 2014 18:36 #17662
Replied by vlad_vy on topic New Hubsan Upgraded Version on the way
Now with H107 I have 0.2V only. Telemetry update works normally.
Last edit: 01 Jan 2014 18:36 by vlad_vy.
- goebish
- NRF Weirdo
01 Jan 2014 18:39 #17663
by goebish
Replied by goebish on topic New Hubsan Upgraded Version on the way
01 Jan 2014 18:47 #17664
Now it works normally.
- midelic
01 Jan 2014 19:03 #17666
by midelic
Replied by midelic on topic New Hubsan Upgraded Version on the way
So only 0xE1 is with voltage telemetry?
- goebish
- NRF Weirdo
01 Jan 2014 19:32 #17668
by goebish
Thanks !
At least on the H107 (X4 v1).
Created a pull request .
vlad_vy wrote: Now it works normally.
Thanks !
midelic wrote: So only 0xE1 is with voltage telemetry?
- midelic
01 Jan 2014 19:40 - 01 Jan 2014 19:41 #17669
by midelic
This hubsan holds hidden treasures.
I just wait to test.
Last edit: 01 Jan 2014 19:41 by midelic.
- SeByDocKy
01 Jan 2014 19:48 #17670
by SeByDocKy
Congratulations !!!
good job
Asap, I will receive my logic analyser... I will write there
Replied by SeByDocKy on topic New Hubsan Upgraded Version on the way
Thanks !
Congratulations !!!
01 Jan 2014 20:08 #17674
Replied by PhracturedBlue on topic New Hubsan Upgraded Version on the way
The code is now merged. Thanks1
- goebish
- NRF Weirdo
01 Jan 2014 23:18 #17688
by goebish
Hubsan is teasing a new model, again
www.helicomicro.com/hubsan-h109s-x4-pro/...=hubsan-h109s-x4-pro (sorry, in French).
Will it use A7105 ?
I guess we'll have to hack gps telemetry, gps waypoints and the likes
Will it use A7105 ?
- SeByDocKy
01 Jan 2014 23:39 #17689
by SeByDocKy
It's exactly what I asked ... so he said that former TX will be compatible so... it will be a A7105....
Yes ... more informations to hack
. Maybe they can open to deviationx ..
why not if they are not stupid ... they could probably sell more if it's known to be open
goebish wrote: Hubsan is teasing a new model, again
Will it use A7105 ?
01 Jan 2014 23:52 #17691
What equipment are you using the FPV with? Some sort of HUD? I'm just wondering what the use of having Deviation enable the FPV if it can't display it on screen?
I have an F7 which could possibly be used, but the overlay driver (not to mention MCU and ROM which could be upgraded wwith sufficient soldering skills)are so pitiful porting Deviation to it will be quite challenging.
So I'm curious how this capability is useful.
- goebish
- NRF Weirdo
02 Jan 2014 00:22 #17693
by goebish
It's useful to fly with my fatshark goggles and a better TX than the stock one.
- Xermalk
02 Jan 2014 00:37 - 02 Jan 2014 00:38 #17694
by Xermalk
Replied by Xermalk on topic New Hubsan Upgraded Version on the way
Im flying my hubsan quad using a devo 10, and my diy hmd.
The hmd really improves the immersion (the screen with lens takes up almost my entire view), and it makes judging distances easier.
And iv noticed that i fly much better/precise using the devo 10 then the stock hubsan tx.
Though, i have no clue on how i will be able get the additional telemetry in my googles. The devo or some external component would have to process the video and overlay the data. So i doubt that would be worth all the work for something as small as the 107.
Ill leave full blown huds/osds for my fpv bixler when i decide to try them out.
Edit: id post a picture of my setup, but i cant find my micro usb cable at the moment.
Last edit: 02 Jan 2014 00:38 by Xermalk.
- goebish
- NRF Weirdo
03 Jan 2014 12:04 #17829
by goebish
SeByDocKy could you try this build with your H102D please ?
speedy.sh/ubxQp/deviation-devo7e-Unknown.zip
It has an "Extra" setting in the Hubsan protocol options screen:
Try each one (0-7) and see if it starts video recording.
- SeByDocKy
03 Jan 2014 12:35 - 03 Jan 2014 12:35 #17830
by SeByDocKy
It's working for the "0" value
If go from "1" to "0" it starts the camera, from "0" to "1", it stops it
The best would be to start the video recording with trim button is it's done with the V2x2 model ini.... and you will be great if something can be written on main screen to indicate recording on/off
goebish wrote: SeByDocKy could you try this build with your H102D please ?
Last edit: 03 Jan 2014 12:35 by SeByDocKy.
- goebish
- NRF Weirdo
03 Jan 2014 12:38 - 03 Jan 2014 12:41 #17831
by goebish
Wow !
Worked on first try with just a guess, I'm feeling lucky
I think I'll implement it as I did for LEDs & flips, with a channel so you assign it to any switch / button you want and probably show an indicator on screen (sorry, I don't know how to use Deviation that much, I should learn someday...)
Can anyone confirm this is the thing to do (add one more channel to start/stop video recording) ?
edit: I'll have a look at V2x2 code to see how it's done.
Last edit: 03 Jan 2014 12:41 by goebish.
- SeByDocKy
03 Jan 2014 12:47 #17832
by SeByDocKy
with this model, you can see how they use trim to acticate camera, etc...
Left Vertical Switch Up - Ch7 Momentary - Camera/AutoMissle/HoistA
Left Vertical Switch Down - Ch8 Momentary - Video/Missle/Sprayer/HoistB
Left Horizontal Switch Right - Ch5 Toggle - Toggle LEDs On/Off
Left Horizontal Switch Left - N/A
- goebish
- NRF Weirdo
03 Jan 2014 12:48 - 03 Jan 2014 12:49 #17833
by goebish
Ok, it's just an extra channel, expect a patch for this evening, maybe included in tomorrow's NB if PB merges it.
Last edit: 03 Jan 2014 12:49 by goebish.
- goebish
- NRF Weirdo
03 Jan 2014 13:25 #17834
by goebish
vlad_vy if you read this I'd really be curious to know if it works with H107C ,I think I read its stock TX does not have a start/stop video recording button. Try this build, it should start recording after bind if it's working.
Devo 8s:
speedy.sh/5UpT8/devo8.dfu
Devo 8s:
03 Jan 2014 13:30 - 03 Jan 2014 13:31 #17835
It's impossible, H107C video recording device has only power wires to main controller, and start/stop button on board.
Last edit: 03 Jan 2014 13:31 by vlad_vy.
Time to create page: 0.202 seconds
- New Hubsan Upgraded Version on the way
